Hot Rods 31 Model A Victoria Build w/Pics - Miss Vicky
Discussion in 'The Hokey Ass Message Board' started by D-Russ, Jul 6, 2008.
  1. K13
    K13
    hahahahaha!
  2. D-Russ
    D-Russ
    Got the alternator bracket finished. All the pieces of the bracket were cut from 3/16 flat stock with a cut off wheel on a grinder, shaped with a flapper disc and then filed smooth with various flat and round hand files.
    Vic Walter likes this.
  3. scootermcrad
    scootermcrad
  4. DBruce
    DBruce
    Nice, I gotta come over & check it out?
  5. Martin_F
    Martin_F
    Looks like it's supposed to be there. Great job once again!
  6. ALEISTER
    ALEISTER
    That's a mighty small generator you got on there, but your bracket is sweet!
  7. DBruce
    DBruce
    Wish I could feeding the m***es tomorrow!
  8. DJM
    DJM
    Looks good Dave...progress progress progress
  9. D-Russ
    D-Russ
    Thanks Dave. Do you or your brother have a hemi in the works again? Dan called me to ask about how I adapted the Chevy crank pulley. Spill the beans man.
  10. DJM
    DJM
    Dave the hemi has been built for a couple years...so we started putzing around with it again. Did learn that the adapter was special cut for the sonic bellhousing. Enough about my junk. This is about your hemi...what's the next project to tackle?
  11. D-Russ
    D-Russ
    Right now I'm working through what to do with my thermostat housing – clearance between it and the fan is tight – like less than 1/4 inch. I also need to trim the fan blades about a half inch for clearance at the lower radiator tank. I still need to finish up the mods to the grille shell to move the radiator a half inch forward into the shell and I need to heat and dimple the driver's side header at the collector for steering clearance. Finally, I also have to fab up some sort of remote oil filter bracket, but I'm going to wait until I pull the motor back out for that.
    I'll pull the motor, put it on a stand, fire it and break it in. While the motor and trans are out, I need to finish welding in the motor mounts and weld in threaded bungs for the front upper shock mounts.
    Once that's done, I'll probably pull the body off the frame and finish welding the rear frame horns on from the top. Then I'll do body work and paint the frame (again).
    Then it's on to the body. I plan to lean the rear window forward about an inch and I'll have M&PC help me make a hood top. Then I'll do final body work and paint the body.
    Once all that's done, I ***emble the car for the very last time.
  12. DJM
    DJM
    Jeez Dave you paint such an optimistic picture. So ready by the 13th up here in f'burg?
  13. 57 HEAP
    57 HEAP
    Custom building with hand tools takes a bit of talent, very nice work.
  14. ClutchDumpinDan
    ClutchDumpinDan
    That's because the show is on the 12th...so it'll be done by the 11th. :D
  15. scootermcrad
    scootermcrad
    I wish I had something to share. :( Haven't had any time to work on it or when I finally do, it rains or something. I'm hoping ALL of that will change soon! Believe me... I'm itching to share some progress!
  16. D-Russ
    D-Russ
    I don't know if it takes any talent Sam, but it does take a can-do at***ude. I'm too dumb to realize that I'm doing stuff that I shouldn't be able to pull off.
    We're waiting patiently.
  17. D-Russ
    D-Russ
    Got a little more done this weekend. I trimmed a half inch of of each blade of the fan. (no pic)
    I notched the shell to move the radiator further forward. This is the bottom of the shell.
    I sourced and installed my highly modified (92–96 Corvette) thermostat housing. I picked it because it's super low profile and it points in the right direction.
    Installed the Hot Heads water crossover.
    I made upper and lower hose mock ups from paper towel rolls and ran out to the parts store to buy some hoses with the right bends.
    I had to move the mounting points on my shell after I moved the radiator forward.
    While the shell was off, I cut holes in the lower part to resemble a factory unfilled shell.
    And last, I bolted the shell on.
    The only engine mock up that's left now is the remote oil filter and dimpling the driver's side header for steering clearance.
  18. Malcolm
    Malcolm
    from Nebraska
    You're getting very close --- looking good!
  19. DBruce
    DBruce
    Wish I was going!
  20. D-Russ
    D-Russ
    Here's some good driving footage shot by my pal Martin (fuxl). The video is shot from the cab of his 36 truck and you'll see 57 HEAP's yellow 57 Chevy and JoeSmith's 50 Merc. Miss Vicky first appears 34 seconds in and shows up more in the end. The music is great.
    <iframe src="http://player.vimeo.com/video/31175460" width="500" height="281" frameborder="0" webkitAllowFullScreen mozallowfullscreen allowFullScreen></iframe> <p><a href="http://vimeo.com/31175460">Jalopyrama 2011</a> from <a href="http://vimeo.com/user9047267">Martin Fuchs</a> on <a href="http://vimeo.com">Vimeo</a>.</p>
    And another of the 283 that I sold to build the 354:
  21. 57 HEAP
    57 HEAP
    So you got a Corvette thermostat housing, what are those hoses off of?
  22. 57 HEAP
    57 HEAP
    A true hot rod, all matter of parts from many different makes.
  23. Brog
    Brog
    Are these the same carbs done at Clarke County Speed?
    I've been working for OJ for awhile and he's been teaching me alot. He showed me how to do the coating and I was doing it on numerous carbs over the summer. I tried a few different processes and eventually got it down to a process that we thought was best. This was my best batch I ever did if these are the same Carter's I'm thinking about.
    It's nice to see them in a different light. I think they look great, but what matters is what you think, I really hope you like them.
  24. D-Russ
    D-Russ
    Yes, they were built at Clarke County Speed. I think they look great sitting on the intake, but I haven't fired the motor yet because I'm still doing mock up. I should be firing it in the next few weeks though. I'll shoot some video of the big day. Thanks for your help on the carbs man.
    BTW, I met you and OJ at the last workshop OJ hosted. It was the one where Robert worked on the bus door and the Mustang door. Good times.
  25. Brog
    Brog
    Good to hear. Those carbs were pretty hard to get clean when they first came in haha, they came a long way. And yeah I'm sure I'd remember you if I saw you.
    By the way I love your 2 four-barrel setup, especially with the air cleaners. Oj was talking about changing his 6 deuce hemi over to a 2 four-barrel setup, I really wasn't convinced and couldn't picture it looking right, but after seeing yours I'm all for it.
  26. D-Russ
    D-Russ
    So I picked up my rear spreader bar (first mentioned in post 523) and my shifter from the chrome shop today. Baby steps. :)
    I had to put the spreader bar on as soon as I got home today.
  27. Martin_F
    Martin_F
  28. DBruce
    DBruce
    Did you weigh it before & after? Looks SMOOTH!
  29. D-Russ
    D-Russ
    I've been ****oning up the 354 so I can fire it and break in the cam.
    I figured I'd post the spacer I made to adapt a single groove Chevy pulley to the Chrysler harmonic balancer. First I opened up the center of the Chevy pulley and drilled six holes in it to match the holes in the balancer.
    Then I made the spacer to align the pulleys. I started with a chunk of 3/8 aluminum. I drilled six bolt holes and then cut a big hole in the center to clear the bolt and washer that hold the balancer on.
    I then opened up the center hole so it centered snugly on the balancer.
    Then I cut the outer circle and tried the fit.
    And then I installed the pulley. I need to have the machine shop mill a little of the thickness off so the pulleys align perfectly.
