Projects 51 Ford F1 daily driver
Discussion in 'The Hokey Ass Message Board' started by kevinwalshe, Nov 29, 2012.
  1. kevinwalshe
    kevinwalshe
    Windshield wipers in with a two speed electric motor from speedway. Not a bolt in and the motor turns the wrong way from the park position. I unplugged the park wire and now stop them in the right spot with the switch. Rain-x is still going to be a good friend of mine.
  2. Johnny Wishbone
    Johnny Wishbone
    That thing is looking good! Newport Engineering makes a really nice wiper setup for those trucks and it is a bolt in available with 2 speed with intermittent. They are friends of mine and all they do is wipers for old stuff. Bob has truck cabs and cut up cowls all over the place from doing mock up. Anyway, you are definitely making me want to get back to work on mine.
    http://www.newportwipers.com/
  3. kevinwalshe
    kevinwalshe
    Thanks Johnny, I'll give it a look.
    I put the hood spears on yesterday. ImageUploadedByH.A.M.B.1380736148.264593.jpg
  4. Flamed48
    Flamed48
    Have you come up with any wheel choices yet?
  5. kevinwalshe
    kevinwalshe
    I'm thinking all chrome steelies with white walls, black steelies/moon discs with black walls, or white steelies/baby moons with redlines. Not sure which one I like best. Your thoughts?
  6. Fairlane Mike
    Fairlane Mike
    Looks really GOOD!! I would go with white wheels and use the '51 style hub-caps. You can make "adapters" out of outside snap hub-caps and screw or pop-rivet the old caps on. Of course I'm ***uming you'll be using newer style wheels.
  7. OahuEli
    OahuEli
    from Hawaii
    Gotta chime in here. I've been digging your work on the truck and have a special spot for the 51-52 F1s. Had one a couple of years ago that I brought back from the dead and nearly got on the road before I had to sell it. Got a photo album of it on here. I also do Photoshop and if you can post a side or angled perspective of the trucks' current state I'll do my best to put together some work that reflects your wheel and tire ideas. This oughta be fun! :D Eli
  8. Mark in Japan
    Mark in Japan
    Mooons with blackwalls!!!!!
  9. kevinwalshe
    kevinwalshe
    Thanks oahueli, I'll snap a pic in some good light tomorrow. Markinjapan, that's the way I'm leaning! This was my little Saturday, not too shabby! ImageUploadedByH.A.M.B.1381043745.599155.jpg
    It was a knights of Columbus show. Small, casual but put a smile on my face!
  10. Mark in Japan
    Mark in Japan
  11. kevinwalshe
    kevinwalshe
    Armed with some oak, a table saw, chop saw, sander and oil based polyurethane, I ripped the new bed boards with my dad tonight. ImageUploadedByH.A.M.B.1381198188.845539.jpg
  12. Johnny Wishbone
    Johnny Wishbone
    Congrats on third place! How will you do with cool wheels and tires? Here are some pics for inspiration.
    These two are my buddy Dave's truck.
  13. kevinwalshe
    kevinwalshe
    I cut did a test with the polyurethane and didn't like the color so decided to stain it a rosewood color. Here's a pic. ImageUploadedByH.A.M.B.1381291911.678504.jpg
    And then I pulled all the strips out to spray the raptor-liner on the sides of the box and weld in a new rear frame crossmember which I cut to length today. ImageUploadedByH.A.M.B.1381291974.224052.jpg
  14. jfreakofkorn
    jfreakofkorn
    its coming along nicely ...
    keep up the good work .... =)
  15. kevinwalshe
    kevinwalshe
  16. drptop70ss
    drptop70ss
    from NY
    Looks great, getting close to the "end" but they are really never done!
  17. kevinwalshe
    kevinwalshe
    Got the running boards back from the sandblaster, then quickly put some acid etch primer before I spray the Upol Raptor Liner on them and the inside walls of the box. ImageUploadedByH.A.M.B.1382497022.069942.jpg
  18. EPP
    EPP
    from Oklahoma
    truck is looking great. Keep up the good work
  19. kevinwalshe
    kevinwalshe
    Sealed the bare steel on the box, and tailgate then prepped it for the Raptor liner. ImageUploadedByH.A.M.B.1382633770.733997.jpg ImageUploadedByH.A.M.B.1382633787.567335.jpg
  20. kevinwalshe
    kevinwalshe
    Sprayed the raptor liner today. Turned out pretty damn good! ImageUploadedByH.A.M.B.1382816482.720678.jpg ImageUploadedByH.A.M.B.1382816500.949884.jpg ImageUploadedByH.A.M.B.1382816515.853161.jpg ImageUploadedByH.A.M.B.1382816535.515589.jpg ImageUploadedByH.A.M.B.1382816584.379613.jpg
  21. CoolHand
    CoolHand
    Alliance Vendor
  22. LowKat
    LowKat
    I've been lurking on your build and just want to say good job!
    The colors look great.
  23. Mark in Japan
    Mark in Japan
  24. 2dr_sedan
    2dr_sedan
    Looks good, although that front suspension looks sketchy!
    You need some Astros and skinny white-walls to set it off.
  25. kevinwalshe
    kevinwalshe
    I'm currently saving up for the rear end, new driveshaft, brake lines, wheels/tires, jag front suspension and steering components. I want to do it all at once, rather than have it sittin on jack stands for an extended period. I'll get the clip and rear end first, then wheels so at least it's a roller.
  26. kevinwalshe
    kevinwalshe
    Heater is in with the defrost ducts connected. Just need to wire it and decide on whether or not to use a bulk head connector or not. I think the less areas it can leak, the better. Also wired a cigarette lighter and dome light. ImageUploadedByH.A.M.B.1383783466.866008.jpg
  27. OahuEli
    OahuEli
    from Hawaii
    I like the chrome dash parts!
  28. fordf1trucknut
    fordf1trucknut
  29. DBruce
    DBruce
    Looking great Kevin, I gotta catch-up!
  30. drptop70ss
    drptop70ss
    from NY
    Hey Kevin, how much clearance do you have from the top of the rear axle tube to the bottom of the frame? I am setting up my rear suspension now and am trying to figure out how much the rear of the truck will come down once the bed is put on. It looks like you had at least 4" clearance when the bed was off so curious how much it came down.
