electric fuel pump
Discussion in 'The Hokey Ass Message Board' started by belair, Sep 30, 2013.
  1. belair
    belair
    My Carter just gave up with not so many hours on it. Who makes a good low pressure one?
  2. gtowagon
    gtowagon
    Carter is the best one do you have a filter before the pump
  3. belair
    belair
    No-but that makes sense. Guess I killed it.
  4. Fenders
    Fenders
    I use a Carter P4070 (5 - 7 PSI, no regulator needed) with a steel filter before it at the tank and a paper filter at the carburetor.
    Nice pump but man is it LOUD !
  5. TagMan
    TagMan
    Do you have it rubber mounted ??
  6. JeffB2
    JeffB2
    from Phoenix,AZ
    I have been in your shoes,DO NOT use a filter with a paper element and especially a FRAM POS which burned a pump up with a couple hours on it also.This works well and can be taken apart for cleaning and is compact http://www.summitracing.com/parts/rus-645120/overview/ also comes in 5/16"
  7. gtowagon
    gtowagon
    I have a fram canister filter in front of my carter pump in my truck this setup has lasted for 75k miles so far I change the paper filter every 5k
  8. Fenders
    Fenders
    That Summit is the filter I use at the tank -- sintered bronze or so-called steel filter. A paper filter is fine at the carb. (**** steel, push paper.)
    My carter is rubber mounted with the bushing mounts that came with it, guess I should add more though.
  9. belair
    belair
    Thanks guys-good info on the paper and bronze filters.
  10. tb33anda3rd
    tb33anda3rd
    did you try pulling it apart and checking the screen?
  11. GeezersP15
    GeezersP15
    from N.E. PA
    I recently installed an Edelbrock electric fuel pump on my non-stock 1948 Plymouth. It replaced a "Mister Gasket" POS that failed. It's mounted with what appears to be an ignition coil bracket, and a rubber isolator. Fairly quiet, and no regulator required. So far, it works very well.
  12. belair
    belair
    Checked the screen, no junk. I guess the motor just failed.
  13. 61falcon
    61falcon
    I have an aeromotive pump. they are pricey but it has been on the car for years with no issues.
  14. sidevalve8ba
    sidevalve8ba
    I too had a Carter low pressure fail on me recently. It might have had 1500 miles on it and yes I did have a filter between it and the tank. Luckily I had a spare pump with me just in case. I've always been a bit leery of electric pumps.
  15. 1971BB427
    1971BB427
    from Oregon
  16. 46Ford
    46Ford
    Did you have it mounted with the motor down? Carter's mount that way and are cooled and lubricated by the fuel.
  17. belair
    belair
    yes^^^^. Got another one today. And a pre-filter. This is on a Mercruiser 250, and I think there is no fuel pump lobe on the cam. So I have to have a good pump. I might buy a spare and put in trunk. A bit pricey, but better than being stranded.
  18. sidevalve8ba
    sidevalve8ba
    What exactly do you mean when you say "motor down"?
  19. 46Ford
    46Ford
    Motor can should be pointing toward the ground. Electric terminals on the bottom. The motor can is intended to fill with fuel while the pump is running. Here's a pic of the one
    I installed on my T. Actually the final version has the filter after the pump, but this is the only shot I have. This one has close to 14000 miles on it.
    BTW Holley pumps mount with the motor up.
  20. leadsled
    leadsled
    I have nothing negative to say about the Carter pump, I am a fan of the Holley Red.
  21. JeffB2
    JeffB2
    from Phoenix,AZ
    Since you need a low pressure pump run this number Carter P60504 on Amazon.com they are running a deal on them,several guys in my Ford group run them on their flatheads.
