Projects The "Minges" 31 coupe
Discussion in 'The Hokey Ass Message Board' started by cornfieldcustoms, Oct 2, 2013.
  1. cornfieldcustoms
    cornfieldcustoms
    been working on this car for a while, i have posted some of the build progress in a thread with a lot of other work going on in the shop, but i figured it is worthy of its own thread. will also be doing some other threads of a few other cars we are doing
    the body i started with
    removed the fenders
    getting a game plan
    the drive train
    tapered the front rails
    "Z" ing the rear section of the frame, internally shear load gusseted
    Stogy and kiwijeff like this.
  2. cornfieldcustoms
    cornfieldcustoms
    starting to come together
    body on the frame
    motor set on stands ready for to start fabbing mounts
    rear cross member and spring perch
    frame inside of body
    Stogy and mike bowling like this.
  3. cornfieldcustoms
    cornfieldcustoms
    bending the k member
    both sections bent
    side sections tacked in and rear cross member tacked in
    start of the trans cross member
    tacked in trans cross member, waiting on the rubber mount to finish the mount
    Stogy likes this.
  4. cornfieldcustoms
    cornfieldcustoms
    motor mounts going in
    Stogy likes this.
  5. cornfieldcustoms
    cornfieldcustoms
    got a 32 heavy dago drop axle in for the car. and got it rolling supporting itself. here are the pics at the end of the 6th day of work this car
    the dago
    lower spring mount on the bones
    and rolled it out side for a good look
  6. fritzz
    fritzz
    from canada
    nice build,thanks for sharing.
  7. Shaun1162
    Shaun1162
    Looks great!! Perfect stance...
  8. cornfieldcustoms
    cornfieldcustoms
    thanks guys, i will keep posting to get it up to date. stay tuned
    work on the torque arm, since it is running an open drive shaft with split bones. used an old wishbone that was bent, heated and bent it to the desired shape.
    front mount of the torque arm, tie rod end, mount has the 7* taper reamed into it
    rear mount was drilled and sleeved with 1.5 od tube and polly bushing installed, .125 plate mounting brackets on the rear end
    also clamped up a different cowl top since the front edge was cut off the old one, still need to do the sides
    Stogy likes this.
  9. cornfieldcustoms
    cornfieldcustoms
    work on the floor skeleton a**** other things. the 3x1 tube behind the tail shaft will be cut out in the center for the drive shaft
    Stogy and chop job like this.
  10. cornfieldcustoms
    cornfieldcustoms
    more work on the floor skeleton
    making some cardboard templates for the new subrail section that will attach the body to the tube skeleton
    transferred the pattern onto steel, p***enger side all tacked in
    driver side all tacked up
    cut the center section out for the drive shaft, and made a piece to go above it
    started welding up some of the floor skeleton
  11. cornfieldcustoms
    cornfieldcustoms
    started some work on the floor. added some raised areas on the floor pans for strength and some design, using my Baileigh bead roller. on the trans tunnel i added another raised area in the center and some louvers.
    Stogy, chop job and bct like this.
  12. cornfieldcustoms
    cornfieldcustoms
    fabbed up front section of the trans tunnel
    p***enger side toe board
    area of the floor were the fuel tank will sit
    all the lines laid out for the section of the floor that go between the floor pans, and the gas tank area
    the panel made up and in place
  13. manyolcars
    manyolcars
    Why louvers in the floor to let all the engine heat into the car?
    nochop, INVISIBLEKID and chop job like this.
  14. cornfieldcustoms
    cornfieldcustoms
    this panel goes behind the area for the fuel tank and makes a small storage area in the rear
    and with the fuel tank in place
    chop job likes this.
  15. BBYBMR
    BBYBMR
    Nice - good work. Keep the updates coming!
  16. cornfieldcustoms
    cornfieldcustoms
    the original quarters had the fenders gas welded on, higher than normal. needless to say they did a horrible job and ruined the quarters. i tried to grind down the welds and straighten the original metal, but it was to thin and brittle. so i decided to just make new centers for the quarters. here is how they are coming out
    before i got started
    the old quarter center removed
    the new sheet metal, spent some time on the english wheel to get the crown to match the original.
    first test fit, pulled it back off and did some more wheeling and shrinking on the flanged side
    started tacking it in place
    Stogy likes this.
  17. cornfieldcustoms
    cornfieldcustoms
    mostly welded up and ground, ran out of welding wire for the day. once i get it fully welded and ground, i will do some more metal working to finish it out
    since i ran out of welding wire and had a couple more hours till close, i started on the hood. making a cardboard template
    bead rolled, flange bent, and ran through the slip roll
    some more rolling
    got it fitting good, still needs some finish work
    Stogy, Tim, chop job and 1 other person like this.
  18. cornfieldcustoms
    cornfieldcustoms
    the louvers are because louvers are awesome lol, the bottom of the louvers will be plated to seal out the heat
    Stogy, INVISIBLEKID and chop job like this.
  19. cornfieldcustoms
    cornfieldcustoms
    got the driver quarter pretty much finished ( still need to do a little the rear area) .after all the welding and grinding i think it turned out nice, will just need a little filler right around the body lines to smooth out some of the grinding marks. then it was time to start on the wheel well.
    cut the old wheel well out
    the customer had already bought these wheel wells so i will use them. needed to be cut out for axle and spring clearance. i also moved the finished ends of the beads up that i had to cut through. i think it gives it a nice finished look.
    Tim and chop job like this.
  20. cornfieldcustoms
    cornfieldcustoms
    then i need to add the flange back on where i cut
  21. manyolcars
    manyolcars
    I sure do admire those quarter panels!
    Stogy likes this.
  22. cornfieldcustoms
    cornfieldcustoms
    got the wheel wells tacked in and then welded solid and smoothed out
  23. cornfieldcustoms
    cornfieldcustoms
    working on the other 1/4 panel this past week.
    the old 1/4
    removed
    cleco'd in place ready to be trimmed
    mostly welded up, and ground
    starting on the wheel well
    moved onto a few smaller things as well
    mounted the heater
    mounted the oil filter can
    and the fuel block
  24. cornfieldcustoms
    cornfieldcustoms
    started on repairing the driver side cowl area, needed a new lip formed and the lower patch panel installed that the owner already bought
    had to make a new front edge for the cowl section, this is the panel all laid out ready to bed and roll
    all the patch panels tacked in place
    the driver side all welded and ground, there are still a couple small spots that need some attention
    then started to fit the deck lid skin while i let the panels cool between welding
    Stogy likes this.
  25. bostonhemi
    bostonhemi
    luv the work, the gas tank work and planning terrific
  26. cornfieldcustoms
    cornfieldcustoms
    the old section of the rear p***enger quarter panel, it was a little beat up and had some rust. so i decided to replace the whole corner.
    the old
    the new all welded in, still needs a little metal work
    did a little more tweaking on the trunk opening to get the deck lid fitting good
    a shot of the deck lid first row of louvers started
    all louvered up
    found another hidden rust hole
    patch panel all tacked in place
    ready to put in the p***enger side wheel well
    all tacked in place
    Stogy likes this.
  27. cornfieldcustoms
    cornfieldcustoms
    had to modify the new stainless head light stands to work with the car
    got both lights mocked up, mounted them low for a more aggressive look
    brake/ clutch master cylinder mocked up
    had to machine these support blocks/ spacers for the deck lid hinges. they help support the sheet metal on the body and are counter bored to allow the raised area around the thread boss on the hinges
    new hinges on
    a shot of the support braces installed
    Stogy likes this.
  28. cornfieldcustoms
    cornfieldcustoms
    started on the p***enger door. i figured it would be best to put a full lower skin on up to the belt line. that way if you looked inside the door you could not see the weld seam.
    started off by making a paper template, then transferring it to some sheet metal
    old door skin removed, all the loose rust scale removed and some black primer sprayed on
    i forgot to take pics of me making the skin itself. pretty much i used the english wheel to get some crown on the panel, then ran it through the bead roller to make the lower body line. used the brake to bend the edges up. i will snap some pics of the making of the skin tomorrow when i make the driver side.
    new skin clamped up
    inside edge like a factory skin
    inside of the weld seam, cut out the inner bracing so i could get in to hammer and dolly the weld seam area
    after some welding, grinding and hammering and dollying this is what i came out with
    once the skin was cut out of new sheet metal, i laid out some lines to show a basic wheeling pattern to get a crown started on the skin
    after some wheeling you can see some shape on the skin
    then to get the crown in the other direction you turn the skin 90* and wheel away.
    after more wheeling you can see the crown, or compound curve on the skin
    moved on to putting the body line on the bottom of the skin
    after a run through the bead roller
    then broke the edges of the skin
    Stogy likes this.
  29. cornfieldcustoms
    cornfieldcustoms
    then shrank the edges to follow the crown of the skin
    when i got the old skin off the driver door there was a lot of rot and pin holes in the bottom of the door frame, so i had to make a new door bottom.
    after a couple hours of bending, drilling and bead rolling i came up with this
    after a few more hours of cutting, welding and grinding
    had to do some steel buck rivets
    pretty much all finished
    sorry for all the updates at once, just trying to get up to with the pics on this car
  30. cornfieldcustoms
    cornfieldcustoms
    in black primer ready for the new skin
    overall i think it turned out pretty nice
    i decided to make another hood for the coupe, the more i looked at the first one the more i was not happy with the way it turned out. the new one looks much better. still needs some minor work but coming along
    i pulled all the sheet metal out to weld all the floor skeleton up and ad some bracing that was all beat up form being a drag car
    welding all the 1x1 up
    here is how the bracing has been all beat up and destroyed
    here is a new brace a bent up to replace the old ones
    a before and after shot while making the braces, and some during fabrication pics
    a finished pair
