1951 motor mount install. help
Discussion in 'The Hokey Ass Message Board' started by ooGREYoo, Oct 2, 2013.
  1. ooGREYoo
    ooGREYoo
    from canada
    ok so yet again i jumped the gun and took the body off the frame not thinking about my motor install, so if anyone is useing the same mounts in my pic or knows a link with the install that would be a great help..if you are useing the same mounts and could give me a few points to measure from that would be great too. any help at all thanx again.
  2. 55 dude
    55 dude
  3. ooGREYoo
    ooGREYoo
    from canada
    Oh sorry 51 BEL AIR
  4. 1955IHC
    1955IHC
    That does not look like an o.e.m. mount. Is that an aftermarket mount for a sbc?
    Sent via Illinois Bell Telephone Company's Car Radiotelephone
  5. ooGREYoo
    ooGREYoo
    from canada
    Yes to place a sbc in the 51 frame
  6. 1955IHC
    1955IHC
    That's what I thought. They appear to be universal and the placement depends on where you want the engine to end to up.
  7. ooGREYoo
    ooGREYoo
    from canada
    Yes I get that.but the body is off the frame so I dont know where to make it clear the firewall and the rad.
  8. Mudslinger
    Mudslinger
    You need the body on to make sure where these go and also the fan and radiator. Theres too many variables you can run into to try installing with the firewall to help place them.
  9. ooGREYoo
    ooGREYoo
    from canada
    The big problem Is the frame and body are in two towns.. someone must be using the sane mounts and be able to give ma a few measurements
  10. ooGREYoo
    ooGREYoo
    from canada
    ok so after a long search i found this.....
    <HR style="BACKGROUND-COLOR: #e5e5e5; COLOR: #e5e5e5" SIZE=1> <!-- / icon and ***le -->
    <!-- message -->went to install my motor mounts today, and something doesn't seem right. Instructions say mount center goes 17 13/16" from center on front bumper holes and as I do this, my mount hits a bracket on the frame. Are my measurements off? I don't mind having to notch the mount to fit, I just want to make sure. Thanks
    so im guessing all i have to do is line my mounts up the same way?? 17 13/16" to my center hole....someone here must have a 48-54 bel air with a small block in it ...i just need a measurement from any point to the center hole in the mount. thanx for the help
  11. ooGREYoo
    ooGREYoo
    from canada
    i found these pics. but dont want to go by them any location points would be great
  12. Rust8it2
    Rust8it2
    Check Ch***is Engineering for their weld in motor mounts, I used the install directions on a small block install in a 50 and they were very accurate and worked out fine most measurments pull from existing bolt holes on the frame.... hope this helps
  13. ooGREYoo
    ooGREYoo
    from canada
    ive looked at both chasis engineering and ch***is engineering inc..dont see the directions on eather. any old links? or maby someone can just head out to the shop and toss a tape on the frame and tell me how far back the center is... you would think this is all over the net wtf.
  14. ooGREYoo
    ooGREYoo
    from canada
    oh and are you guys useing the solid mounts? or the rubber ones? im talking about the mount that bolts to the motor...not the frame mount... thanx again
  15. 56sedandelivery
    56sedandelivery
    I'm fairly certain those are the CE mount instructions. We used them on my 51 Bus Coupe, now my nephews car. Do you know who made your mounts? The CE mounts are quite a bit different than yours. Butch/56sedandelivery.
  16. fastcar1953
    fastcar1953
    the measurement would be the same. the center of mount to front bolt hole. sometimes there are brackets that are in the way and have to be removed.
