Projects Why would someone do this?
Discussion in 'The Hokey Ass Message Board' started by pat59, Oct 3, 2013.
  1. 24riverview
    24riverview
    Went out in the weeds in the dark just to prove my point, doesn't look like I needed to, LOL. 59 9 inch but same idea.
  2. NMCarNut
    NMCarNut
    I agree, it really looks like the taper is part of the drum. It is just very rusted on. I have had several that look just like that on cars I've saved from the woods. You can remove the drums by carefully grinding the portion of the axle protruding from the drum down to clean metal by using a Dremel or something similar and then soaking for a day or two with a good penetrating oil.
    Worked for me every time.
  3. Best way to get the drum loose is spray some penetrating oil in/though/around the studs/axle, then start beating on the drum between the wheel studs (after backing off the adjusters). I've never had this fail to get 8/9" Ford drums off....
  4. 1bustedbuick
    1bustedbuick
    LOL!!! True!
  5. finn
    finn
    Not welded. That drum is coined as part of the manufacturing process. Heat it up with an oxy-acetyline torch and the drum will expand and slip right off (after a few hits with a BFH).
    Won't come off without the torch, and no, your propane plumbing torch isn't up to the task.
  6. 1955IHC
    1955IHC
    Get some KANO KROIL penetrating oil. It's saved my ass a ton of times.
    Sent via Illinois Bell Telephone Company's Car Radiotelephone
  7. All squirted down with kroil. I'll take another crack at prying and hammering in the AM after a good soak, and if that don't get me anywhere, The 2 5/8 hole saw fits over the axle perfectly. :)
    -Pat
  8. mrhotrods3
    mrhotrods3
    I have always just sprayed some oil on axel where You think it is welded and then smack the hell out of it in between the studs and keep going around each stud and if its not welded it will come loose as every time You hit it it will draw the oil into hub Ive had some tough ones that other people couldn't get off come off and doesn't hurt a thing or bend hubs ect. just keep Hitting it with a 1/2 lb hammer it will break loose eventually never had one that I couldn't get off this way,
  9. Cerberus
    Cerberus
    Went thru the same thing with my 1936 "special construction" I thought the same thing. The drums were welded to the 8" Ford axle. Thought about it and said to myself, No this can't be. Got out the big rubber mallet, my BFH, big feet with boots and kept kicking & pounding on the drum. When you least expect it, and you have almost run out of energy, the drum will pop loose. See my pix of the rusty ordeal. Before and after.
  10. Well found this pic on the bay, original four lug drums (mine are supposed to be five) BUT, you can clearly see the raised flange on the front and back of the drums. So, They are not welded as many have already said. I'll give 'em a good beatin' in the AM. :)
    -Pat
  11. blowby
    blowby
    from Nicasio Ca
    If that's welded it's been turned down.
  12. rustang
    rustang
    +1... those axles look like Ford 8" diff....some of those drums on Fords are tapered/convex, and do fit tight.....I don't think it's welded, but may be frozen on good...
    Tom
    Edit... I should have read further, others already gave you the same advice... :)
  13. blowby
    blowby
    from Nicasio Ca
  14. JEM
    JEM
    Doesn't look like a weld to me, that's the taper stamped into the sheet metal web of the drum.
  15. frankenfords
    frankenfords
    from SoCal
    I haven't read all the posts, but that not a weld. It's a tapered lip cast then machined into the drum hat to keep the drum in place on the axle register. Clean the axle stub with a wire brush, blast some penetrating oil on it, smack the drum with a hammer from a million different directions, and work the drum off. Then wire brush everything again before you put it back together.
  16. I Drag
    I Drag
    Think about it...who would weld the brake drums on when bolting the wheels on would accomplish the same thing?
    Anyway, I recommend a HF 4# sledge, thats what I use at work.
  17. el Scotto
    el Scotto
    from Tracy, CA
  18. classic gary
    classic gary
    why don't you remove the four nuts holding the backing plate to the axle housing, the whole thing should remove with a few yanks, axle and drum and backing plate....
  19. The37Kid
    The37Kid
    These must make great circus tent pegs for guys with poor hand/eye coordination. Bob
  20. R Pope
    R Pope
    If all else fails, use an air chisel to split the drum from a wheel bolt hole to the center hole. The drum will come off easy then, and it can still be re-used.
  21. 5DeuceSled
    5DeuceSled
    Im surprised no one else mentioned this; aren't brake drums ,for the most part, made of cast iron? Cast iron cant be welded to steel. I think they can be friction welded, but not any other way.
  22. Late to the party but that is not welded although a little rusty and stuck,,typical of some of the older fords. HRP
  23. Sqeaky Hinge
    Sqeaky Hinge
    I have to agree with a lot of guys here , those are some real purty welds , maybe even factory weld quality , seems like a weird thing to do , but , as far as appearance , nice....
  24. john walker
    john walker
    not welded, but with all that crusty rust, it ain't going to come off easy. clean it up with sandpaper and a wire wheel before you spend more effort on it.
  25. raidmagic
    raidmagic
    I love people that post without reading the thread. Always good for a laugh.
    btw I don't think those are welded, if so, those are nice welds. :D
  26. nailheadroadster
    nailheadroadster
    Those are some damn nice welds!
  27. VoodooTwin
    VoodooTwin
    from Noo Yawk
    apply heat to the "weld" area of the drum with your rosebud torch. the drum will come right off. its not welded.
  28. BillWallace
    BillWallace
    Pound the drum on not off. When you try & pound the drum from the back side it is like the old Chinese finger tube. It tightens up on the axle stub.
  29. black 62
    black 62
    from arkansas
    vely intelesting...
  30. Well got it all apart. Everything inside was completly rusted out and seized up. I used the hole saw to cut that flange off of the drum centers. and a couple BFHs and pry bars and alot of sweat. I've now got a bunch of scrap metal. Now to clean up the rear and get all new brake parts.
