Projects Finally found my original 283
Discussion in 'The Hokey Ass Message Board' started by Butch Clay, Oct 1, 2013.
  1. MannyK
    MannyK
    from NYC
  2. Butch Clay
    Butch Clay
    Pulling out the first piston. This is really getting to be fun!
  3. Butch Clay
    Butch Clay
    Emily, pulling out pistons
  4. larry woods
    larry woods
    from venice fl
    Great to see your daughter involved. (have previously) written about my failure to do so ). These are the memories you will cherish, savor them, teach and be patient. Maybe in your advanced years they'll find time to go with you to a car show on father's day as my daughter did this year and my son to Bonneville with me!
  5. swade41
    swade41
    from Buffalo,NY
    Just reading this for the first time and pulling the engine with a rope a mile down the road is just funny as all get out. Around here it would have fallen into pot holes to never be seen again.
  6. racer32
    racer32
    Butch, the engine's at least had the heads off at some point. It has later-model heads on it. What are the casting numbers?
  7. Butch Clay
    Butch Clay
    The heads that were on it have a casting number of #3988338X (the 8's 9's & 6's are really hard to tell apart because the castings are horrible)
    But I also have a set of Power Packs with a casting number of #3795896
    My plan was to have the power packs machined for 184's, new guides, 3 angle valve job, screw in studs, all new parts, and hardened seats. $600 in labor. I will NOT be using modern heads because these heads I have had since I was 16.
  8. Butch Clay
    Butch Clay
    Dropped the old girl off at the machine shop to have it cleaned and nothing machined or installed.
    I'm gonna bring it home and smooth off the casting marks.....then have it re-cleaned and machined.
    I smoothed a small spot on the side and it really motivated me to do this. Should be fun.
  9. shadams
    shadams
    Haaahaaa! I just showed a co worker this guys pic of his engine sitting in the middle of the street, cracked me up. Then the hippo comment...man that was a great thread....wonder what ever happend...
    As far as this thread, awesome story. I have been thinking about finding an old 283 to build up for my truck or next project. I just think saying you have a 283 in it is much cooler than a 350, even if it is a little step backwards in the power dept. My little one is only 5 months old but I plan on doing everything I can to get her involved with the hobby...
  10. hendo0601
    hendo0601
    from Tacoma, WA
    Lookin good man! The inside of that engine doesnt look half bad for sitting so long. I like the gigantic gloves your boy is wearing. This is a project your kids will remember for a very long time.
  11. Butch Clay
    Butch Clay
    Thanks guys. It's been a lot of fun.
    Thinking of painting it similar to a Chevy orange but punched up a little with some metallic. Not sure.
  12. 55Belairretrorod
    55Belairretrorod
    from Australia
    I'm thinking solid lifters, dual quads, power packs with 184's, very mild cam and figure out a car it will go in.
    Not an option to slip it into your dad's old '46 truck?
  13. 56LINK
    56LINK
    Crazy how some things just stay around for ever, sounds like it was meant to be...great to see the kids geting in there and doing things with ya they will remember it for sure..building up the next generation of rodders.
  14. D.N.D.
    D.N.D.
    Hi Butch
    Boy does your story bring back memories for me as I had a 57' Bel Air with the ' 270 ' motor in 59-60 doing a little street racing
    Hanging out at Bob's Big Boy in Van Nuys the ' 270 ' engine was the hot to go thing to have in your tri 5 chevy
    Now days Mellings and other people make a copy of the Duntov cam the 097, and did they ever sound great with some ticky - ticky in the valve train and some gl*** packs you knew the car was a Factory hot rod
    With todays sticky tires you might think about some better rods & bolts as they were pretty spindly, if you are going to gas it up at all there will be more load on the bottom end as back in my day we just had narrow hard tires that just smoked very easy
    Would hate to see you break you new toy because of a weak rod, might want to clean up the sides of the rods too and a bead blast to keep any cracks from starting
    Have fun. G Don
  15. carpok
    carpok
    from Indy
    Thanks for posting your 283 story. Brings back lots of fond memory for me also. I had a hopped up 270 H.P. in my first 55 in the late 60s. You never get over the music those motor make. It's like your first, favorite 8-track tape you never forget it.
    I guess that's why I have a fresh 327 domed pistons, solid lifter motor sitting in my 55. Just waiting for it first test drive. Ron
  16. johnc451
    johnc451
    I have a 283 that a buddy gave me about 10 years ago. He got it with a car he bought but had no need for it. I oiled it and sealed it in a plastic bag. A month ago I open it up to look at it just for fun. It was apparently given a "quickie" hone and ring job at some point--no real care--crud caused a rod bearing to score- a big oil pump put on to save the day and then they gave up. It cleaned up at +.030, crank only need polish, and it is being prepped to go into a 51 pick-up. Yep---giving away some cubic inches--but I can not wait to be driving a screaming 283 again! Great story---hope your efforts are rewarded with a good runner. Should last way past those kids first licenses.
  17. Butch Clay
    Butch Clay
    Well, I have a 40 that's untouched in a dry barn. I'm also thinking of a T Bucket.
  18. Butch Clay
    Butch Clay
    Here's the last photo sitting on the docks of an engine shop to be cleaned. It should be done today. Pretty excited to pick it up.
  19. Butch Clay
    Butch Clay
    Here's my first intake I had when I was 16. It's a GM part. #14044836
    Thinking of using it.....but dual quads would be sweet!
  20. kwoodyh
    kwoodyh
    Go with the Z28/LT1 intake, had it this long why not put it to use?
  21. Butch Clay
    Butch Clay
    Picked up the block and ready for grinding to smooth out the casting marks. Previous to dropping it off I ran a Roloc disk on the side of the block to see how well it would clean up after cleaning.
  22. mgermca
    mgermca
    Hey BC, any updates on this adventure?
