What gears should I use ??
Discussion in 'The Hokey Ass Message Board' started by crusty a, Oct 8, 2013.
  1. crusty a
    crusty a
    Can anyone tell me what the formula for deciding on what gear ratio to run.
    I'm running a 283 small block S-10 5spd with a ford 9" rear tires are 700-16 would like to be around 2000 rpm @70 mph.
    Thx.
  2. DumbstixLars
    DumbstixLars
    from ATX
  3. 1955IHC
    1955IHC
    You will also need to determine which overdrive gear ratio you have. There were multiple ratios used over the years depending on the specific engine combination used in the S10.
    http://www.apexgarage.com/tech/gear_ratios.shtml
    Sent via Illinois Bell Telephone Company's Car Radiotelephone
