Projects 1965 Buick Riviera - the build
Discussion in 'The Hokey Ass Message Board' started by Snake hit, Jul 11, 2013.
  1. Snake hit
    Snake hit
    from calif. LA
    Here is the 425 nailhead engine. The numbers matched but the heads were red under the blue paint (66 heads) and .030 overbore when it was pulled back in May of 2012, it looked like a fresh build from the outside( new paint) but you never know, pulled heads off , looked pretty fresh.
    [​IMG][​IMG]
  2. Snake hit
    Snake hit
    from calif. LA
    Heads have 3 coats of Por-15 Ford red engine enamel, now time to prep the block, ran out of paint need to order more.looks real glossy and thick.This red will match up real nice with the pinstripe on the inside of the engine bay.
    [​IMG][​IMG][​IMG][​IMG]
  3. Snake hit
    Snake hit
    from calif. LA
    Just a few ideas that I have for the Art Deco interior build.
  4. Snake hit
    Snake hit
    from calif. LA
    Painted the engine bay two tone with stripe, the frame , under wheel wells and A arms were painted with RustOlium Hammer finish black brush on. Has a charcoal finish to it.
    [​IMG][​IMG]
  5. Snake hit
    Snake hit
    from calif. LA
    A few more pictures of the top and sides, top and side was buffed.
    [​IMG][​IMG][​IMG]
  6. Gasoline
    Gasoline
    from Atlanta
    Interested in the pistons and sent you a PM. Thanks T
  7. Snake hit
    Snake hit
    from calif. LA
    Yes sent you a PM last night.
  8. Snake hit
    Snake hit
    from calif. LA
    In its stock form over two years ago, the tranformation to what I invision will be quite drastic but subtle.
  9. Snake hit
    Snake hit
    from calif. LA
    The look Im going for on the turn sinals, under bottom of bumper will be cutouts 9'' x 2'' for a camero type rectangular slant 8'' long by 3'' stainless tip with 3 stainless slats welded on the tip to match the turn signals.
    [​IMG][​IMG]
  10. Snake hit
    Snake hit
    from calif. LA
    Up to this point Im waiting for the car to be completed by the painter, still need to wet sand and buff, and also paint inside trim, dash, console and gas tanks for my harley. Lets see how long I ca
  11. Snake hit
    Snake hit
    from calif. LA
    Some more interior stuff Im looking at for that Art Deco look. Also instead of walnut veneer Im going for some real carbon fiber black.
    [​IMG][​IMG][​IMG]
  12. Snake hit
    Snake hit
    from calif. LA
    Some minor touch ups to the Rivi, ready for buffing and painting consoul and dash then finished with paint.
  13. OahuEli
    OahuEli
    from Hawaii
    I've liked them 'ol Riviera's since seeing them on the dealership floors when I was a kid. They looked like they were hauling *** even when sitting still. Your car looks like its gonna be top notch! Subscribed.
  14. Snake hit
    Snake hit
    from calif. LA
    Some pics of the touch up painting, durring the project I had an extra set of tanks painted with 1965 scheme and badges also electra glide script. next is block sanded flat then 3 stage buff then its off to the garage for engine and ******.:cool:
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  15. Snake hit
    Snake hit
    from calif. LA
    Some touch ups and PPG 2021 clear on the engine bay and jambs.
  16. Snake hit
    Snake hit
    from calif. LA
    Completed all the clear coat on door jambs and engine bay.
  17. mt94ss
    mt94ss
    What's going on with your car? Is it finished?
  18. Snake hit
    Snake hit
    from calif. LA
    Some final last touch ups, some interior parts painted and building the dask with a real carbon fiber kit. hopfully out of the body shop by next week then to the garage for engine ****** and posi then off to the upholsterer, and last tires and bagged.
    [​IMG][​IMG][​IMG]
  19. Snake hit
    Snake hit
    from calif. LA
    And had the ralley Rims painted gunmetal grey to match the bottom panel.
    [​IMG][​IMG]
  20. Baumi
    Baumi
    Great Build! I love 65 rivis!
  21. RockinRivi
    RockinRivi
    Very very nice…
  22. Snake hit
    Snake hit
    from calif. LA
    Since the body shop is taking thier time Im going to add the front grill for them to paint and clear all the vertical lines gloss black. working on the rear bumper and turn signal lights, cut outs for the rear bumper rectangular stainless slanted tips. On the turn signal Im going to cut off the vetical lines and add two horizontal lines for a total of 3 slats then heve them chromed add sequential lights to them and maybe even have 3 polished stainless horizontal slats added to the exhust tips.
    [​IMG][​IMG]
  23. Kustombuick
    Kustombuick
    Hey Snake, love the build on your Riv, lots of nice details. Who did the power sunroof install for you, I like the looks of it and its factory feel.
  24. OahuEli
    OahuEli
    from Hawaii
    That oughta look sharp! I like the sequential idea too.
  25. Snake hit
    Snake hit
    from calif. LA
    Kustombuick, in California they customize a lot of lowriders, I asked this cholo where hehad his sunroof done. The place is called Sunroof Performers in south gate California. This type was called a factory bend, using a used GM sunroof from a earlier model and they cut your top an inch smaller than the sunroof, there is jigs used and chilled then bent down and the sunroof is installed from under. Thus calling it a factory bend.
  26. Kustombuick
    Kustombuick
    Thanks Snake hit, the build is great, lots of cool details. just picked up a 63 Riv to fix up so your giving me some great insperation...Alan
  27. Snake hit
    Snake hit
    from calif. LA
    This is how the bumper turned out with cut outs and cutting the vertices lines on the rear turn signal light housing
  28. flynbrian48
    flynbrian48
    Great project. I like the sunroof add, one may end up in my own '63 Riv!
  29. Snake hit
    Snake hit
    from calif. LA
    Cleaned block, painted with ford TBird red POR -15 brush on 3 coats , chased all hole treads , replaced main seals with new neoprene rubber instead of the old rope seals, torqued cap bolts cleaned and rebuilt oil pump, sequenced torqued heads and installed cam. image.jpg image.jpg image.jpg image.jpg image.jpg image.jpg
