Features 1959-60 Ford F100 Pics?
Discussion in 'The Hokey Ass Message Board' started by BEAR, Jun 17, 2008.
  1. 4rod
    4rod
    another tip on lowering the rear is to move the front(rear) perch to the top of the frame rail, you have to drill new holes and run 5/8 bolts through the rail...this also, adds another 2 3/4 drop...did it on my '54...same concept though for 57-60.
  2. Barn Find
    Barn Find
    from Missouri
  3. Hoptup Jalop
    Hoptup Jalop
    And where is this?
  4. Lowriders Art Gallery
    from Montana
    Amazes me, that for a low production vehicle, there are so many panels left. I have saved two from a similar fate.
  5. djlifter
    djlifter
    from oklahoma
    We have already flipped the axle, so doing Sid's idea on the rear leaf isn't gonna happen right now unfortunately.
  6. djlifter
    djlifter
    from oklahoma
    60 is lowered
  7. djlifter
    djlifter
    from oklahoma
    Lowered
  8. paco
    paco
    from Atlanta
    Looks good.
  9. djlifter
    djlifter
    from oklahoma
  10. paco
    paco
    from Atlanta
    It looks like a very well kept rust free Okie truck. Power? What'd you do on the front to ger er down in the weeds?
  11. djlifter
    djlifter
    from oklahoma
    Pack
    Thanks. It really is a very straight and virtually rust free truck. One very small rust spot on the inside Of one cab corner. That's it !! No other rust.
    I did a 3 inch dropped axle from Sid. Removed one small leaf. May do another. Depends on if it settles a little more.
  12. djlifter
    djlifter
    from oklahoma
    It's lookin pretty good. More to do. Did get the bumper tucked in 2.5 inches
  13. djlifter
    djlifter
    from oklahoma
    Bumper
  14. paco
    paco
    from Atlanta
    That'd look great with the front bumper tucked a bit towards the fender. Always liked that custom touch.
    Good luck with the truck. Again - kewl sled.
  15. Unibodyguy
    Unibodyguy
    Bumper looks a Hell of a lot better that way. Should been like that from the factory.
  16. Hotrod1959
    Hotrod1959
    Looking real good Danny.......
  17. djlifter
    djlifter
    from oklahoma
    Thanks Bob.
    Have you sold the other truck ? Green one ?
  18. Hotrod1959
    Hotrod1959
    Yes the green one is gone........
  19. oneab4951
    oneab4951
    from naperville
    Picked up a new project today! 59 f100 6cyl 3 speed it runs and drives!
  20. daddio211
    daddio211
  21. Tony Ray
    Tony Ray
    Anymore info on what that truck was used for or what the bed is off of?
  22. oneab4951
    oneab4951
    from naperville
    The truck came from oklahoma.The bed is a utility box that has been sectioned.Not sure how long the box and truck have been together.
  23. resol
    resol
    I've been working on my 59 for a few months now. Bought it mostly like this but I don't know the original builder. If anyone has any info on it, please let me know.
  24. Mellowgt
    Mellowgt
    Where can I find front cab corners? Search ios coming up empty.
  25. Jaybird60
    Jaybird60
    You will need to find a donor cab, they don't repro the front ones.
  26. Mellowgt
    Mellowgt
    Gotcha, figured that after hours of research. Wonder how different the 61+ front corners are? A guy on FTE was going to see if they work, it got me thinking as well. I just don't have one available to measure.
  27. Lowriders Art Gallery
    from Montana
    61 is different. I have been having great luck with finding 2 ton truck donor cabs. If you look at my crewcab, you can see that there is a lot less work in splicing a whole cab, verses putting in patch panels. Just finished another 59 2 ton front half, and a 60 big back window cab. After the cabs are loose, cut the windshield post, splice the floor. About two hours welding time.
    Here are a few pics...
    Nicks59 likes this.
  28. StuntmanJames
    StuntmanJames
    from Denton Tx
    Just picked this ol girl up a few weeks ago! Loving it! Dont see alot of stepsides looking this good in my opinion! And she has AC!
  29. Lowriders Art Gallery
    from Montana
    What does the AC unit look like? Is it a factory option?
  30. StuntmanJames
    StuntmanJames
    from Denton Tx
    it was def an aftermarket add on from the previous owner. Said it was around 3k for parts and labor. Just a small unit under the middle of the dash. Two vents or i can switch it to the top dash vent. Blows nice and cold but she needs some insulation to keep the cold in better. Dynamat or the equivalent is next on the list! :)
