Projects 33 downs laid back drag coupe build
Discussion in 'The Hokey Ass Message Board' started by Citizen caine, May 25, 2013.
  1. Citizen caine
    Citizen caine
    After building & racing drag cars for 13 years my father and I have decided to build a old coupe. We do everything ourselves in my 2 car garage.
    Our plan is we're building a 9second drag car with limited street use.
    Here is our build.
  2. H.G. Wells
    H.G. Wells
  3. Inland empire hot rods
    from so cal
  4. Citizen caine
    Citizen caine
    Here is the body when we picked it up from downs industries
  5. Citizen caine
    Citizen caine
    9" rear
    Doug Nash 5 speed
    351w
    76mm or twin turbo
  6. Citizen caine
    Citizen caine
  7. Citizen caine
    Citizen caine
    My Great Dane thinks his new Dog sits perfect on the chassis jig
  8. Citizen caine
    Citizen caine
    Cut the wheel well out down the center to get a 6" tub
  9. Citizen caine
    Citizen caine
    Her is a 13x32 slick for mock up.
    We will run a 15x32.
  10. Citizen caine
    Citizen caine
    Sections of wheel wells that were cut out are now being fiberglass end back in, but not show in final position.
    Notice the 3 steering wheels!
  11. Citizen caine
    Citizen caine
    We bought boxed frame rails & will locate cross supports as needed
  12. Citizen caine
    Citizen caine
    Frame being narrowed 6"
  13. Citizen caine
    Citizen caine
    First side of rear frame cut and located
  14. Citizen caine
    Citizen caine
    Both sides of the frame narrowed
  15. Citizen caine
    Citizen caine
    Had to make sure I was on track with my alterations
  16. Citizen caine
    Citizen caine
    Wheel tub filled with fiberglass. After I get it cleaned up I will have fiberglass sprayed in, it will look like it was molded like this when its done.
  17. Citizen caine
    Citizen caine
    Starting to locate stock 351w.
    I think the motor is sitting a little low. Still trying to work this out.
  18. Citizen caine
    Citizen caine
    Well that what we got done so far.
    We've had the car 2 months.
  19. 32 hudson
    32 hudson
  20. This should be good !
  21. Ready for some more please
  22. Citizen caine
    Citizen caine
    Iv been away from home for a while.
    But we're back at it now!
  23. Citizen caine
    Citizen caine
  24. Citizen caine
    Citizen caine
  25. Citizen caine
    Citizen caine
    Motor is placed for mock up so I can get the firewall
    Cut and get ready to fab floor supports
    Well the front end was set up for a little motivation
  26. Model A John
    Model A John
    from wichita ks
    Looks like your project is moving along. Keep us posted!
  27. LeadSledMerc
    LeadSledMerc
    Nice start...I'll be watching this build!!
  28. Citizen caine
    Citizen caine
    Thanks guys. Iv built many cars over my shirt time
    In this hobby, big this is my first ground up build
    & also my first coupe.
    I'm loving the fiberglass, it's amazing iv not found
    Any rust yet!
    I will be doing some things different than most of you are used
    To, this is a drag car.i won't have nice carpet, fancy door panels, or soft leather seats.
    We are all about being light & fast. A big turbo is coming down the line. We will be 1000-1200hp.
  29. That should be cool !!!!
    A 61 olds jet fire turbo set up keep it Hamb friendly.
