MOON tank photo gallery
Discussion in 'The Hokey Ass Message Board' started by Jeem, Aug 25, 2012.
  1. papa's 39 koop
    papa's 39 koop
    My old IH..
  2. jimmy1931
    jimmy1931
    Like that coupe, show us more sometime.
  3. Ranunculous
    Ranunculous
  4. rpkiwi
    rpkiwi
    from Truckee CA
    A buddy of mine just gave me this original Moon Tank that he used racing in his 55 Chevy back in the 70's down in LA.Wasnt sure whether I should use it,but have decided I like the look and have just finished making the brackets.Will use it as an auxiliary back up fuel tank in combination with the original.
  5. captmullette
    captmullette
    mine has eelco brackets I guess its a eelco tank ??
  6. ArtofHotRod
    ArtofHotRod
  7. Muttley
    Muttley
    Yep, you can tell by the shape of the tank.
  8. ArtofHotRod
    ArtofHotRod
    kool .................
  9. Original tank, brackets and cap.
  10. pecdaddy
    pecdaddy
    Like that car hb32. Ford in a Ford, sweet.
  11. Drive'em
    Drive'em
    Here's mine, same as my avatar
  12. 1971BB427
    1971BB427
    from Oregon
    Mine's a swap meet clone, that had a fugly chrome gas cap on it. I had a knockoff hub and spinner, so I cut it down to fit over the neck, and setscrewed it to the neck, so I'd have a better looking cap. It also had ugly black steel bracket and straps. I cut the bracket down and used 10-24 threaded rod, with clear tubing to mount it.
  13. blue57ford
    blue57ford
    Here is mine. I've had it about 12 years collecting dust. It was actually from an old monster truck from the 80's. The Texas Ranger.
  14. hotcargo
    hotcargo
    this one is an original Australian Bill Croft ( Idlewild ) tank from the Sixties
    it will be coolant overflow tank for the Hemi in this thing
  15. hiboyroadsterboy
    hiboyroadsterboy
    from Mass
    Mine.
    chryslerfan55 and cruiserjohn76 like this.
  16. Buckeyeman
    Buckeyeman
    Here's mine, has the pump in the handle.
  17. hiboyroadsterboy
    hiboyroadsterboy
    from Mass
    Is it being a Poser if the tank is just for looks?
  18. Kerry
    Kerry
    Why wouldn't you use it?
  19. hiboyroadsterboy
    hiboyroadsterboy
    from Mass
    Well I did when the car was built 9 years ago,it was my overflow.I took it off and put another overflow tank under the hood,so now my moon tank is used for looks.It's always off and on the car.
  20. Kerry
    Kerry
    Plumb it for gas and put race fuel in it. I used a mid eighties pickup tank solenoid. Very much worth it for me as I can set my blower boost retart to 0 and make a bunch more power than when running 87 with timing retard.
  21. Big Mac
    Big Mac
    Moon tanks are for wagons, too!
  22. Powerage440
    Powerage440
  23. paul55
    paul55
    from michigan
    pic of mine.
  24. model.A.keith
    model.A.keith
  25. model.A.keith
    model.A.keith
  26. need louvers ?
    need louvers ?
    Does anybody have any idea the diameter and thread count of the Moon spinner type cap?
    I have an old off brand tank that is in good shape, built some brackets for it, but I don't have a cap and would like something that would look good through the toneau cover for the bed. The neck is 2 1/2"X16 thread.
  27. Kerry
    Kerry
    A new style cap or an old style? New caps are threaded on the inside and old caps are threaded on the outside. I've got an old style I can measure.
  28. Tim_with_a_T
    Tim_with_a_T
    ^What he said. I have a new cap and old cap available to measure. I think you can buy the new cap with a threaded weld in style bung, so you could just cut out your old filler neck and weld in the new.
  29. need louvers ?
    need louvers ?
    This has external threads on the tank itself, so I guess I would need the later style. Just hoping I could just buy the cap itself and not get concerned about the bung, but if I have to I will get both.
  30. hiboyroadsterboy
    hiboyroadsterboy
    from Mass
    Does anyone know if MoonEyes will send me another tag for the front of my tank,mine got screwed up?
