Projects '53 Chevy 210 Texican build
Discussion in 'The Hokey Ass Message Board' started by brooksinc1976, Jul 15, 2013.
  1. brooksinc1976
    brooksinc1976
    from P-Town
    Look at my thumb. Gee I'm dumb. ImageUploadedByH.A.M.B.1373940414.674866.jpg . Yep after a few good swings my hammer found my thumb. This is my project. ImageUploadedByH.A.M.B.1373940618.838408.jpg . Bought it from a guy who got too deep. Got the rear suspension rebuilt and installed tonight. ImageUploadedByH.A.M.B.1373940797.394381.jpg ImageUploadedByH.A.M.B.1373940811.112325.jpg Critiques are always welcome- good or bad. I'm in the green horn category and plan on learning from y'all. Like how to swing a hammer. Ha.
  2. 54rat210
    54rat210
  3. Leebo!
    Leebo!
    from Yale OK
    Maybe you shouldn't use a hammer. Other than that it looks like youre off to a good start!
  4. willys1
    willys1
    from South Ga
    "Like how to swing a hammer. Ha." sure we do, but more importantly: how did you like it? Good luck on your build and wear gloves when you can. at least it's a little protection:)
  5. brooksinc1976
    brooksinc1976
    from P-Town
    That was with gloves. I probably would not have skin. There was some power behind that swing.
  6. Mr48chev
    You can usually tell a guy who has been doing ch***is and suspension work for a while by the scars on his off hand.
    I could have beat JD Fikes with my good hand when he took the long way to the emergency room to show me a car in someone's carport after I smashed my thumb with a 2-1/2 lb hammer and needed 4 s***ches though.
    That looks like an interesting project, keep us posted on the progress.
  7. brooksinc1976
    brooksinc1976
    from P-Town
    Well it's been a slow learning process rebuilding the ft suspension. Got it tore down and had fun installing one of the upper inners. Thank goodness for the chevytalk link of the rebuild.
    My game plan is to get the ch***is rolling and put the Lego set back together and make it a driving work in progress so the fam can enjoy it as it evolves. That said on vacation I picked up some Mexican blankets and a cool mask for the interior ImageUploadedByH.A.M.B.1375932905.516220.jpg . I know they are a trendy style but be trendy till I break down on a new interior.
  8. brooksinc1976
    brooksinc1976
    from P-Town
    Not much of an update. The suspension is almost finished along with the brakes. Started stripping the body preping for blasting and primer. ImageUploadedByH.A.M.B.1381368448.083655.jpg got board and put some flames on the gas tank. My girls helped now my car has all their art work on it starting to wonder if I should just clear over it ha
  9. brooksinc1976
    brooksinc1976
    from P-Town
    ImageUploadedByH.A.M.B.1381885859.286094.jpg almost ready for sand blast and prime. Got to pull her out of the garage to get the other door off. Hopefully this time next week ill have her back cleaned and primed. ImageUploadedByH.A.M.B.1381886038.729960.jpg had trouble getting the hinges off so we had to redneck improvise with my impact. Ha
  10. brooksinc1976
    brooksinc1976
    from P-Town
    View attachment 2053665 almost ready for sand blast and prime. Got to pull her out of the garage to get the other door off. Hopefully this time next week ill have her back cleaned and primed. View attachment 2053674 had trouble getting the hinges off so we had to redneck improvise with my impact. Ha
  11. brooksinc1976
    brooksinc1976
    from P-Town
    The more I research fab work the more im thinking of changing the tail lights. What do you think is a less invasive surgery vs the cool factor. Ill take other suggestions. Thx
    '53 chrysler windsor
    '55 lincoln
    55 or 56 packaed caribean
  12. low budget
    low budget
    from Central Ky
    The Texican? Never heard that before, That may be a common term down that way I dont know, but that seems like that would be a cool name to be painted down the side of an old g***er from that area.;)
  13. KIRK
    KIRK
    Try keeping both hands on the hammer next time.
  14. 325w
    325w
    John Wayne used the term " Texicans " .
  15. brooksinc1976
    brooksinc1976
    from P-Town
    Yep, the Texican, the Duke used it along with other big Texas names like Sam Houston.
    Yep, thumb nail is still growing back and still swollen.
    ImageUploadedByH.A.M.B.1383100550.898706.jpg before
    ImageUploadedByH.A.M.B.1383100580.958884.jpg after
    Looks like more Swiss cheese that I thought. Luckily, most of it was in the pans which I planned on having to replace. Time to track down my patch panels.
  16. tricitiesxs
    tricitiesxs
    looks like a pretty solid start
  17. mrconcdid
    mrconcdid
    from Florida
    Great start, keep digging!
    Godspeed
    MrC.
  18. brooksinc1976
    brooksinc1976
    from P-Town
    She's a roller ImageUploadedByH.A.M.B.1383964835.770769.jpg ImageUploadedByH.A.M.B.1383964848.149549.jpg still need to finish up the brake lines but it rolls...
  19. brooksinc1976
    brooksinc1976
    from P-Town
    Motor in - check.
  20. brooksinc1976
    brooksinc1976
    from P-Town
    http://youtu.be/ajk_KlF8kDI
    This is the link to the first start. Didn't want to drop much into it if it was gona need a lot of work so I did the bare minimums and sure enough she fired off and she didn't smoke as bad as I thought. Now I get to rebuild the carb...
  21. brooksinc1976
    brooksinc1976
    from P-Town
    Not much of an update. Got the carb rebuild and alt. waiting on the water pump. And got my oil bath cleaned and painted ImageUploadedByH.A.M.B.1386291599.740190.jpg ImageUploadedByH.A.M.B.1386291611.670516.jpg
  22. Olderchild
    Olderchild
    from Ohio
    That was my first car years ****x + ago:eek: as for the thumb i doubt you will ever catch up to me,seems like every time i swung a hammer my eyes crossed and my thumb became the target, now i grab a pair of channel/locks to hold a chisel, got a little smarter with age:D If my memory serves me right mine never, even after being rebuilt wouldn't carry more than 5/10lbs oil pressure at idle and 20/30 lbs with the go peddle on the floor. My neighborhood friend who's dad was a mechanic/ mechanist helped a 16 year old kid out by rebuilding the engine after hours in his shop,he told me to go to the junk yard and get a power glide cam and carb. cause they were bigger than the three speed,.10ths over rings on standard pistons lol did it ever have piston slap but ran dam good for many, many years
  23. brooksinc1976
    brooksinc1976
    from P-Town
    Not a huge update but started on the rockers and pans. Here comes learning curve 101... ImageUploadedByH.A.M.B.1391908283.509187.jpg ImageUploadedByH.A.M.B.1391908328.454473.jpg
    And I almost have my ch***is rolling just need to finish up the brakes and connect the torque tube.
  24. King Karl
    King Karl
    from N.C.
    Now would be the perfect time to put a late model rear in. IMO
    You'll want one when its all said and done.
  25. brooksinc1976
    brooksinc1976
    from P-Town
    Yes that is what I would like to do however I'm glutten for punishment. I'm trying to go us get on the drive terrain so I can hemorrhage more on the body work and interior for the wifey. I'm sure as soon as I get her where she can drive it will cash out and I'll have to change it...
  26. brooksinc1976
    brooksinc1976
    from P-Town
    Few updates my buddy and I have been acting like sheet metal guy cutting out rust. I'm sure there is a better quicker way but we are committed now. Ha. On the ch***is I have ben looking for or buying odds and ends that my Lego set either didn't have or I couldn't find. ImageUploadedByH.A.M.B.1394980798.007439.jpg ImageUploadedByH.A.M.B.1394980812.883692.jpg my dad got a wild hair and pulled this out of storage. We horse traded it for some concrete work. I know it's not hamb friendly but he promised it to my boy for his first car. I figured it would be a good guinie pig on my painting skills. We're planning black on black. All the chrome is pitted so were gona gloss black it... ImageUploadedByH.A.M.B.1394981021.388338.jpg ImageUploadedByH.A.M.B.1394981038.838976.jpg
    On a side not does any one have this for sale or know where to get it. Have trouble finding it. Thx ImageUploadedByH.A.M.B.1394981141.600692.jpg ImageUploadedByH.A.M.B.1394981152.433468.jpg
