Projects Flat FED build
Discussion in 'Traditional Hot Rods' started by roseville carl, Jan 14, 2010.
  1. fenderless
    fenderless
    from Norway
    Our first trial this year was with a magneto with built in advance.
    Lazy launch, fixed advance with static 25 degrees, came to life:)
    New numbers coming your way Carl, as we ended up with 14-15 psi this time:)
    What boost are you aiming on?
    K
    Taildragger&fenderless
  2. roseville carl
    roseville carl
    12 -15........... don't wanna push too much
  3. 38FLATTIE
    38FLATTIE
    from Colorado
    What compression do you have? You can get away with a little higher compression, since you say you're only running 6.6 lbs PSI. What cam/cam specs are you running. Regardless of what Joe and the 'experts' say, these engines still like a higher lift cam.
    Carl, she's looking good, my friend!:cool:
  4. Goose
    Goose
    Compression should be around 10:1 and I have a 390 lift cam 284 schnieder seris
  5. roseville carl
    roseville carl
    Goose you really need to cc the chambers to make sure of what you have and its easy to make em bigger if you have to, also remember to add to you figures what relief you have, I know offy's are off a lot on some heads.......
    Got the final touches on the lubricator today and I am happy with the outcome......
  6. carshopowner
    carshopowner
    Very nice!
  7. 38FLATTIE
    38FLATTIE
    from Colorado
    Carl, that's sweeeeet!
  8. Alden8100
    Alden8100
    from Canada
    Really done a nice job there. Looking sounds good. The display you present for us is inspiring and very professional. I am also work on it. This will be helpful for me taking ideas. thanks everyone...
  9. fenderless
    fenderless
    from Norway
    Hmmm, a guy said this to me;
    Damn Kjell you have way tooo much time on your hands!!!
    What should I say Carl? Really outstanding pice of art:)! Now I will not post pictures from my garage:D!
    K
    <!-- / message --><!-- sig -->
  10. Wow Carl! That is a thing of beauty!
  11. roseville carl
    roseville carl
    Touche' Kjell
    Thanx Tim It sure looks better than that rusty ol piece it used to be, even momma's happy..........
  12. roseville carl
    roseville carl
    Well had a wonderful weekend...........
  13. dragsled
    dragsled
    from Panama IA
    Great video Carl, Looks like your haveing the time of your life out there, Tim Jones
  14. greaser
    greaser
    Great day at the track.
    Do you always run in the left lane?
  15. roseville carl
    roseville carl
    I'll run anywhere and anything...............
    Had a good run against an injected Chrysler, that was fun, always try to run Elwood as he will give me a head start, run some of the HAMB guys its more about seat time than anything................
  16. Carl with one of the Y-Block girls. :)
  17. hilltopgaragede
    hilltopgaragede
    from Delaware
    Kool project! What's the coupling that you are using and where are you getting it?
    My FED is also direct coupled from trans to rear, but I've never had the cover off.
  18. fenderless
    fenderless
    from Norway
    Very Cool video Carl:) This evenings entertainment;)
    K
  19. roseville carl
    roseville carl
    Hey Timmer thank the girls for me, glad they got recognized for their efforts. Do you have a high res pic of that???:D
    Try Brad at Fabcraft Metal Works 800-208-8242
  20. Actually cropped from a much bigger picture, that's about as good as it gets. There may be more as my friend has yet to give me all the shots he took. ;)
  21. Goose
    Goose
    Well we ran the rail Sunday with the blower for the first time. We now know we need some better rear tires! Our best run of the day in the 1/8 mile was 7.46 seconds and 94.4MPH!! It ran flawlessly all day with no problems. Shifting is hard with the manual transmission, but with a little patience that too became easier. We had 3 runs of 7.47 then 7.46 and 7.51. Pretty consistent when it shifted ok. With some better rear slicks I think it will go even faster.
  22. roseville carl
    roseville carl
    Great Goose, I need pics though!!!
  23. Goose
    Goose
  24. Goose
    Goose
    Here are a few pics from the weekend!
    djhalladay likes this.
  25. roseville carl
    roseville carl
    Now if that don't get the blood goin nothing will!!!
    plus she sounds great in the video!!!!
  26. Goose
    Goose
    One of the straight axel mafia!
  27. Goose
    Goose
    Carl it sounds completely different than it did. If we get some better tires on her it should launch a lot better. We tried taken off at a higher rpm, but it just spun the tires really bad. We are looking into getting some new slicks for her!
  28. Once you go to a blown flathead - you'll never go back! Gets into your blood first, then your pocketbook. :eek:
  29. fenderless
    fenderless
    from Norway
    Yes D. That sums it up perfect:) It's an addiction:)
    K
  30. wrenchbender
    wrenchbender
    Carl I definately agree 100%. Hey goose what wheelbase is your car that thing is soooo bad*** !!!!!
    Chrome don't get ya home
