1934 Chevy Master or Standard
Discussion in 'The Hokey Ass Message Board' started by sodas38, Oct 15, 2013.
  1. sodas38
    sodas38
    Well I've picked up a 34 Chevy Coach but can't determine if its a standard or master. I got several measurements from someone with a master and they match up. However there are 3 things that throw it off from what I've read on the interweb.
    I've read that Standard rear fenders bolt up under the body instead of into the side. This is what mine does. Also my wheelbase is 109" whichever doesn't match either standard or master. My car has a leaf spring front, Masters came with knee action. It's got me confused.
    Any help is greatly appreciated.
    Thanks
  2. Master of None
    Master of None
    If yours has the I beam axle up front it is a standard .
  3. Jokester
    Jokester
    I think you have a Master. The Standard had the instrument cluster in the middle and no glove box.
    .bjb
  4. F&J
    F&J
    I say Standard for just one reason....and I could be wrong.
    Your hubcap looks small. The standard had a 4.25" boltcircle 5 lug, and master was 6 lug with kind of a puffy looking center hub on the wire wheel.
  5. Slimmey
    Slimmey
    Definitely a Master dash. what does your firewall look like? Standard had a deep recess, Master had a shallow ( 1" or so then flat) wheel base has me stumped, Standard should be 107", Master 112".
  6. Slimmey
    Slimmey
    Oh, Nice ride! Was going to post pic of master firewall, but it won't load.
  7. Egghead
    Egghead
    Agree with Jokester.
  8. Wally
    Wally
    from Iowa
    Someone could have built that car back in the 60's or something and converted some pieces from a Standard to a Master. Change out the dash and maybe the grill shell. Maybe the frame he had was junk so he used a different frame that he had lying around. Isn't 109 inches what a 31 or 32 Chevy has for a frame length?
  9. sodas38
    sodas38
    I got under and tried to look at the frame, thinking maybe they changed out the front years ago. The frame is gas axed just rear of the front spring mount. Someone's done something to it. The bright work on the hood, headlights even the garnish is chrome, all leads me to believe its a Master. The dash too. I bet they did something to the frame or switched it out altogether.
  10. wisebri24
    wisebri24
    My 35 standard has 107 wheelbase. 5 lugs. Straight axle. X cross member ch***is.
  11. paul55
    paul55
    from michigan
    rear fenders are master and grill/headlites appear to be master. Also, standard had shorter hood and no trim on hood louvers. The wheels have been changed as well, as should have 17". Noticed pedals are not org., so the beam axle has probably been installed at some point.
  12. mgtstumpy
    mgtstumpy
    Master. Instruments & glove box along with knee action front suspension. Centre x-member is different. When I get home I will post frame & hood specs. Body & panels are not interchangable. I used a Master instrument cluster on my Standard. Not hard to swap a dash.
  13. sodas38
    sodas38
    I've read the dash's do not swap between master and standard as the Standard is 7/8 the size of the Master. Here are some measurements I got off another thread, these are from a Master 2 Door sedan.
    Back (side window length) - 30 3/4"
    Front Door Length- 41 1/2"
    Back of front door to front of rear fender - 7 1/2"
    Running board length - 49 1/4"
    Hood length (side panel) - 42 1/4"
    Cowl vent is hinged from the front
  14. primed34
    primed34
    Looks like a Master to me. Kneeaction front was an option and wheel base measurements from the factory were all over the place from car to car. Rear fenders are Master. No trouble to swap dashes. As best I remember, all '34s had front hinged cowl vents.
  15. pasadenahotrod
    pasadenahotrod
    from Texas
    33 Series CA Master 110" wheelbase
    33 Series CC Standard 107" wheelbase
    34 Series DA Master 112" wheelbase
    34 Series DC Standard 107" wheelbase
    35 Series EA Master 113" wheelbase with Dubonnet "Knee" action suspension
    35 Series ED Master 113" wheelbase with beam axle suspension
    35 Series EC Standard 107" wheelbase
    Your tape measure is your friend.
    Find the data plate and verify series.
    109" wheelbase doesn't match any 33-35 Chevy p***enger car, only 32 and earlier had models with 109" wheelbase.
  16. Slimmey
    Slimmey
    As primed said, dash is the same size W & H, std & master cowl vents opened at rear. I think the earlier merc/eagle series dashes were different. 1st cowl pic is a master, 2nd is std.
  17. 302GMC
    302GMC
    from Idaho
    That's a '34 Master with '33 Eagle wheels ...
  18. paul55
    paul55
    from michigan
    Actually, the dashboards are a direct swap.
  19. raymay
    raymay
    In 1934 Knee-Action was new and available for all models. Not sure if yours has the original motor but in 34 the Master series came with a new engine called the Blue Flame.
    Master series had 112"wb and Standard series had 107"wb.
    You can also check your serial number. The Master series starts with a "DA" prefix and the Standard series starts with a "DC" prefix.
    Can not tell from your pictures if it has a trunk on the back which was the Master series 2dr Town Sedan (3,020 pounds). Without the trunk were the most popular 2 door Coach cars which came in Master series (2,995 pounds) and Standard series (2,565 pounds).
    Whatever it turns out to be, it looks like you got a great car. Enjoy
  20. Richard Head
    Richard Head
    You can tell a 34 master from a standard by the reveal on the back fender. The master appears to have a wheel opening that is too small for the wheel. The standard has about the same proportions as a similar year Ford. The difference is most evident on street roddy styled cars.
    The master was the only one to get the stainless strip on the edges of the horizontal hood louvers.
    By the look of the rear fenders, the dash and the hood chrome, I'd say that car was a master.
    Dave
  21. 37hotrod
    37hotrod
    Does NOBODY read the freakin' post BEFORE they start spouting off their expert knowledge??!!?? The OP already said that the frame has been hacked up and s***ched back together. Giving him wheelbase dimensions at this point is irrelevant.
    Judging from what is there on the body, as some have already pointed out, this is a '34 Master. It is essentially the same body as the '35 Standard, except for the rear panel ('35 is one big piece, '34 has a seperate tail pan piece), and the dash is different (but they are a direct bolt in swap).
    Either way, a very nice car. Check out my albums for pics of my '35.
  22. Gary Addcox
    Gary Addcox
    I had a '35 Standard 2dr in '67, which is very similar if not the same as your '34, and the ***le said 1935 Chevrolet Coach. It had twin elliptics front and rear like yours but the dash insert was in the center of the dash, unlike yours. It looks to be a Standard. Master Deluxes in '35 had heavy suicide doors and the top of the body was not so square. Hope this helps.
