History Dragster Chassis Engineering Company Inc
Discussion in 'Traditional Hot Rods' started by peckerwoodpicker, Oct 12, 2013.
  1. peckerwoodpicker
    peckerwoodpicker
    from Commerce
    Anyone ever heard of them? I ran across a set of blueprints for a 120" fed ch***is that had their company name printed across the top but there wasn't an address or any other company info available. Did the ch***is builders back then use an engineering company to design and print their blueprints? The ch***is looks like a mix of an early Ch***is Research K88 and a Lynndwood Eliminator.
  2. chickenridgerods
    chickenridgerods
    from DSM, IA
    "Engineering" isn't an uncommon word in the automotive industry, even if the company is not an engineering company. For example, the current "Ch***is Engineering, Inc." that sells ch***is parts for hot rods.
  3. Jimbo17
    Jimbo17
    Ch***is Research made ch***is for dragsters and also for other forms of racing. Take a look at the decal below and you will see what I mean.
    Jimbo
  4. jlhelm
    jlhelm
    from Minnesota
  5. peckerwoodpicker
    peckerwoodpicker
    from Commerce
    Here's a few pics of the ch***is in question.
  6. Koz
    Koz
    The plans you have are for Scotty Fenns' drag ch***is from 1958. It is actually a 108" WB rail. The frame rails themselves are 120". These plans are all over the place and I built mine from them. Rich Venza on here knows everything about them.
    There are a load of threads on here with the companys' history.
  7. peckerwoodpicker
    peckerwoodpicker
    from Commerce
    Thanks for the info! Do you have any pics of your rail posted here?
  8. speedbump
    speedbump
    i built my anglia bodied comp. coup using that blueprint. had to make alot of changes to get it cert for 7 50 et check it out under comp coupe dragsters mike
  9. peckerwoodpicker
    peckerwoodpicker
    from Commerce
    Wow! I've ran across that thread before but I never would have thought it was built off of the same blueprint. Do you have any pics of the ch***is without the body?
  10. Great to see a few folks have used the blueprints I've been selling for several years for more that wall hangings.
    Have one ready to mail @ $25.00.
  11. 63comet
    63comet
    What is the ch***is shown middle right in the sticker?
    Do you have more than just the drag ch***is blueprints available?
  12. Koz
    Koz
    My rail is currently in storage Because my shop is swamped with client cars. I'll have it out over the winter for some more work. I don't think I've ever taken a picture of it. I will say that mine won't p*** tech and as such is just a toy. I have a narrowed Ford banjo and a gutted 78 case, direct coupled in it so it is pretty much '58 typical. It kills me everytime I walk past it because I just want to sit in it and make motor noises.
    I will say that this is about the easiest ch***is you can build but it does take a bit of thinking, (not much), Because the plans are typical of the day and not very detailed, you must use your head a bit. The letter that comes with them from Scottys' engineer is worth the $25 alone!
  13. Dustin0330
    Dustin0330
    from Georgia
    I bought a set of these blueprints from Rich a few months ago and plan to build one ch***is off of the original plans and build another up to sfi specs to run a few events at the local track.
  14. speedbump
    speedbump
    sure here are a few of the ch***is alone
  15. Koz
    Koz
    Lots of changes there! I know you can't run anything without a double hoop anymore. I need to take some pics of mine which is built pretty much exactly like the plans show.
  16. Koz
    Koz
  17. Dustin0330
    Dustin0330
    from Georgia
    I would love to see a few pics! I'll definitely have to change the whole design but Im looking to keep the dimensions the same. I plan on using a Cadillac 331 engine 39 Ford 3 speed trans and Olds rear in the ch***is built exactly like the blueprint.
  18. Brad54
    Brad54
    from Atl Ga
    I'm going to use Rich's blueprint (framed and hanging on my wall right next to my computer) as the basis for the ch***is on the recreation of my uncle's '61-'65 Altered.
    The front of the ch***is is the same as the altered. I'll have to mount the rear axle under the frame, so that's a noticeable change. The front axle is a straight tube with no drop. I'll also need to completely redesign the roll cage, but that's okay.
    -Brad
  19. Koz
    Koz
    I'm no NHRA tech but I've seem to think that if you put a second hoop in front of the first a few inches as noted in the rule book and added the kidney bars which could be hidden by the body panels anyway it might be legal to about 9.00 or so. I have no idea. Maybe somebody on here knows how much you need to add to get it there. My rule book is several years old now and I'm sure things have changed a lot.
    As somebody else on here said, "The only time a double hoop looks good is when you're upside down". I'd probably be a lot more inspired to work on mine if I could do something other than burnouts in the street in front of the shop.
  20. ryno
    ryno
    As somebody else on here said, "The only time a double hoop looks good is when you're upside down". I'd probably be a lot more inspired to work on mine if I could do something other than burnouts in the street in front of the shop.[/QUOTE]
    finish it up and bring down to the hamb drags in joplin mo in aug. not an nhra sanctioned track, so you can run single hoop cars
  21. Dustin0330
    Dustin0330
    from Georgia
    I'm going to run a shoulder hoop from the firewall hoop to rear of the ch***is with back braces and kidney bars coming up from the main rails. Once I get that in place I'm going to build a five point cage off of the shoulder hoop. Hopefully that will get me past tech so I can run a few of the nostalgia events at the local tracks.
  22. Dustin0330
    Dustin0330
    from Georgia
    Are you going to have this ready for the Gear Jam next year?
