Technical Tudor roof fill panel
Discussion in 'Traditional Hot Rods' started by chiro, Oct 18, 2013.
  1. chiro
    chiro
    I did the search but didn't see a lot of choices
    Anybody fill a '30-'31 Model A Tudor roof with a junk yard roof? Pictures and donor roof make and model would be great.
    Thanks,
    Andy
  2. 5559
    5559
    from tn
    It may be hard to find now , but I always liked 59-60 chevy stationwagon ribbed roof
  3. bp1971
    bp1971
    from Fresno, CA
    My pop used a roof off of a late 80's early 90's pontiac station wagon.
  4. junk
    junk
    80's s-10 blazer made a nice filler for a local guy. Don't remember 2dr or 4dr.
  5. texkbc
    texkbc
    Heres mine, not a Model A but an example that might help. I made my roof /insert panel from a 59 Belair.
  6. 30tudor
    30tudor
    The 59-60 chevy wagon was the choice many years ago. I've used volare wagon (ribbed and non-ribbed are out there) tops and been quite happy, don't forget your tape measure.
  7. HOTRODPRIMER
    HOTRODPRIMER
    The early wagons and econolines was far game 10 to 15 years ago,but they have about dried up.
    How about measuring some of the mini vans,the junk yards are full of them. HRP
    fiftyv8 likes this.
  8. motoandy
    motoandy
    from MB, SC
    I used an astro van roof. Check out my album. I have a buddy that used a Nissan murono roof. Hit a pick a part. Think outside the box.the astro van roof I used was turned backwards on my model a vs the way it was on the van.
    fiftyv8 likes this.
  9. Using a 65 Valiant (Australian) stationwagon roof in my 28, it has two ribbed panels in it, looks cool as ****. I think mid 60's Plymouth roof's are the same, took me a lot of searching to find mine and im pretty sure the Plymouth equivelient is pretty ****** rare as well..
    fiftyv8 likes this.
  10. Harvey29
    Harvey29
    from kansas
    90s Jeep cherokee roof works pretty good
  11. scrap metal 48
    scrap metal 48
    Why not do something different.. $40 and 2 days for this one...
  12. I live in Colorado (hail country), there is a lot of new car dealerships that supply replacemnt part to body shops for repairs. Have you ever tried to send a roof panel across country? Usually they order 3 to get 1 desent one, I got a brand new roof for
    nothing, still in the box, with a rolled corner. The bodody shop refused the damaged
    part, the dealer claimed freight damage. I hauled it away for $0.00. Jeep Chrysler dealer,
    minivan I think, was nice to use NEW sheet metal.
    fiftyv8 likes this.
  13. Hot Rod Nut
    Hot Rod Nut
    just did it last week, used a 99 Chrysler carvan top and turned it around and it fit perfectly !I was even able to use the 3 ribs that came with it. cost was $50.00.I'll try op post pics. tomorrow night.
  14. I had this 28 body for a while. I'm not sure what they used but here's a pic.
  15. 28TUDOR
    28TUDOR
    I used a Astro van roof turned backwards and it fit pretty good.
    28
    Just Gary likes this.
  16. 33Tudor
    33Tudor
    Not a model A, but this one was filled with a 55 Chevy wagon roof.
  17. Just Gary
    Just Gary
  18. chiro
    chiro
    ^^^^Thanks Gary. Not only does it look great, but the tons of pictures and descriptions of the process are very helpful. I need some education on how a shrinking disc works, how to use one and where to buy one.
    Andy
  19. 29moonshine
    29moonshine
    90's suburban worked good in my 29 chevy sedan
  20. oneowner
    oneowner
    96 Lincoln Town car works good
  21. 55willys
    55willys
    70's-80's Volvo roof, the have the right crown and are made of good metal. I have also used 55-57 Chev station wagon roof with great results. Jim
  22. OLD HEMI
    OLD HEMI
    I used the roof off of a 93 Grand Cherokee. A nice fit.
    Lee
  23. olskoolrodder
    olskoolrodder
    this is the one I used...
    Howell Sheetmetal http://www.fordor.com
    part# SR-500 - ribbed
    or
    SR-500a - smooth
    basically center it, tack it in the front or back center and work your way around the car. I used a cutting wheel and cut it as I went around tacking it in place then went back and filled it all in. It over hangs at least 6 inches all the way around your opening. They also sell he visor and damn near other sheetmetal part you need. I did end up with some oil canning so you might need to spot weld additional sheetmetal on the bottom side to fix this problem. good luck
  24. olskoolrodder
    olskoolrodder
    would help if I actually read your complete question sorry... I heard Jeep grand cherokee roofs work great. That is what Ricky of Ricky Bobby Hot Rods uses.
  25. 1980's Granada wagon roof, works perfectly, turn it around backwards the front windshield on the wagon roof fits the rear curve of the sedan roof. Did it twice already. The wagon roof has chrome ribs, when removed the roof is not ribbed only a compound curve remains.
  26. snopeks garage
    snopeks garage
    from macomb MI
    i used a 94 caravan roof on mine. it was some work to fade out the ribs but it looks great
  27. snopeks garage
    snopeks garage
    from macomb MI
  28. snopeks garage
    snopeks garage
    from macomb MI
  29. last builder put on a caravan on my 30 and it fits good after doing some finishing
    ribs are cool on it
  30. 5559
    5559
    from tn
    Man , am I living in the past !!!!!
