Can I drill a 2" hole in a 5" C Frame?
Discussion in 'The Hokey Ass Message Board' started by DirtyDave, Oct 23, 2013.
  1. DirtyDave
    DirtyDave
    Need to drill a 2 inch hole in the center of the 5" C frame on my F100. I can weld in some reinforcement but do I need to? Truck is already built (in avatar) so avoiding reinforcement would be nice.
  2. Hnstray
    Hnstray
    from Quincy, IL
    Yes..............and I would not think a reinforcement is necessary
  3. randy
    randy
    If you do that, you'll only have an 1.5" on top & bottom of the hole (as I'm sure you figured out). I'd box it for sure and probably sleeve the hole between the two sides.
    It probably depends on where on the frame exactly the hole will be if it'll crack or not, but I wouldn't risk it.
    But...that's me.
  4. pitman
    pitman
    Could you drill the hole in a smaller diameter, and flange the hole (increasing the dia to 2") ?
    This would lessen the loss of strength in the C rail.
  5. 1955IHC
    1955IHC
    What is it that you are trying to do that you need to drill such a large hole in your frame? Maybe we can help you come up with some alternate ways of doing it.
    Sent via Illinois Bell Telephone Company's Car Radiotelephone
  6. DirtyDave
    DirtyDave
    I need to run the fuel fill through the frame for an under bed tank
  7. old round fart
    old round fart
    from Norman Ok.
    A 2" tube would be plenty big. Make it a 2 1/2" hole and you are safe.
  8. HOTRODPRIMER
    HOTRODPRIMER
    Why would you need a 2" hole for a fuel line?,,better yet can't you find a different section of the frame to do this?
    I have fuel lines on all my cars running down the inside of the frame. HRP
  9. Hnstray
    Hnstray
    from Quincy, IL
    Fuel FILL................... :D
  10. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Fuel tank filler tube, Danny.
    Where does the hole need to be in relation to your suspension pickup points? if there is little stress on the frame where you want to drill it, then there's no problem. But if it's a stressed member, I'd sleeve and box it to be safe.
  11. HOTRODPRIMER
    HOTRODPRIMER
    My bad,,looks like the new specks ain't a bit better than the old ones. :rolleyes: HRP
  12. DirtyDave
    DirtyDave
    Roughly at rear axle.
  13. VoodooTwin
    VoodooTwin
    from Noo Yawk
    And you're running leaf springs? If so, that's THE worst place to drill the hole. The bending moment there is at its greatest.
  14. DirtyDave
    DirtyDave
    yes, leaf, tend to agree with you.
  15. 1955IHC
    1955IHC
    I suppose if we saw some pictures it would be easier to understand why you feeling going through the frame is your best option.
  16. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Can you change the location of the fill tube to avoid this?
  17. DirtyDave
    DirtyDave
    It has been through the bed since 2007 because I couldnt stomach drilling a hole in a brand new steel fender. Now I can.
  18. bobss396
    bobss396
    You could do the hole, but weld a 3/16" plate on easiest-to-access side of the ch***is. I'd think of using a 4" x 7" piece of steel with a few rosette welds for good measure.
    Bob
  19. Why not do a c-notch ... inverted if you have to? Just did this to a f-100 frame. Is the pumpkin going to clear you tank?
  20. DirtyDave
    DirtyDave
    Sounds logical
    ...and I laughed out loud at your signature!
  21. DirtyDave
    DirtyDave
    Tank is between cab and rear on drivers side.
  22. Ole don
    Ole don
    How much space is between the bottom of the floor and the top of the frame? If its 1 1/2 inches, you could fab up a flat piece of metal with your two inch ends, sort of like a Nascar exhaust outlet. Make it fit available space. Add the overflow to the filler separately instead of inside.
  23. chopt top kid
    chopt top kid
    The bending moment of the frame depends upon the distance between the top cord (the upper flange) and the bottom cord (the lower flange). The frame doesn't care if it's got a 2" hole in it or not!!!
  24. blowby
    blowby
    from Nicasio Ca
    I'm no engineer but I would tend to agree. Don't many hot rod frames have such holes up front for lightening/looks?
  25. MP&C
    MP&C
    Dave, I'd sleeve it.. use welders leather to curtail any sparks from getting where they shouldn't. How's the Hudson coming?
  26. Joe H
    Joe H
    Oval pipe so the hole is wider then it is tall. You retain the strength in the frame better this way. With enough oval, you may be able to snake it over top of the frame.
    Joe
  27. tylercrawford
    tylercrawford
    from Buford, GA
    That would make me nervous
  28. readhead
    readhead
    Chopt top is right. Put a 2" hole and move on.
  29. 36fordguy
    36fordguy
    Drilling the hole changes the section modulus and the radius of gyration , Modify the top and bottom flanges to compensate for the hole in the channel 36fordguy.
  30. A Boner
    A Boner
    Why not neck down to a 1 1/2" filler tube? Then use a 1 3/4" hole saw.
    Or you could use a 1 1/2" hole saw, and weld in that short section of 1 1/2" filler tube, (thick wall), then box and weld that tube in for reinforcement. Then connect it up with rubber hoses and hose clamps.
