1" radius rods
Discussion in 'The Hokey Ass Message Board' started by jake_t327, Oct 23, 2013.
  1. jake_t327
    jake_t327
    from Custer, MI
    I have access to free 1" .120 wall DOM tubing, and I want to build a set of radius rods with it. I have searched on here, but can't find pictures of any that are made with 1". I know you usually use 7/8, but free is free. I can do all my own machining, such as making weld bungs, tapping in lathe, etc. Does anyone have any pics of 1" hairpins/radius rods???
  2. groundpounder
    groundpounder
    Don't see no reason why you can't!...
  3. FiddyFour
    FiddyFour
    um, i'd like to think they'd look just like the 7/8" ones, just 1/8" larger so a photo is going to do you very little good
  4. jake_t327
    jake_t327
    from Custer, MI
    Yeah, I just wanted to see if the diameter difference was noticeable, out of proportion
  5. FiddyFour
    FiddyFour
    only with a caliper
  6. bgaro
    bgaro
  7. tfeverfred
    tfeverfred
  8. Humph, I could tell jus at a glance, especially if it went by me at 80 MPH. :rolleyes: :D
    Form over function, build it beffier and tell everyone that is Race Chit if they ask.
  9. patmanta
    patmanta
    from Woburn, MA
    You could make the rods a little longer to balance out the small thickness difference.
  10. 1971BB427
    1971BB427
    from Oregon
    Put a little label on the tube that reads, 7/8", then nobody will know! ;)
  11. seb fontana
    seb fontana
    from ct
    My first thought...But get as much of the tubing as you can, nice stuff..
  12. fab32
    fab32
    can't beat free. Why not build a set and see how it looks? As long as whatever you do has sufficient thread engagement on the threaded parts I don't see why you shouldn't be good to go. Just make sure the clevises or heim rod ends you use are rated for the application.
    Frank
  13. Koz
    Koz
    Just remember the 1" .120 rods will not be any stronger than the 7/8" .156 that is typical. The thinner wall and larger diameter makes them slightly less rigid. I'd still use it and I don't think it will mean **** but you're going to have to make a bung and weld every tapped connection so be careful and make sure you trust you're welding.
    Question is, it that much extra work worth about $100 worth of 7/8" DOM to build a slightly weaker suspension component? My labor is worth something, and I'm sure yours is as well. I'd think about it before I jumped.
    (Doesn't mean I wouldn't scavenge all the tubing I could get though!)
  14. jake_t327
    jake_t327
    from Custer, MI
    well my time is worth something, the thing is, i work on 2nd shift, machinist. When i get my work stuff done for the night, i do my own projects, so i'm getting paid for it.
  15. 94hoghead
    94hoghead
    Do it, the price is right......
  16. Pewsplace
    Pewsplace
    Make a set and show us your results. We are waiting and all love "Free"....but remember sometimes "Free" is too much.
  17. snopeks garage
    snopeks garage
    from macomb MI
    haha:D
  18. jake_t327
    jake_t327
    from Custer, MI
    Alright, I am almost done with these now, I have some finish grinding to do, and have to install a threaded bung in the end for a tie rod end.
  19. butch27
    butch27
  20. ago
    ago
    from pgh. pa.
    Increasing the dia. of round tubing increases the strength exponentially. So a small increase in dia. even if it is thinner is stronger.
    Ago
  21. fortynut
    fortynut
    Looks like risers in an old Choppers Magaine article. Maybe with Big Daddy beaming on. Oh the days. Free ain't good, it's a lifestyle.
  22. RPM
    RPM
    1" is all we use on our radius rods. We use a .219" wall DOM. Seen way too many .156" rods fail, always on the rear end. Here is a pic of a set we made.
  23. badshifter
    badshifter
    Hmm. Spikes? I've seen this before somewhere....
  24. n.z.rodder
    n.z.rodder
    Yup, let's see what they're going on.
    Scotty
