Features 54 Chrysler New Yorker Custom
Discussion in 'The Hokey Ass Message Board' started by Hotrodhell35, May 23, 2013.
  1. Hotrodhell35
    Hotrodhell35
    Yes!
  2. Hotrodhell35
    Hotrodhell35
    John Walker, what grille pieces do you have?
  3. Bredlo
    Bredlo
    from Chicago
    Nice projects here - Hotrodhell, looking forward to seeing how yours progresses, and Schiestey, your frame in primer looks great. Hope you've gotten more done since October.
    We're putting a 5.7 Hemi in our '54 Chrysler - currently I'm swapping out the tail cone from the 4WD trans to a 2WD version. Supposedly it isn't that difficult, and will work much easier with an aftermarket wiring harness and ECU. Keep us posted if you follow up on that, I'll do the same.
  4. Schiestey
    Schiestey
    Finally got the wheels back under it, work was crazy and put everything on hold but hit it hard this weekend. Rolled the body into the garage this morning to start the hard stuff.
    Chris
  5. T-DeWitt
    T-DeWitt
    This New Yorker is sick as hell.I have been working on a 54 4 door just like yours.It is cool to see one customer out to give me some ideas.killer
  6. Paychobilly53
    Paychobilly53
    Any Chrysler New Yorker guys left?
  7. vwsherm73
    vwsherm73
    Hi, Mark here. I have a 53 windsor coupe and I'm planning on a small block and am having trouble with the exhaust and steering box on the drivers side. any help would be appreciated.
  8. George
    George
    On the 46-48 Plym/Dodge the engine gets move 1"-1 1/2" to the p***enger side. The drivers side ex. man. for the boxy early 70s 318 Dart curls right around the steering column. Should be similar to your situation.
  9. vwsherm73
    vwsherm73
    Thanks, I had been planning to move it some, enough to clear the steering arm. Some custom motor mounts and it should work. Thanks again.
