Starter and Solenoid
Discussion in 'The Hokey Ass Message Board' started by rabidmonkey, Oct 27, 2013.
  1. rabidmonkey
    rabidmonkey
    from NC
    I am in no way a master mechanic so be gentle with me. I just got a new starter and solenoid for my 52 Chevy and I was putting it together and hit a wall. As it sits there is no way the plunger will engage the solenoid. I have at least 3/4" between the shift lever on the starter and the plunger's bracket when the starter is fully engaged. Any suggestions?
  2. old round fart
    old round fart
    from Norman Ok.
    Looks like the lever arm is backwards. Did it come like that?
  3. rabidmonkey
    rabidmonkey
    from NC
    It did
  4. e1956v
    e1956v
    Alliance Vendor
    You're missing an extension piece on the plunger it was used for fine adjustment on the drive throw into the flywheel. It was held in place with an 8/32 bolt and nut to the plunger and to the shift lever with a pin and a cotter pin. Check around your work bench, if you can't find it I can send you one on Monday when I get back to the shop.
    Shift lever is not in backwards. Hope this helps.
  5. rabidmonkey
    rabidmonkey
    from NC
    Thank you! I double checked boxes and whatnot and no extension or the corresponding hardware at all. How much do you want for it?
    Sent from my SAMSUNG-SGH-I337 using H.A.M.B. mobile app
  6. e1956v
    e1956v
    Alliance Vendor
    Nada, its a HAMB pay it forward PM me your address or email it from our website.
  7. e1956v
    e1956v
    Alliance Vendor
    Plunger to lever extension sent USPS let me know how it works.
  8. rabidmonkey
    rabidmonkey
    from NC
    I cant thank you enough.
  9. rabidmonkey
    rabidmonkey
    from NC
    Sorry it took awhile to get back to you I was out of town and when I got back the extension was waiting for me. Thank you again. I got everything back in the car but cant get anything more than a few clicks after trying to start it.
  10. squirrel
    charge the battery? check the cables?
  11. e1956v
    e1956v
    Alliance Vendor
    Like squirrel said, check battery and cables check and clean (file) grounds. Also check for voltage drop on the switch wire to the starter solenoid. You can adjust the shift lever adjustment a little and make sure the solenoid is pushed all the way forward before tightening the four mounting bolts.
  12. 302GMC
    302GMC
    from Idaho
    Stab in the dark here ... new solenoid is marked 12V. Is the '52 also 12V ?
  13. rabidmonkey
    rabidmonkey
    from NC
    Ended up being a bad battery cable. Shes now running for the first time in months. Thanks for all the help
  14. e1956v
    e1956v
    Alliance Vendor
    Glad you got it figured out now put some miles on it!
