Projects 1953 5 window 3600 into 3100, frame swap build started today
Discussion in 'The Hokey Ass Message Board' started by bbp53, Oct 23, 2013.
  1. bbp53
    bbp53
  2. The37Kid
    The37Kid
    Get me up to speed here, is the 3600 far more than a stretched ch***is and bigger axles? Bob
  3. lango
    lango
    from Georgia
    Dig the continental kit step bumper.
    (Kiddin')
    Sent by a Western Electric Dial-up Modem
  4. bbp53
    bbp53
    I believe the frame is narrower in the rear on the 3600 and beds longer on the cab end, and 8lug instead of 6lug. Not much more diff than that though. Oh and in later yrs they had they larger 6cyl engine but in 53' the 3100 and 3600 had the same engines.
  5. bbp53
    bbp53
    Lango, im diggin that bumper too because it saved the rear fenders from damage as it wrapped around them. Shocked there was no rust behind there! But it was a california truck and been tucked away here SC for the half its life.
  6. bbp53
    bbp53
    Im sorry, i shouldve added that im swapping an s10 frame under the '53 , shortning the original bed / running boards. Im using as much original sheet metal as possible. Using s10 steering colum and brake system. And fabbing my own cab/bed mounts.
  7. bbp53
    bbp53
  8. Skidder
    Skidder
    Were are you at in SC? I am located in the Simpsonville area. I to am working on fixing up a 50 Chevy 3100....I decided to keep my stack frame and just add a Jag front and rear suspension. Best of luck with your swap....
  9. Skidder
    Skidder
    I just noticed we are both FNG....I have been here for years just don't post much...:D
  10. bbp53
    bbp53
    Im near columbia.sc area, sounds like a nice build plan you have going on yours, i worked most the day on mine today. Tryn to load pics but want load for some reason! Good to hear of a fellow member close to me with same model truck and interests in them. Do you have any pics posted of yours?
