Projects 64 old 394, is it worth getting for scrap price.
Discussion in 'The Hokey Ass Message Board' started by bigvinny, Oct 21, 2013.
  1. bigvinny
    bigvinny
    My friend was gona s**** a 61 olds 394 with 4 barrel intake. said it ran when he pulled it out of his parts car. missing valve covers but other wise complete. do you think its worth grabing for future projects? what kind of ******s work with these? thanks
  2. bigvinny
    bigvinny
    I can also get a 331 Cadillac bare block no cracks. would it be worth grabing also?
  3. texasred
    texasred
    from Houston
    If you have the room to store them, why not
  4. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Well, they sure as hell aren't going to make any more of them, so.....'61 was the year that Olds redesigned the exhaust ports, and they're quite large. As said, if you've got a place to store them where they won't deteriorate, get 'em.
  5. bigvinny
    bigvinny
    I agree, some one may need the caddy block also.
  6. Yep I would grab it they are getting hard to come by and while they are not the prettiest engine that are pretty stout and ad a little pizzaz to your rod.
    By the way it will have a forged lower end and if it is a 4 bbl car it will be about 10.5:1 from the factory.
  7. Paul
    Paul
    Editor
    ***le of thread says '64
    text says '61
    which is it?
  8. BobF
    BobF
    from Poway, CA
    They are getting harder to find. Check the cast number on the heads above the back exhaust port and whether the middle port has 2 or 3 bolts. Olds heads are rather unique because they all inter change bolt hole wise, not necessarily advantageous (394 #23 on a 303)
    Save the 4 brl manifold for sure, nobody is currently making a alum 4 brl for any of the 3 deck height blocks far as I know.
    The crank can be turned down to fit a earlier block, as previously stated all the Olds stuff was forged. The cam was unique in the 371/394's it's slightly longer.Worth not s****ing IMHO.
  9. My 2 cents.
    Had a 63 Olds 88 394 "Ultra Hi Compression" back in 72
    Incredible torque, at incredibly low RPM.
    Perfect for lite hot rods.
    Always good to have!
  10. bigvinny
    bigvinny
  11. d2_willys
    d2_willys
    from Kansas
    bolt on transmissions: dual range hydro, dual coupling hydro, roto 10 (slim jim), manual transmission. Others will need adapter.
  12. Unfortunately, they don't have a ton of transmission options available, and some of what are available aren't "well loved". The engine more than makes up for that problem though. I have a 394 in my '64 model 98 convertible, and it is surprisingly fast. It will easily hang with the 327 in my SS Impala, a much smaller car.
  13. 22george
    22george
    from ohio
    ditto grenade inspector
    I had a 63 super 88 394 4 barrel high compression and it hauled ***
