Can a 200 4R easily replace a 350TH
Discussion in 'The Hokey Ass Message Board' started by Jalopyrama Mike, Oct 28, 2013.
  1. Jalopyrama Mike
    Jalopyrama Mike
    I have a 350 turbo ****** in my '47 Ford convertible and am about ready to install a new engine and want to swap out the 350 for a 200R4. Any changes to mounting or fitting needed?
  2. takid455
    takid455
    bolts in. Trans mount needs to be moved rearward. need shifter cable brackets for a 200. hook up wire to brake light switch for torque conv lock up disengage. Hook up TV cable and properly adjust. This is important.
    If not mentioned, you can use your 350 stuff.
    enjoy
  3. wheeltramp brian
    wheeltramp brian
    you will have to move the trans mount back about 4" i think,but everything else lines up
  4. OldFord39
    OldFord39
    from Monroe, Wi
    The transmission mount sits back further than the th350; the 350 had 6",9" or 12" extension housings if your 350 has a 9" extension you may not have to shorten your drive shaft. the 200-4R uses a TV cable, geometry and adjustment of cable are critical to making the transmission live. Included is an illustration of length and transmission mount location.
  5. ebfabman
    ebfabman
    Good upgrade. Once you get it all adjusted, you'll love it.
  6. Cerberus
    Cerberus
    I replaced the TH350 in my GM pony car with a 200R4. Setting up the TV cable is easy. Cross member I had to replace with a BowTie Overdrive tubular cross member. Did not have to change the length of the driveshaft. Readjusted the B & M Quick Silver Shifter by pulling a pin in it and adding the Shift indicator plastic strip with one that included the OD position. Again, very easy to do. Good luck. You will appreciate the upgrade.
  7. saltflats
    saltflats
    from Missouri
    Install a Transgo kit and adjust as prescribed.
  8. mgtstumpy
    mgtstumpy
    Any help?
  9. choptop40
    choptop40
    i agree , excellent choice , better fuel economy to boot
