Projects Who's running a Ford Y Block? Gonna build one, gimme some tips on what to/not to do.
Discussion in 'The Hokey Ass Message Board' started by 69supercj, Oct 25, 2013.
  1. 69supercj
    69supercj
    Like the ***le says, I'm wanting to build a 292 for my 62 Uni but I don't know much about these motors other then I like 'em cause they're different. Just wondering if there are any perculiarities which I'm sure there are, about these motors for me to look out for. Not gonna build a real thumper, probably just a nice 292 with maybe a 3 deuce setup and MAYBE a T-5 5 speed. Thanks for any and all help and info.
  2. JeffB2
    JeffB2
    from Phoenix,AZ
  3. 2racer
    2racer
  4. crminal
    crminal
    Go for it! New to Y-blocks as well. Follow the links above and use the search feature here, you will be well on your way.
  5. Speedmaven
    Speedmaven
    Don't line up the cam and crank gear marks like a SBF or scrub motor, 12 link pins between them, will be closer to 3 o`clock on each mark..
    Like above, http://www.y-blocksforever.com/ is my favorite Y block site.
  6. 57Custom300
    57Custom300
    from Arizona
    Just follow 2racers posted links. Everything you need to know will be there.
  7. birdman1
    birdman1
    I used to build a few 312's. be sure to use the 312 heads, and the high ratio rocker arms. I can put big valves in the heads if you want. The 312 heads flowed better than the 283 chevy power packs. i could easily whip any 283 around with my 292, 1956 cheap hardtop with a 4.11 rear and overdrive. had 2x4's(factory), a Mallory dual point, and duals. Have fun.Henry
  8. Talk to Mctim, Ted Eaton and Keith Cornell here on the board.
  9. teddyp
    teddyp
    2x that they help me alot with info on my y-block
  10. Tedd
    Tedd
    Here's the link to the common ***embly errors compiled by John Mummert. The only one I'll add to the list is watch out for too long of a 5/16-18 bolt attaching the oil pump through the block as if too long, it can break into the oil pump housing.
    http://www.ford-y-block.com/***emblyerrors.htm
  11. 1954Bill
    1954Bill
    from Long Beach
    John help me a lot when I put my Y/block together :D
  12. gibraltar72
    gibraltar72
    from Osseo Mi.
    Don't put the cam in first!
  13. Buy a good engine stand
