Features Vintage Stock Cars for the street...
Discussion in 'The Hokey Ass Message Board' started by Conder, Oct 3, 2008.
  1. Daddiojoe
    Daddiojoe
    from Austin, TX
    50 Dodge----That is awesome. Needs a big 42. Lee Petty won races in a 51, not sure about other years.
  2. 53olds
    53olds
    Here's a 63' Galaxie my girlfriends Uncle built. It used to be raced back in the day and he restored it into a street car but he has another one thats still a race car.
  3. Jondefender
    Jondefender
    Been driving this '65 for a few years and decided to give it the "stock car" look. 352, 5spd, Crown Vic cop car sway bars.
  4. budd
    budd
  5. vetteson
    vetteson
  6. hotrod bob
    hotrod bob
    I know that car! :)
  7. jvolgarino
    jvolgarino
    How long would it take you to build your dream car? Keith Larson of Cedar Falls, Iowa took 18 years.
    1981 Camaro Street Legal Dirt Tracker
    A true gearhead can point to some seminal moment when he or she was struck by an unexplainable epiphany. That moment when you knew things had changed and suddenly every motorized creation became a point of interest. It was that one time when you realized you’d never again look at any vehicle of transportation, play or collectability without the quickening of your heartbeat and a shortness of breath.
    For Iowan Keith Larson, it was a walk past a car dealer’s lot in the late 1960s where a ’64 Chevelle dirt track car resided, painted up in red, white and blue and sporting all the proverbial race car stuff…full roll cage, stinking big tires, cut out fenders.
    The race car didn’t make Larson want to go racing, however. His young mind thought, “Wow, wouldn’t it be cool to drive something like that on the street?” Speed forward 44 years and Larson has his “mechanical symphony on wheels”, but it was an 18 year journey only a gearhead could understand.
    A race car on the street? Yup, it’s been done many times, but probably not with the attention to detail and the fine points Larson has invested in this one. He began the project once, ran out of space and patience and s****ped the project, except for some key components. It was in 1994 the project took hold and Larson started in earnest the quest to make this dream a reality.
    “I tried to take a retired ’77 Camaro dirt car in 1986 and convert it to street use,” he explains. “I knew the car, found it intact in a junkyard and tried to mate a 1970 Camaro SS body to the ch***is.” Larson found the task daunting at best and a family move to a different house and smaller garage pretty much killed the attempt.
    “I kept a lot of parts of that race car, but couldn’t quite get the job started the right way,” he says. In ’94 things changed again, this time in favor of another attempt at “the dream”. Larson bought 400 feet of steel tubing. If he couldn’t adapt a ch***is, he’d just build one. Of course, he’d never built anything like this before, but that fact wasn’t going to stop the effort.
    Bolting two I-beams to the floor of his garage, Larson built a jig for the foundation of the car. With help from a friend he drew up exactly what the ch***is would look like with full dimensions and hung the drawing on the back of his walk-in garage door. “I used the sub frame from an ‘81 Z-28 donor car I bought from a neighbor for $250 and built a full perimeter frame of 2x3 .120 gauge wall tubing,” he describes. “Once that was in place I went after the rest of the cage.”
    Endless brackets, mounts and configurations followed to engineer what Larson had essentially dreamed up in his mind and on paper. “I had to figure out how to make everything work together and spent nearly 6 years working on it (the ch***is), one piece at a time,” he says. When you look over the car, you can tell he literally planned every single connection, weld and bend after a lot of thought.
    “I probably have about 3000 hours in the car and half of that time was spent just trying to figure out what to do next.” Working with no instructions other than his own ideas, Larson, in cl***ic gearhead fashion, made use of basic tools on a limited budget. “I bought a used MIG welder, chop saw and angle grinder,” he says, “and eventually had to have a mechanical tubing bender, an imported box and pan sheet metal brake and I managed to borrow a bead roller.”
    Describing six years of labor can’t handle what had to be thought through every time Larson approached the ch***is for another session. But he did get it rolling and on the ground. “I knew some people over at Performance Bodies in Cedar Falls who could help me with the next step so I headed their direction.”
    Performance Bodies is a local company started in 1981 by racer Scott Braun who was a dirt tracker himself on the local scene. He discovered he could build, and sell, aluminum body panels to racers like himself. The company has grown to nationwide size, today handling all types of body parts and other components to keep racers supplied throughout both the racing and building seasons.
    The rolling ch***is was twice taken to Performance Bodies where fabricator Jeff Higgins began forming up the body. The car was delivered in both 2002 and 2008 so Higgins could mock up panels that eventually ended up in the Performance Bodies catalog so Larson’s Camaro became a prototype test bed in addition to slowly making it’s way to completion as a street driven vehicle.
    In addition to the 90 pound aluminum and fibergl*** body produced to cover the ch***is, the original donor car provided a myriad of pieces including the front nose which had to be channeled and set back in order to arrive at the proper dimension. The car’s windshield frame and upper dash panel (including the car’s VIN plate) were incorporated along with lights, horn, turn signals and 4-way flashers.
    The pre-painted panels produced by Performance Bodies kept the total paint and powdercoating budget at less than $600 for the vehicle which tips the scales at about 2900 pounds. Including tools purchased for the project, Larson figures he’s into the car for $15,000. “Spread over 18 years I figure that’s not too bad considering what I ended up with,” says Larson. “The car drives great, rides good and corners like a race car is supposed to and I’ve not even done any adjustments yet to the suspension.”
    All of the fabrication inside the car came from Larson’s own hands. “My Dad was a John Deere engineer,” says Larson, “and he grew up on a farm in Kansas where there wasn’t a corner parts store where you could find what you needed. You simply learned to make it.” He obviously inherited that particular fabrication gene when he used galvanized steel for the firewall, transmission tunnel and exhaust heat shield that blocks the 3” chambered exhaust that is snaked through the door panels.
    “My family included a bunch of uncles who loved nothing less than flying down dirt roads as fast as they could. I remember that well.” Larson’s family landed in Cedar Falls, Iowa when his Dad went to work for John Deere. “I started at John Deere myself right out of high school, but military service (in the Navy) called and I went to California which was car heaven for me.”
    Larson worked on a series of his own rides during his Navy stint as an electrician including Corvettes, a Chevelle SS and a 1959 Mercedes. “We could work on cars at the base hobby shops for 50 cents a day,” he explains. “That pretty much got me hooked into all kinds of vehicles.” Upon discharge Larson headed back to Iowa, eventually taking a job again at John Deere, retiring after 37 years as an electrician. Now he runs a custom wheel and tire service in town and drives the Camaro to local area car gatherings when he can.
    “I have about 200 miles on it,” he says and explains his need to test all the car’s systems before he embarks on anything that is much more than a safe towing distance from home. “I know the car is right, but it just takes a bit of time to get used to how it functions on the street.” In the meantime Larson gets to hear that “mechanical symphony” whenever he wants. Here’s hoping we get to see a lot more of it at future events and gatherings. It’s guaranteed there won’t be anything else like it when he arrives.
    The Details
    Engine—In 1989 Larson found a zero mile 1970 350 LT-1 crate engine that he stashed away for future use. The 11:1 power plant was eventually torn down for new bearings and rings due to its long hibernation, but Larson says the original ***embly lube was still in place. The engine is essentially stock but he says it falls easily into the 400 hp range. Fuel delivery is handled by a 750 Holley with Edelbrock Performer RPM Air Gap intake. Stock plugs are fired by MSD ignition system. Installation included a 10” setback in the ch***is using a mid plate mount and the engine is cooled via an AFCO aluminum radiator and electric fan.
    Transmission—1967 Muncie with short throw Hurst Super Shifter.
    Rear end—1974 Frankland quick change that came from the original dirt track car running 3:85 gear currently but Larson says a 4:47 he has for the quick change is a lot more fun. He also has 5:31 and 6:13 ratios he wants to try out. The rear is suspended using AFCO 194lb Chrysler springs and with an upper shock damper, again using the dirt track car’s original set up.
    Steering—The dirt track car’s 12:1 box and linkage uses 1976 Impala spindles and lower A-arms. AFCO upper A-arms with 750lb front springs and weight jacks round out the front suspension.
    Brakes—Pedals for brakes and clutch are Wilwood with pressure gauges, balance bar and proportioning valve handling 1969 Impala calipers and rotors. The car uses a Jamar hydraulic park lock.
    Exhaust—Again borrowing from the car’s heritage, the headers are Schoenfeld dirt trackers turned upside down to allow the 3” Sweet Thunder chambered pipes and mufflers to be run inside the door panels on each side, exiting outside just forward of the rear wheels.
    Wiring/electrical—Ron Francis provided the harness with the front wires run inside the frame and all other wires (including battery cables) encased in ½” air hose for protection. Stock headlights and turn signals are used in addition to the rear lights which are LED semi truck. Auto Meter gauges provide all needed information from the custom built dash panel. A kill switch is mounted within reach of the p***enger.
    Wheels—15 x 10 Coys all around with 275/60-15 Firestone Indy 500s.
  8. keithv
    keithv
    from Flordia
    This is a true story;
    I was a young snot-slinger, about 11 or 12, riding a Sting-Ray & hang with my buds at the 7/11. Up comes a 64 0r 65 Falcon done up like a stocker, we are all drooling over this thing and asking lots of questions. The owner tells us that he built it for the local oval (Hialeah Speedway) but decided that it looked to nice to take it on the track & get it trashed, so he put the gl***, lights, ect. back on, re-taged it & had one bad-*** little runner. One of those cool car memories that gets tattooed in your brain, even after 45 years!
    (with that said, allow for lost brain cells)
  9. Augustine
    Augustine
    My uncle owns a factory built 63 galaxie stock car. It basically sits pretty in his barn now. It get's out onto the road maybe once a year for a show. Other than that it's just another one to his collection. It's so killer to see true survivors though.
  10. hotrodMarv
    hotrodMarv
    from Germany
    my dad´s old original 32 five window coupé stockcar!
    and a 41 ford COE! nice one :) [​IMG]
    Toms Dogs, ring gap and Animal like this.
  11. George
    George
    Nice! Now do your Intro before the Forum Police get ya!:)
  12. jmh
    jmh
    SWEEETTT!!! John
  13. bumpybigblok
    bumpybigblok
    from Midwest
    I raced this Camaro in the 90's, then recently sold it and converted it back to a Street Machine. The new owner has been running some Auto Cross events with it and doing quite well.
  14. edweird
    edweird
    my newest project.
  15. Jimbo17
    Jimbo17
    One of the best parts of my business is meeting and talking with so many different old racers who call looking for old decals for projects they are working on.
    The other day Jimmy Kitchens called looking for decals from the 60's for a stock car he is building in memory of his famous father who years ago was part of the Alabama gang. His father owned a speed shop in Alabama for years and he raced stock cars with all the big names in the business back in the day.
    Jimmy also raced in the Nascar Craftsman Truck Series in the 90's
    Today Jimmy is the spotter for Ryan Newman and also for Ben Kennedy in the K&N Series and also some truck races.
    I meet some very interesting people who really have interesting stories to tell.
    Jimbo
  16. nash510
    nash510
    from Vista, CA
    A couple of shots taken at a recent cruise.
    jebbesen likes this.
  17. Animal
    Animal
    Nash, I love that Falcon! That has a great stance.
  18. nash510
    nash510
    from Vista, CA
    Thanks Animal. Stay warm there in CO. I don't miss that nonsense at all.
  19. japar
    japar
    from Seekonk Ma
    After seeing the Vintage Trans Am cars run at Lime Rock Park I'am going to make my old Camaro a Penske/Sunoco clone. Being an old drag car it already has a roll bar, fuel cell, race seat, no interia heck I am half way there. Instead of running a BB 4-speed I am going SB 302-305-307 with a 5-speed. I hope to beat that "FRIGGIN FALCON" that everyone has been chasing
  20. texoutsider
    texoutsider
    from Frisco, Tx
    The "Hunchback of Holly Farms"
    Indeed Jr's car.
  21. 1934coupe
    1934coupe
    This one pulled into Mills Mansion this year. First time I've seen one on the street.
    Pat
    Animal likes this.
  22. Pushman
    Pushman
    I have a FB page called Street Legal Oval Track Cars it covers everything from Street Legal Dwarfs & Legends to Street Legal Indy Cars, plus we have restored race cars (Not Street Legal), Street Legal Bumper Cars, & a page called Odd & Bazar!!!!! Hope some of you will come over & take a look & maybe join. We have over 450 photos in 12 photo albums.
    https://www.facebook.com/groups/161176690732893/
  23. Pushman
    Pushman
  24. AmericanPinups
    AmericanPinups
    from Dallas, TX
    Here is my Starlifter. I drove it to the Lone Star Round Up a few years back, it lives in TN now.
  25. Pushman
    Pushman
    They stick well but they come apart fast, not recommended!!!!
  26. Pushman
    Pushman
    For Street Tires the best ones we found were the Hoosier Street Sportsman, they look like a dirt tire but are DOT approved & come in various widths & sizes. Gives the car a mean look too!!!!
  27. Pushman
    Pushman
    For Street Tires the best ones we found were the Hoosier Street Sportsman, they look like a dirt tire but are DOT approved & come in various widths & sizes. Gives the car a mean look too!!!! <!-- / message -->
  28. Animal
    Animal
    Does Hoosier still make those? I've been looking, but can't find any mention of them on the 'net.
  29. Pushman
    Pushman
    This is the # to Hoosier West. 1-559-485-4612, we ordered through a speed shop, we got ours about 2 weeks ago.
  30. AHotRod
    AHotRod
    This car has "The Look"!
    I'd be interested in seeing more pictures of it and some information.
