Technical steering box I.D.
Discussion in 'Traditional Hot Rods' started by bgaro, Oct 31, 2013.
  1. bgaro
    bgaro
    i picked this up and have no idea what it's from. was sitting on an old drag car ch***is, it reads T13481FC. it's froze up, but if it's worth resurrecting i'll use it for my T project.
  2. 31Apickup
    31Apickup
    Looks pretty light duty like a golf cart. My dad has one similar, i wouldn't use it on a car.
  3. bgaro
    bgaro
    it's fairly small, the case looks aluminum too. i was interested in it for a dry lake style '23 model T (light weight). i thought jeep at first.
  4. Dale Fairfax
    Dale Fairfax
    It's a Ross-built for something light like an industrial truck (one used inside a factory) or maybe a golf cart. Ross made steering gears for everything imaginable-even combines. Probably would have worked on a digger but definitely not recommended for the street (unless it's a Crosley). They are a ***** to reverse (if needed).
  5. bgaro
    bgaro
    yup, you guys are right. looks like it's for a little tractor called a power king. thanks for the input, i appreciate it very much.
