Identify 9" rear
Discussion in 'The Hokey Ass Message Board' started by coupe33, Nov 1, 2013.
  1. coupe33
    coupe33
    Some time in the past 20 years I aquired a 9" rear all set up with brackets installed for a 4 bar, I only have the housing and 4 bar no axles or pumpkin. The rear is 52" wide so how can I possibly identify what it is from? How do I identify the axle offset? I was hoping to use it in my T coupe. Any help would be greatly appreciated.
  2. kuhn1941
    kuhn1941
    I installed a curry 9" axle for our foxbody mustang . It measured 52 1/4" end to end of the housing itself no backerplates or axles. If you google search foxbody 9" rear. That should give you measurements for the 4 bar hook up and total specs. Goodluck
  3. 57 HEAP
    57 HEAP
    If you know the housing is 52", then I will ***ume you know how to use measuring instruments. If that is the case, you can determine the axle shaft length and bearing bore size. The year and model really doesn't matter.
    The ring gear is in the left side of the housing as viewed from the rear. This will likely be the short axle shaft.
  4. Xdrag48
    Xdrag48
  5. TagMan
    TagMan
    <TABLE bgColor=#ccffff border=2><TBODY><TR><TD width=250>YEAR/MODEL (flange to flange)</TD><TD width=20 align=center>46"</TD><TD width=20 align=center>50"</TD><TD width=20 align=center>52"</TD><TD width=20 align=center>54"</TD><TD width=20 align=center>56"</TD><TD width=20 align=center>57"</TD><TD width=20 align=center>58 3/4"</TD><TD>60"</TD></TR><TR><TD>'66-'77 BRONCO</TD><TD align=center>X</TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD></TR><TR><TD>'58-'60 THUNDERBIRD</TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD></TR><TR><TD>'57-'59 FORD/EDSEL</TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD></TR><TR><TD>'63-'69 FALCON</TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD></TR><TR><TD>'63-'69 COMET</TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD></TR><TR><TD>'63-'65 FAIRLANE</TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD></TR><TR><TD>'65-'66 MUSTANG</TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD></TR><TR><TD>'67-'70 MUSTANG/COUGAR</TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD></TR><TR><TD>'66-'69 FAIRLANE/CYCLONE</TD><TD>
    </TD><TD>
    </TD><TD align=center>X</TD><TD align=center>X
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD></TR><TR><TD>'70-'71 TORINO/CYCLONE</TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD></TR><TR><TD>'71-'73 MUSTANG/COUGAR</TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD></TR><TR><TD>'60-'64 FORD/MERCURY</TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD align=center>X</TD><TD align=center>X</TD><TD>
    </TD><TD>
    </TD><TD>
    </TD></TR><TR><TD>'61-'67 THUNDERBIRD</TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD></TR><TR><TD>'58-'72 F-100 PICKUP</TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD></TR><TR><TD>'73-'90 F-100 & F-150 PICKUP</TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD></TR><TR><TD>'70s LINCOLN TOWN CAR</TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD>
    </TD><TD><CENTER>X</CENTER></TD></TR></TBODY></TABLE>
  6. Hunter73
    Hunter73
  7. xwing01
    xwing01
    as 57 heap said, the specific source of the 9" isn't near as important as the dimensions, considering most parts are interchangeable as well as the strong aftermarket/custom length following.
  8. Oldmics
    Oldmics
    I like Tagmans chart BUT there is no mention on 57 Mercury that also was 52" wide like the Fords.
    I am curious to know if 58 and 59 Mercurys were also the same?
    Oldmics
  9. studedudeus
    studedudeus
    S**** it!! Go get a 8.8 explorer axle with disk brakes. Straight tubes, stronger shafts, Limited slip. You can get one complete for less than $200. Put your 4-bar on that.
  10. stillrunners
    stillrunners
    from dallas
    nice stuff.... thanks
  11. 32 hudson
    32 hudson
    ED I think you must have an 8" small bearing 28 splne housing according to chart width and years which apply for that width. I think the offset would be 2 1/4 inch. unless the housing is not stock and has been narrowed. I will try to check the info I have.
    Steve
  12. coupe33
    coupe33
    Steve,
    Your right it could be anything. I have a 57 truck rear and I know that it is 3:50 gear real narrow compared to the others in the stack. I will just drag it in and use it for mock up then build the frame around. I have a pumpkin that is posi and I will check some of my other housings. I never used a 4 bar set up so I will stick with the ladder bars. No need to go a different direction at this point.
    Ed
  13. jfreakofkorn
    jfreakofkorn
    i would say, its hard to tell w/o it being complete ...
    the 8" that i have laying around ( which is complete down to the tag on the housing ) came out of a late 6os vehicle ( and and decoded it awhile back and yet to find something to put it in tho ) ....
    better off finding something that doesnt involve to much it cost ....
    s**** yards yield alot of possibilities ... IMO
  14. coupe33
    coupe33
    I really wish that there were s**** yards. Well Steve is right it is a 8" I put a 8" pumpkin on the housing and it lines up perfectly. Too bad I plan on a bit more power than the last one. The center chunk is a 2:66 posi center but I don't think it would survive. Thanks to all for the help.
