Spot Welder Tong Question
Discussion in 'The Hokey Ass Message Board' started by grapp, Nov 1, 2013.
  1. grapp
    grapp
    I'm considering buying a spot welder, and have a question about tong lenght, does it cut down on welding capability/capacity if I make or buy longer tongs? They look like solid copper bar is that correct?
    Thanks!
  2. The decrease in pressure is probably more of a issue than the loss of current with that style of welder. You could probably go a little longer, but not much.
  3. 73RR
    73RR
    What lengths are available on the open market? Let that be a guide. Yes clamping pressure will affect weld quality as much as squeaky clean parts.
  4. grapp
    grapp
  5. Petejoe
    Petejoe
    from Zoar, Ohio
    The industrial type spot welders have a water coolant system that runs right into the tips. Yes they normally are solid copper at the very tip but the industrial types have a water p***age area in them.. FYI. It is extremely important to have both sheets of metal spotless. No rust, scale, and importantly no oil. That is the biggest problem you will run into when spot welding.
    Don't even think of using these on old metal. If you intend of spotwelding old metal. save your money.. drill a 3/8 hole in one sheet, clamp it together and fill the hole with mig weld.
  6. BobF
    BobF
    from Poway, CA
    Don'y know much about spot welders, haven't used one since high school, long ago.
    I did see a home made version on u-tube using a micro wave transformer which can be built for $20 or less. Do a search on it. Might check it out and see if will do what you need.
  7. grapp
    grapp
    Tinbender, No I would buy a used Miller that was just a good picture and about the same size as the Miller hand helds
