Technical rewiring question?
Discussion in 'The Hokey Ass Message Board' started by mikhett, Nov 3, 2013.
  1. mikhett
    mikhett
    from jackson nj
    Im rewiring my 56 ford victorias dash and i have one power wire thats gotta go to 5 gauges.Its the instrument panel light wire and its gotta go to all 5 gauges.what kind of connector can i use ?1 wire in and 5 wires out.Rebel wire is cosed on sunday.Thanks
  2. jjbubaboy
    jjbubaboy
    Hey Mikhett,
    Best bet would be to use a terminal block. Then attach all gauge wires and power to one spot.
    Jeff
  3. squirrel
    solder...heat shrink tubing....
    Robdski and jimmy six like this.
  4. 325w
    325w
    Just tie the others to one main lead.listen to Squirrel he speaks the truth.
  5. Zurekbrau
    Zurekbrau
    Yep Squirrel is right.
  6. 53 sparky
    53 sparky
    Yup.
    Robdski likes this.
  7. rfraze
    rfraze
    Run power wire to one gauge, cut and strip a piece of same color wire long enough to reach next gauge, crimp both wires in the first connector, and so on down the line of gauges. Sometimes you can even use a slightly larger, same color wire to reach the first connection point. I would suggest insulated connectors for power wires. Safety third. Hope that helps.
  8. HOTRODPRIMER
    HOTRODPRIMER
    There you go,,that's the way I did it when I made my own wiring harness. HRP
  9. Model T1
    Model T1
    This is the cleanest safest way to do it. Safty first.
  10. mikhett
    mikhett
    from jackson nj
    Daisy chain.Got IT! Thanks
  11. aircoup
    aircoup
    just did my guages that way ,, worked great
  12. 39 Ford
    39 Ford
    That's a great idea but its a little like the old Christmas tree lights one goes out they all go. I used a terminal block on mine, to each their own.
    Just Gary likes this.
  13. roundvalley
    roundvalley
    Daisy chain the grounds also.
  14. Leviman
    Leviman
    One of the gauges, or one of the wires? If a gauge fails, unless it fails shorted, it won't bring the rest with. If a wire fails, you have larger problems. Also, christmas lightsare wired in series, this is parallel.
  15. 1971BB427
    1971BB427
    from Oregon
    When I did my gauges I put three wires together with solder and heat shrink. One in and two out. This made a cleaner setup that put one wire to each of two gauges, plus a third to the next gauge. Once I had all the gauges daisy chained this way I took the last end to the common feed.
    This is the cluster I built up to go into my '63 Falcon:
  16. Engine man
    Engine man
    from Wisconsin
  17. Here ya go, I also grouped the wires for each gauge and function, ( turn, hi beam, etc. that way you can unplug the gauges to work on them if ever needed. You can see the ground wire (green) daisy chained, as are the lights power wire. All the methods posted here are right, it's a matter of which way you want to do it.
  18. Russ B
    Russ B
    daisy chain looks cleaner, but might give less voltage to last gauge than to first one; a terminal block will give more even voltage. One place i read recommended a completely separate line to volt meter.
  19. Just Gary
    Just Gary
    BTTT
    Do you guys wire your aftermarket gauge power wires in series (i.e. daisy chain),
    or in parallel ( 1 wire in, 4 wires out)?
    What about gauge grounds?
    Thanks!
  20. BJR
    BJR
    I am not trying to be an *** but..... You need to look up the difference between series and parallel circuits. From this statement it appears you don't understand the difference.
  21. RICH B
    RICH B
    Depends a little on how the gauges are set up. On the gauges in your picture; I would daisy chain the ignition power from gauge to gauge and build a harness for the light wires. Power wire and left gauge light wire into a **** connector power wire and second from left gauge light wire out of the **** connector, power wire from first connector into a **** connector and power wire and speedo light wire out of the connector, then power wire from second **** connector and second from the right gauge light wire into a **** connector and right gauge light wire out of the **** connector. Gotta be sure to slide the shrink tube sleeves on before crimping.
    Both daisy chain and small harness used in the pictures attached.
  22. bobss396
    bobss396
    My harness had a gauge power and separate gauge power circuit. I used some T&B barrier strips (terminal blocks) and made the terminals common with jumpers that came with them.
    I wish I took a picture, I made up a bracket and mounted them back-to-back on a dash support. Then ran the gauge power and lights accordingly. From the instrument cluster, I made the wiring as common as possible.
    RICH B and Just Gary like this.
