Technical 1929 Model A body block question
Discussion in 'Traditional Hot Rods' started by IronFord, Nov 3, 2013.
  1. IronFord
    IronFord
    from NoDak
    I'm currently in the process of bolting my 29 sport coupe body to an original model a frame. I recently ordered body blocks from Mac's and have discovered that they sent one incorrect block. The rear most block that they sent me has a notch in it. I believe this block is for a phaeton or a sedan. Since I'm only bolting this to the original frame to square the body and brace it. I'm trying to find out if this block is the correct height for a coupe. The block that I have measures 1 15/16"
  2. woodypecker
    woodypecker
    Try the ford barn you will get lots of answers.
