Technical Flathead help
Discussion in 'Traditional Hot Rods' started by 64ONEOFF, May 19, 2013.
  1. 64ONEOFF
    64ONEOFF
    from Md.
    I took this flathead out of my running car. Been collecting a lot of nostalgic parts to put it in my 31 sedan. I decided to cosmetically take it apart clean it up and re***emble it. Then I found this crack behind the p***enger side water pump. It never leaked or showed signs. I was wondering if its possible to weld the block. Or should I say a machine shop weld it. I have a lot of money invested in parts to start looking for a block at this point. If anyone has any input on this it would be much apprieciated......Thanks Jeff:(
  2. scrubba
    scrubba
    Any competent shop capable of cast iron welding techniques could do this one .scrubba
  3. Bart78
    Bart78
    Jb weld it.
  4. JohnEvans
    JohnEvans
    from Phoenix AZ
    Perfect place to do the "Cold Weld" with the threaded taper pins. Regular welding would be a piss poor idea.
  5. If it never leaked don't sweat it
  6. pinkynoegg
    pinkynoegg
    take it to a shop so they can fix her up. I dont see this being a deal breaker
  7. Bart78
    Bart78
    Just use it. Welding a block would be a pain in the ***. The ones I have seen welded were pre heated in a oven. I have seen jb weld hold a lot worse than that.
  8. 64ONEOFF
    64ONEOFF
    from Md.
    I am just really concerned, being the water pump being the motormount. That its gonna continue getting larger. That's why I wanted it welded. Thanks guys.
  9. 1950Effie
    1950Effie
    from no where
    Just pin the ends and JB weld it.
  10. mashed
    mashed
    from 4077th
    JB Weld. That's FUNNY.
    Do yourself a favor and have it fixed PROPERLY.
  11. Saxon
    Saxon
    from MN
    Take it to get pinned and welded. Not a junk block in my opinion but it will need some work. Tough call depending on use.
  12. Pete1
    Pete1
    from Wa.
    It is not in a high stress area.
    Pins will work fine there.
  13. 64ONEOFF
    64ONEOFF
    from Md.
    It ****s, its a low milage 8ba in great shape, well it was. I'm not giving up on it yet. Thanks fellas.
  14. Petejoe
    Petejoe
    from Zoar, Ohio
    You have it apart. Weld it since its easy to get at. Not a show stopper.
  15. R Pope
    R Pope
    I see two cracks in the pics....?
  16. flat 39
    flat 39
    X2 on having it pined
  17. reverb2000
    reverb2000
    from Houston TX
    I see two cracks also...I ***ume you are worried about the one that extends to the outer portion of the block? You need to address both..they will not get any better.
  18. 36tbird
    36tbird
    I would drill and pin the one that goes to the outside of the block just to stop the crack from continuing. The other one is akin to the ones that run between head bolt holes, nothing to worry about. If you think about it, the water pump bolts are above and below that area so a water pump bolted on there trusses up that area.
  19. 64ONEOFF
    64ONEOFF
    from Md.
    I took it to the machine shop. The old timer there said at one point the car it was originally in was in a accident. Said he's seen it a lot back in the day. Said he will pin it and it should be just fine....We will see. I will post picks of it, and final ***embly... Thanks again fellas.Jeff
  20. Gene Boul
    Gene Boul
    Don't weld it...it'll just "swarm" on you. I would pin it and forget it. If it should seep a little (and it bothers you) then add your favorite stop leak...
  21. 64ONEOFF
    64ONEOFF
    from Md.
    Well fellas, Here it is. They Pinned it and machined the face....It turned out Great.... Thanks again for the help.:D
  22. choppedtudor
    choppedtudor
    what? no pics of the pins/repair...? Thats what we all want to see...
  23. 64ONEOFF
    64ONEOFF
    from Md.
    You really couldn't see it after they machined the face of the pump plain...:)
  24. paleot
    paleot
    from louisiana
    S***ch lock repair will take care of that no problem! My Flattie has two cracks through valve seats and into cyl wall. Craigs automotive in Eunice Louisiana fixed it two years ago .No problems!
    Tony
  25. luke13
    luke13
    as a welder i always like ta stress relieve cast steel or iron after working with it, specialy when cracks have been around, usualy a light sandblast works wonders.
  26. Kiwi 4d
    Kiwi 4d
    I had a new French block cracked similarly in the pump face, but from top to bottom , some one else had drilled and plugged it etc. never leaked well not yet any way 3000 Mls. I imagine ours cracked at the foundry when it cooled .
  27. sawbuck
    sawbuck
    from 06492 ct
    nice lookin flatty .... what heads and manifold ?
  28. 64ONEOFF
    64ONEOFF
    from Md.
    Edmund's heads and Wienand intake....Thanks
  29. UNCLECHET
    UNCLECHET
    Great looking mill!
  30. aonemarine
    aonemarine
    from Delaware
    there is a guy near me that fixes stuff like this by spray welding. Pinning is something I have done, but is inferiror to what can be done with the spray weld. Might sound hokey but to see it done is very cool ****!!
