Man A Fre Linkage Help
Discussion in 'The Hokey Ass Message Board' started by oldskooljc, May 29, 2013.
  1. oldskooljc
    oldskooljc
    from Fresno CA.
    Dose anyone have a line on linkage for a Man A Fre 4X2 set up. I am not looking for Eelco it is ****. Any help greatly appreciated thanks Jim
  2. mgtstumpy
    mgtstumpy
  3. joel
    joel
    Hope these help.
  4. craig mcneill
    craig mcneill
    Try vintage speed in FL he built a really nice 6x2 linkage for me and didnt rip me off like that dirt bag Leckner at eelco
  5. rob-redm
    rob-redm
    The new Eelco stuff is ****... That dude is bad news...
  6. saltflats
    saltflats
    from Missouri
    Don't mean to be a smart *** (but I guess I am) looks easy enuf to make your shelf.
  7. titus
    titus
    I made the set up on mine from scratch, copied as close as i could to the original stuff, i ordered rod ends left & right hand threads, stainless rod, left hand jam nuts and a lh tap and die. then i went to it. had to have a buddy machine a couple small parts but over all it worked out nicely. and only cost me about $50
    I also modified the peices that went on the throttle shaft. trimmed off all the fat.
    jeff
  8. saltflats
    saltflats
    from Missouri
    That's what Iam talking about.
  9. titus
    titus
    Also understand that he center cross shaft has to be on the same plane or centerline of the carb throttle shafts and that the link from the cross shaft up the the links that attatch to the throttle arms also have to be the same center to center, thus there is no binding what so ever. you center cross shaft is basically mimicking another pair of carbs.....if that makes sense.
  10. titus
    titus
    just a quick line drawing so my above comment makes sense. my set up isnt fully adjusted yet so they are close eyeball wise for now.
    jeff
  11. saltflats
    saltflats
    from Missouri
    Makes sense to me.
  12. patelaaw
    patelaaw
    from london
    The new Eelco stuff is ****.[​IMG]
  13. oldskooljc
    oldskooljc
    from Fresno CA.
    Only thing I am having a problem with is the two peaces that go over the center shaft and the two pivot himes screw into and lock on the shafts. Dose any one know if there is a peace all ready made like that or will they have to be made from scratch. Pretty much have every thing else. thanks jim
  14. saltflats
    saltflats
    from Missouri
    You may be able to find them in a 2 4 linkage set up.
    Or take a machinest a 24 pack and see what happens.
  15. jacplumb
    jacplumb
    from new jersey
    Let me see if I can help, I will be making a couple of new sets in the near future.
  16. saltflats
    saltflats
    from Missouri
    Bet that cost more than a 24 pack.
    Looks great!!!
    WHat do you have for shaft flex? It does look like larger dia.
  17. oldskooljc
    oldskooljc
    from Fresno CA.
    I will buy Two 24 packs domestic off course. jim
  18. timbow33
    timbow33
    There is a complete, high quality set of linkage on Ebay right now. 11/5/2013.
