Projects How does this look.
Discussion in 'The Hokey Ass Message Board' started by hoodprop, Nov 4, 2013.
  1. hoodprop
    hoodprop
    What so you guys think. Got the fuel block installed. Coil mounted is next to distributor OK.
  2. captmullette
    captmullette
    looks o.k. to me....
  3. You really want opinions ? Sorry for this but...
    I wouldn't have done it that way.
    That rubber hose looks like **** with just 6" of it. 12 feet of it d****d over the engine looks that much worse ( math wizards will see that's 24(****) ) and it likes to get hard and brittle.
    Did you really run out of the fuel pump, up the front, over the top, across the engine, up the fire wall and then back to all 3 carbs you just went past with that ugly *** hose?
  4. HOTRODPRIMER
    HOTRODPRIMER
    I does appear the gas lines are a bit long. HRP
  5. hoodprop
    hoodprop
    Just mocking up some different things seeing what flows and what doesn't. The line is the picture is just being use to get some ideas.
  6. snopeks garage
    snopeks garage
    from macomb MI
    i will second that.
  7. hoodprop
    hoodprop
    The one going to the fuel pump will be metal.
  8. hoodprop
    hoodprop
  9. fsae0607
    fsae0607
    Use rubber hose very sparingly.
  10. 327-365hp
    327-365hp
    from Mass
    Rubber lines are a potential fire hazard and it can look a little lazy. But there's a hundred different ways to skin a cat. Do it the way you like it.
  11. 55 dude
    55 dude
    ditch the rubber and get all the metal you can because todays fuel eats up fuel line and causes nothing but headaches.
  12. fordflambe
    fordflambe
    Ran the rubber for several years on a 31 chevy built in 73' and one day running with my buddies, a piece under the car, connecting the fuel filter broke........it had become brittle and literally broke apart in the middle of the length (about 3 inches long)..........fortunately, the car began running ****py and I had to pull over.......quickly saw the tank draining on the ground............run hard lines where ever possible!
    My lesson was learned.........fortunately, it didn't result in flambe'.
  13. henryj1951
    henryj1951
    from USA
    I kinda like the aircraft braided look...
    :cool:
  14. saltflats
    saltflats
    from Missouri
    Dang 31 Vicky that sounded like my dad.
    Now it sounds like me with my kids.
    For sure to much rubber.
    I might think about mounting the block on the engine.
    Get some cheap brake line and play around when you get it you have a pattern to go by.
  15. 54sled
    54sled
    I think the old school red fuel line looks best with the fuel block, just use new every couple years,so it dont get brittle on ya!
  16. Diavolo
    Diavolo
    I'd do like the 3rd or 4th pic in post 10. Not a fan of rubber except where it connects from the frame to the engine for a little run. Even then I would make sure and use FI line with the teflon liner inside.
    Hard lines are cool, banjo fittings are cool.
  17. luke13
    luke13
    you can get rubber hoses that deal with the new ****py fuels but ya just cant beat the look of steel lines, braided steel looks good to, worth the extra little bit of effort i think.
  18. clem
    clem
    third pic in post ten looks best to me, but then that was how I did mine, - never liked rubber fuel hoses going to a fuel block on the firewall, the different lengths look messy in my opinion.
  19. I am not going to beat you up about rubber fuel lines. Instead I am going to beat you up about the coil mount. Is that coil mounted on an angle? I think vertical looks much better.
    JimSig
  20. Jimv
    Jimv
    Makes the engine look too "Busy"!! Keep everything simple.
    JimV
  21. Post # 10 -
    Move The fuel lines from the yellow Chevy to the red Chevy and now you got something to really proud of.
    The yellow Chevy fuel lines are clean and simple direct and to the point. No rubber involved and the lines are in the path of air from the fan. There's no ugly fuel filter visible, just a nice fuel system. About the only thing id change it to strip the blue anodize off and polish the fitting. However he blew it on the radiator hose and worm drive clamps and plug wires.
    The red Chevy nailed everything except the rubber hose from the fuel pump. I could live with the rubber between the carbs if there were no other options but I'd make it from hard lines.
    Now the carbs on hoodprops engine feed from the opposite side, so the yellow Chevy style would be easy to adapt with the fuel block on either side of the engine. The red Chevy style might work better for him since its feeding from the other side. You could use copper Hvac fittings soldered together and polished to go from carb to carb.
    And yea I sounded like my dad too sorry again. There a preface "sorry" and here the after.
