Can Anyone ID This Weird Double Airfilter Setup For A Single Carb?
Discussion in 'The Hokey Ass Message Board' started by Black Panther, Nov 6, 2013.
  1. Black Panther
    Black Panther
    from SoCal
    Picked this up at a swapmeet...has anyone seen this type of thing before? It goes on a Holley or similar sized carb 5 1/8"...and fits two air cleaners....
  2. oldn_rusty
    oldn_rusty
    I'ma novice, but that looks aftermarket, to me.... Possibly from one of the old superchargers???
    Ed...
  3. Black Panther
    Black Panther
    from SoCal
    Ed....thanks for your reply...it is aftermarket for sure..has A1-45 cast into the top..
  4. davey
    davey
    It ma be the other way one air cleaner for two small carbs
  5. hendo0601
    hendo0601
    from Tacoma, WA
    I dunno, it doesnt look like it would be very efficient because there is no ring-landing for the filter to sit on, whereas the big opening is the perfect size to sit on a carb. The little openings have a place for the filters to sit. Too bad you dont have the tops for the filters, that thing looks pretty cool. I couldnt find anything that looks like that doing a few google searches.
  6. john walker
    john walker
    maybe it's two carbs and one air filter. :)
  7. propwash
    propwash
    from Las Vegas
    If it was for two carbs, I sure like to see the long-*** engine they sit on, enough room for another 4bbl in between.
  8. henryj1951
    henryj1951
    from USA
    bad guess ------> propane adapter ?
    and one would think that the part number would be on top.
  9. Black Panther
    Black Panther
    from SoCal
    Its definitely meant to run two of something on top of a single something. ..if you look at the bosses underneath...the small outboard openings look like they are setup to run studs going upwards...or a bolt down I guess...the center looks like it is just held down with a stud. There are small groovelike areas on the small openings like for an o ring or that the airfilter element would seat on it...
  10. 40FordGuy
    40FordGuy
    Marine application, to accomodate the flame arrester ?
    4TTRUK
  11. Black Panther
    Black Panther
    from SoCal
    Four barrel flame arrestors are readily available...also this piece doesnt save in height or anything...seems to be mostly for looks...
  12. tb33anda3rd
    tb33anda3rd
    there is an air filter adapter like that on my v-12 gmc engine but it has two smaller holes for tubes to the carbs.
  13. 37hotrod
    37hotrod
    Looks more bar-b-que grill or gas furnace, than automotive.
  14. Floorboardinit
    Floorboardinit
    I like it!! Pretty funky...reminded me of one that was in the cl***ifieds. JohnnyA
    [​IMG]Uploaded with ImageShack.com
  15. oldn_rusty
    oldn_rusty
    I think that is one of those wonderful mysterious devices you hang onto, mount on the wall, maybe over the front door, as if it is special and wait for someone to say "Hey, you have one too!".
    Until the wife contributes a "Don't do that"....
  16. It's the optional dual bag adapter for a 1946 ****-A-Lux vacuum cleaner
    Sorry, just trying to increase my post count
  17. Black Panther
    Black Panther
    from SoCal
    Youre almost as bad as the bar b que guy...lol...
  18. Black Panther
    Black Panther
    from SoCal
    Bump for the weekend crowd....any ideas?
  19. 327Eric
    327Eric
    Total guess here. but my first thought was an adapter to run two of the small Cal Custom "Bugcatcher"style scoops. kind of a "fake" crossram look.
  20. BamaMav
    BamaMav
    from Berry, AL
    I'm thinking maybe industrial or farm equipment related? Dual air filters for dusty operating areas?
  21. Steve!
    Steve!
    from at the gym
    Looks like an adapter to feed two turbochargers into a 4bbl carb. sorta like these:
  22. Hotrodmyk
    Hotrodmyk
    I'm thinking an air cleaner adapter for an older medium diesel V8 like a 555 ***mins or 1145 Cat????
  23. Bruce Lancaster
    Bruce Lancaster
    I don't know about the center spacing, but several manufacturers of manifolds offered very similar adapters for use on early Olds and Stude V8 dual carb manifolds with the original side-inlet carbs, the ones with 90 degree bend at top of an otherwise conventional 2-barrel. This gizmo adapted the two carbs to use the main body of the original air cleaner.
  24. hotstuff1
    hotstuff1
    looks like a set up for a 2 carb inline 6 , to use the oil bath air cleaner ?
  25. Okie Pete
    Okie Pete
    I was thinking 2 carbs one air filter. After looking at it closer the two outer holes are threaded for a bolt . The center hole is smooth as if it slid over a bolt. If it was mounted on two carbs the outer holes would be smooth.
