Driveshaft tunnel help
Discussion in 'The Hokey Ass Message Board' started by 57MoreDoor, Nov 6, 2013.
  1. 57MoreDoor
    57MoreDoor
    from CC,TX
  2. Cali4niaCruiser
    Cali4niaCruiser
    Personally, I think that solution is kinda lame. I would rather see the stock brace modified to push up into the car as well. Here's what I did on my roadster floor. different beast, but similar concept. The stock braces were just modified. There are some other pics on my build thread if you are interested.[​IMG]
  3. 57MoreDoor
    57MoreDoor
    from CC,TX
    I agree. Nice work btw. So since my brace is under the car, just modifying that section as you did, should be enough strength?
  4. 57MoreDoor
    57MoreDoor
    from CC,TX
    Is it also necessary to brace the floor somehow, when cutting and raising the tunnel? Such as weld a piece of straight bar from rocker to rocker, almost like bracing the body when chopping a top.
  5. GoFastHotRods
    GoFastHotRods
    from CT
    Here are some under car shots of a model a we did. It is 1"x1" 11g square tube. The floor bolted to the 1.75" tubes of the frame.
  6. 49ratfink
    49ratfink
    working on a 51 Chevy right now where the tunnel was cut out, the new one put in and brazed and a few boogerwelds along with some sort of rubbery stuff was all that was holding it in so basically the left side of the floor was not really attached to the right side. has to be the worst driveshaft tunnel of all time, but it matched all the other ****py work that was done to the car.
  7. 40FordGuy
    40FordGuy
    Great work !!!!
    4TTRUK
  8. Cali4niaCruiser
    Cali4niaCruiser
    I would sure think so. I'm not a materials engineer or anything, but you're not really cutting the entire middle out of the car. There is still metal tying right to left, and top to bottom. When you chop a top the entire structure of one end of the vehicle is removed, hence the braces. On the contrary, braces wont hurt anything either. Ah the joys of home engineering :)
  9. 1971BB427
    1971BB427
    from Oregon
    I don't like floor or tunnel bracing to be raised or above floor level, but I do replace it. I use box tubing, and try to use lightweight box that is close to the original size of the braces. When I chopped the tunnel and floor out on my Falcon project I built a new brace out of 1.75" box tubing. I split it lengthwise to make it close in size to what I cut out, and then welded it into the old braces, and tied it all together. Then I built my new tunnel and floors to the new braces, and added some 1" box tubing to brace up the rest of the new tunnel.
    It's heavier than the original floor and tunnel, but I don't mind the extra weight.
  10. 57MoreDoor
    57MoreDoor
    from CC,TX
    Sounds like fabrication is going to be the hardest part. Keep them coming I need to get as many ideas as possible.
  11. HOTRODPRIMER
    HOTRODPRIMER
    That is some beautiful work! HRP
  12. Cali4niaCruiser
    Cali4niaCruiser
    Thank you HRP! When looking for answers to fabrication issues, sometimes emulating stock is the cleanest way too go. Just modify to fit.
  13. 57MoreDoor
    57MoreDoor
    from CC,TX
    So can I get some more ideas and help on this. I'm afraid of cutting through the floor brace and the floor shifting.
  14. 49ratfink
    49ratfink
    what you do is get some steel like 1/4 X 2.5 and bend it to the shape of what your tunnel will be. then weld those pieces to whatever crossbraces your floor came with. then make the sheetmetal tunnel to fit the hoops you just made. this photo should explain it.
  15. 57MoreDoor
    57MoreDoor
    from CC,TX
    Looks and sounds good. Hate to get technical, but every placed I've called said their steel is cold rolled, isn't hot rolled easier to work with and weld?
  16. 1971BB427
    1971BB427
    from Oregon
    No, cold rolled is easier to work with.
    When I do mine I bend up lightweight box tubing to the shape I want prior to bending up the trans tunnel. Then bend the tunnel to fit the new braces I build, and drill holes in the new tunnel where it overlaps the braces and plug weld to the braces.
  17. 49ratfink
    49ratfink
    can't help you there, most of my steel if of the FFF variety. Found For Free
