3/4 cam???
Discussion in 'The Hokey Ass Message Board' started by Dan, Nov 8, 2013.
  1. Dan
    Dan
    See this term kicked around a lot...obviously its in reference to the fact that it is a performance grind, not quite stock... i.e. "3/4 race"...
    What I don't get is, its 3/4's of what?? At what point is a cam a 1/4, 1/2, 3/4, full etc.? I am sure I am overthinking this and it was obviously just an early marketing ploy...a way for the early guys to puff up and say "Well my engine has a 3/4 race cam..." I just constantly find myself wanting to ask someone when they say they have a 3/4 cam "3/4's of what??" Any insight into the origination of this term??? Thanks-
  2. hendo0601
    hendo0601
    from Tacoma, WA
    I too take issue with people saying "3/4 cam" because I am just not sure what the hell it is 3/4 of? I haven't heard this term get used in a few years, but most of the people I heard use it also referred to them as an RV cam. How do you quantify what 3/4 of a race cam profile is? It probably originated with the guy whos brother's uncle's sister's cousin's best friend had a "67 Dodge Challenger with that "440 Hemi" 3/4 race cam and 4.56:1 rear gears from the factory".
  3. I haven't heard that term since I was a teenager. Many many many years ago. Lol
  4. Bert Kollar
    Bert Kollar
    I think it started in the 50's with the flatheads. Cam grinders use to sell them as street grind, 3/4 or full race
  5. gimpyshotrods
    gimpyshotrods
    I had a 3/4 cam once. Ran really rough with the back two cylinders out.
  6. scrappybunch
    scrappybunch
    from nj
    Van Idersteins speed shop here, had a 3/4 grind mounted up on the wall. Yep the 4 rear lobes were sawed off.
  7. Thumper
    Thumper
    Oh geeze.....not this **** again....:rolleyes:
  8. BillWallace
    BillWallace
    This is pretty simple really. After ww2 when speed parts were something you could buy from adds in magazines etc cam grinders used the term to identify cams that did not provide the lift & duration of the race grinds thus were 3/4s ( or less than) of the grind of the full race cams.
  9. Dan
    Dan
    I thought I saw in the latest Speedway they had a new line of cams they were marketing as "3/4"? Sorry if this has been beat to death, I just don't remember ever seeing the topic come up...
    A cam with a 1/4 of it missing...that's funny **** right there-
  10. models916
    models916
    Back in my days it meant 300 dur with 400 lift at the cam lobe. 3/4
    22rdstrguy likes this.
  11. Hdonlybob
    Hdonlybob
    Good question. I have often wondered the same thing...
    This answer seems to make sense..
  12. HEATHEN
    HEATHEN
    from SIDNEY, NY
    It was just the terminology of the day.....it was hotter than stock, but not really up to the "race" cam specs, so it was "3/4 race". I picked up a few N.O.S. Wolverine cams at a swap meet last sunday, and one of them is a solid lifter cam for Pontiac V8s with "super full race" printed on the box, so I guess that it trumps both of them!
  13. Dan
    Dan
    "super full race", that's good...reminds me of "Do not taunt Super Happy Fun Ball!"
    300 duration, 400 lift would be an interesting definition as it refers to actual specs...
  14. If this is true, what is "full race" derived from?
    I remember "street grind", "3/4 race", and "full race", The names were just comparative names for us idiots that didn't understand all the cam spec numbers.
    A street grind was a little hotter than stock, a 3/4 cam had a lope at idle but was able to be driven on the street and a full race cam was meant for the track, not really something you would want to put up with on the street.
  15. 40FORDPU
    40FORDPU
    The Isky Max 1 camshaft for Flathead Ford, is refered by Isky as a 3/4 race cam.
    The specs are .364 lift 249 adv. duration.
    Sharpone likes this.
  16. 40FordGuy
    40FordGuy
    What 40FORDPU said.
    4TTRUK
  17. 26 T Ford RPU
    26 T Ford RPU
    This term has bugged me since the 70s. I pissed off anyone saying ( what ever amount of race they said ) that by asking what kind of race is it for,road race drag off roar etc etc and then explain why they are not the same. The term was used a lot in New Zealand back in the day. JW
  18. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Some people couldn't even go with "3/4 race".....when I worked in a parts store in the '80s, a guy walked in one day and wanted a 3/4 INCH cam. I told him that, at .750 valve lift, he'd probably run into valve to piston clearance issues.
  19. A 3/4 cam has @ 270 degrees of duration or 3/4 of 360 degrees of rotation. A circle is 360 degrees. A quarter of that is 90, correct?
    It does not describe lift just duration of the cam shaft. Now here is where we stray anything in the 280+ range is considered a full race cam, obviously you cannot have your valves open for the full duration of a cam rotation.
  20. hendo0601
    hendo0601
    from Tacoma, WA
  21. 'Mo
    'Mo
    This is correct.
    Isky had no problem with the term.
    Note how similar his 3/4 and full-race cams are in both lift and duration.
    Sometimes it was more a matter of lobe profile (i.e., steeper ramps).
    Same for McGurk. (Also 'D.P.' cams, with in./ex. differences in both duration and lift).
    Likewise for Howard, Herbert, Spalding...This was standard terminology of the day, a**** the cam grinding pioneers. Old Timers still use the term.
    Incidentally, The 'D.P.' designation is for 'Dual Pattern', because the in./ex. grinds are not the same. (Old Chevy sixes made good use of additional ex. duration, without losing street-ability.)
  22. gkgeiger
    gkgeiger
    I've never heard this term used in anything but a flathead, but at 70 I've heard it for years. I use it because that's the way my cam was advertised.
  23. 1971BB427
    1971BB427
    from Oregon
    Ditto! I used to hear and read the term used in advertising a lot in the 60's. I can't say I've heard that terminology used in a couple decades or more. Never made sense to me back then, and still doesn't today.
  24. 1971BB427
    1971BB427
    from Oregon
    Or maybe lobe separation? Often the shorter LSA was used on strip cams, and longer LSA was used for more streetable cams, so they idled better, and had more vacuum.
  25. 'Mo
    'Mo
    BIG factor! Good point.
  26. s55mercury66
    s55mercury66
    from SW Wyoming
    Athough I imagine the term dates back farther than 1956, my dad had my uncle (service manager at Ogg Ford, Glouster, Ohio) install a "3/4 cam" in his 312 in his new '56 Sunliner.
  27. Scumdog
    Scumdog
    Yep, bored out Zody motor with Bedford pistons, 1/2 race cam, flows and tripple SU's:D
    Any of you Yanks understand this??
  28. colinsmithson
    colinsmithson
    Us Aussie understand
  29. colinsmithson
    colinsmithson
    A cam guy once told me you have stock and full racing 1/2 way between the 2 is 1/2 race
    And is easy parts sell to remember instead of lots of numbers most do not understand
  30. volvobrynk
    volvobrynk
    from Denmark
    I'm not an American, so the things that makes sanse to you is odd to me, and odd too you is really weird me.
    We use to just list cams as: stock, fast road, rally/track (******** road) or full race.
    3/4 must be a rally/track, bad idleling, but gets better with more RPM. But no screamer.
    I get the "zody w/Bedford pistons 1/2 race, flows and triple su".
    And around here we would say:"that is one that really could put flaps down". :-D
    Around here, people calls a hotter cam for sharp cam.
    And we only puts up Duration/lift, in adds.
    I see on here you list other kinds of stuff. Sometimes other stuff, and even put different values for in and out lobes.
