Projects my other build the dirty2
Discussion in 'The Hokey Ass Message Board' started by hooliganz 1, Nov 11, 2013.
  1. hooliganz 1
    hooliganz 1
    well this is my roadster ive had it about 5-6 years now i built it in a carport with a grinder a tourch and a flux core welder. most of it was given to me no not the best if done but it was what i could do with what i had
  2. hooliganz 1
    hooliganz 1
    finally got it to this it was fun but after the wife left i started to have waaaaay to much fun with it wicth ending up braking cross members and the transmission.after i got my head out my *** and the car to mississippi i thought it was time to update the car better frame better welds and mounts better floors opening doors and so on
  3. F&J
    F&J
    Looks great now. It also is really close to a 30 chev roadster pickup I just got that was built in 59/60. real close.
  4. hooliganz 1
    hooliganz 1
    so i tore it all downgetting the ****** fixed and tought id fix some things on it made coil spring buckets for the rear
  5. hooliganz 1
    hooliganz 1
    it a 32 dodge four door that was gut down to a truck after i was done cutting the rust this is what i had a cowl and two door skins i made the rest
  6. hooliganz 1
    hooliganz 1
    then i started on the poor frame
  7. hooliganz 1
    hooliganz 1
    one brake shown here is what the body was bolted to and the other is the mess of a front crossmember i made real weak it popped out with a little grinding and a hammer
  8. hooliganz 1
    hooliganz 1
    some parts i made to fix that problem
  9. hooliganz 1
    hooliganz 1
    a new crossmember and mounts to move the spring look alot cleaner and safer not welded in fully yet
  10. hooliganz 1
    hooliganz 1
    a little ahead of my self before and after shots
  11. hooliganz 1
    hooliganz 1
    then i started on the floor. it was channeled to the bottom of the frame but at six foot 200 + and no doors that was a pain. so i just put new floors in my dads 41 coup so i took the old one and did some measuring and the rust would be cut off if i used them. plus a pic of the old floor
  12. LOWBLAZERO1
    LOWBLAZERO1
    whoa! that frame is scary!
  13. hooliganz 1
    hooliganz 1
    what took the longest was removing the tar all over the floors but under all that tar was nice shiney metal
  14. hooliganz 1
    hooliganz 1
    yes it was opps
  15. rottenleonard
    rottenleonard
  16. hooliganz 1
    hooliganz 1
    made a BIG cardboard templet and cut it out to fit
  17. hooliganz 1
    hooliganz 1
    not done yet i know its ugly
  18. hooliganz 1
    hooliganz 1
    and this is it sitting in the cap no channel
  19. willymakeit
    willymakeit
    You will get there. Good luck
  20. hooliganz 1
    hooliganz 1
    oh i have alot of work to do but now i have the right tools and supplys and money to do it right though im doing it on the cheap
  21. HOTRODPRIMER
    HOTRODPRIMER
    I applaud you for trying but please seek out some help with that front suspension. HRP
  22. hooliganz 1
    hooliganz 1
    thats not the final weld its just a mock up
  23. Ironskillz
    Ironskillz
    from Madison,AL
    x2! That needs to be ground flushed and re-welded in one proper motion with a GMAW welding process. No flux. You hit a bump just right that whole front perch/linkage will go in all out hells dive as long as well as everyone looking at it. Not trying to be harsh stating the facts jack. Rather be alive then K.I.A.
  24. hooliganz 1
    hooliganz 1
    it will just not now! enuff already! jesus its just mocked up to see if it will even work i was in a hurry sorry move on!
  25. You really need to improve your welding skills before welding ch***is and suspension. Other people use the streets too.
  26. hooliganz 1
    hooliganz 1
    ill admit it is a ****ty weld do you really think id leave it like that no but thanks for your concerntrust me ill fix it
  27. I think you misunderstood. I'm not just referring to that one weld or that one part. You need to learn how to weld BEFORE you try to build and modify ch***is and/or suspension components. I'm not trying to be an *** or to put you down, but that entire frame and rear suspension is junk even by rat rod standards. Learn some skills and start over.
  28. hooliganshotrods
    hooliganshotrods
    Sorry but he's right. You have a chance to re-do all that is wrong and judging from your fab skills you aren't capable of the welding or fabricating so do yourself a favor and take some welding cl***es and practice ALOT if you insist on welding up another suspension, or better yet, spend a little money and have someone capable to do it. It would be money well spent since it could be your life OR worse.....someone else's when it breaks.
    No-one I know fully welds a bracket or whatever part for mock-up
  29. hooliganz 1
    hooliganz 1
    you guys are funny thank you
  30. F&J
    F&J
    don't sweat it, stick around.
    You said you'd fix the welds, and thats fine by me.
    You do have a good eye for style, as your pic of the new version sits dam nice and looks well proportioned. Have fun.
