Technical 1958 corvette
Discussion in 'Traditional Hot Rods' started by rooster31, Nov 12, 2013.
  1. are the 1958 corvette rear ends the same at the 55-57 chevys? im working on a 49 chevy. i havent picked up the rearend yet. trying to do some research to see if its close to the same with as my 49 thanks.
  2. R Pope
    R Pope
    Same as 56-57, 55 had smaller pinion shaft but the rest is the same.
  3. If it is truly a rearend out of a 58 Corvette I would think you could sell it to a restorer for enough dough to buy a custom 9" setup for your car. Vette people pay a lot for original parts even if they are interchangeable with standard Chevies..
  4. it was taken out for a street rod up grade. to 9 inch ford. entire running gear was removed with less than 30k miles
  5. V4F
    V4F
    from middle ca.
    sell it as the guy said . you will be $$$$ ahead
  6. cavman
    cavman
    It is NOT the same. The thing that isn't the same is the axle flanges where the backing plates bolt. They are at a different angle. I found that out years ago. :)
