Projects 1952 packard 200
Discussion in 'The Hokey Ass Message Board' started by ammiller83, Nov 12, 2013.
  1. ammiller83
    ammiller83
    I just got a 1952 packard 200. Are there any other hamb guys that have a 1952 packard ?
  2. Rusty O'Toole
    Rusty O'Toole
    Yes more than one. Do a search for Packard and see what turns up.
  3. Ocean56
    Ocean56
    from Michigan
    Also make sure you visit packardinfo.com. LOTS of Packard knowledge and info and help there!
  4. ammiller83
    ammiller83
    I need help my Packard transmission goes from low to high put when i come to a stop its still in high and not low.
  5. Rusty O'Toole
    Rusty O'Toole
    Normal. They only had 2 speeds. High was the main gear, low was for emergencies. Only from 54 on they had a Gear Start Ultramatic, it started in low and shifted to high. Before that they just started in high unless you shifted to low manually.
    low budget likes this.
  6. low budget
    low budget
    from Central Ky
    Bet thats a relief to the op, Not just any old joe would know that, So thumbs up to ya Rusty:cool:
    ....but he did say it started out in low at first so???
  7. ammiller83
    ammiller83
    I start it off in high i can shifted it into low manually. I drive it in high all the time. When i come to a stop in high it jerks and wants to stall and die.
  8. ammiller83
    ammiller83
    Some time in the cars life someone changed the engine to a 1953 327 with a Carter WCFB 4-Barrel Carburetor Carb on with a manual choke.
  9. foolthrottle
    foolthrottle
    Have you considered a modern th 400 or something? as I recall that original trans was cast iron and weighed as much as a VW.
