Bench seat options for A coupe?
Discussion in 'The Hokey Ass Message Board' started by dsiddons, Nov 12, 2013.
  1. dsiddons
    dsiddons
    from Indiana
    I have a minivan seat already. My problem is the damn thing is kinda tapered the wrong way. Bottom line I just really don't like it. Has anyone cut down a early S 10 or Ranger seat? Or what else will work. CJ rear seat is to small at 33".
  2. Jokester
    Jokester
    Consider who will be driving it. My wife has shorter legs than I, so when she's driving the seat is pulled way forward. If I had a bench seat, me knees would be against the windshield. I vote for individual seats.
    My 2¢.
    lbjb
  3. scrap metal 48
    scrap metal 48
    I've cut down a few S-10 seats but the backs are not very high and don't quite look right...
  4. leroux
    leroux
    from SoCAl
    I toyed around with a swap seat frame with my 30 coupe. Out of sure craziness I went with the stock. It turned out better than I ever expected. Looking perfect and natural it fits.
  5. 68Camaro427
    68Camaro427
    I'm in the process of cutting down an S10 bench seat for my 29 A.
    S**** metal 48 - I never really considered the seat back being low. :( I'll have to keep my eye on that.
    I sold the stock A seat last summer. I'm too tall to fit behind the wheel with the stock/unadjustable seat, so I started looking for alternatives. Lo and behold, craigslist came through, and the price was right (free-get this seat my son bought out of my garage!!), so if it does end up being too short at the backrest, I'll only be out time and mig supplies :)
  6. HellsHotRods
    HellsHotRods
    You want a lower back so you can push it back further. I've cut down some s10 seats for a coupes and trucks. My brother is 6' 2" and I got him to fit in a 28 truck cab.
  7. Bam.inc
    Bam.inc
    from KS
    Keep'm comin. What are more bench ideas? I got a $10 '90's dodge caravan third row, but was too wide. So do u just start sawing off foam of outer sides?
    Seems there' s some old threads on this; but what are other good ideas?
  8. lrs30
    lrs30
    from Kentucky
    Middle row mid 90's caravan seat worked like a charm, made new seat riser angle just right.
  9. HellsHotRods
    HellsHotRods
    Cut frame in half, take out section that is too wide, weld it back up. cut foam off on ends. It will come out great, you can do this.
  10. HOTRODPRIMER
    HOTRODPRIMER
    High density foam and plywood works great and when covered it doesn't look like a mini van seat. HRP
  11. ...Second row 90's Dodge Minivan seat in my coupe project...
  12. ^^^^^ That looks like a jeep rear seat to me. Judging by the fabric and shape.
    Fits good...
  13. ...You're probably right!.. It was in there when I got the car...Thanks!
  14. leroux
    leroux
    from SoCAl
    Almost looks like a back seat to a blazer or bronco.
  15. dsiddons
    dsiddons
    from Indiana
    Thanks. I'm headed to the yard this weekend. Never thought about the Bronco. The Jeep seat must be a TJ looks like a good fit. I must just got the wrong year van seat. I will still look at them to.
  16. leroux
    leroux
    from SoCAl
    What's the plan for the seat. I'm using a stock seat with a rebuild spring kit and I turned out perfect
  17. RDAH
    RDAH
    from NL, WI
    Pontoon boat seat. Already upholstered in a 50's style. Not the buckets. The bench ones.
  18. fiftyv8
    fiftyv8
    from CO & WA
  19. Oldmanolds
    Oldmanolds
    Here is my answer to the same problem I had. The oversized lumbar is for a bad back. This seat is great for trips 4 hours or more. Before with the buckets I had I was good only for a short trip.
  20. crminal
    crminal
    All the parts are available to rebuild a stock seat. Wood kit for the seat and back platforms and spring units. Ends up about $450.00 for all, plus upholstery. Lebaron-Bonney.
    If you are looking for original style, made well, it is another option.
  21. sidevalve8ba
    sidevalve8ba
    I narrowed an '84 Ranger seat by about 6" if memory serves me and I am using it in my '32 pickup. It is comfortable, adjustable and the seat back tilts forward for access. I cut the foam with one of those electric carving knives and glued it back together with spray trim adhesive.
  22. dragass
    dragass
    I went with 1960's A-100 Dodge van buckets. Perfect fit.
  23. Rochie
    Rochie
    Mine is a middle seat out of a mid 90's dodge minivan. If you take one bolt out each side of the seat back, the back will fold forward to allow access to "SOME" storage behind the seat. I've spent a few 12 hour driving days sitting on it and it works great.
  24. willys1
    willys1
    from South Ga
  25. dsiddons
    dsiddons
    from Indiana
    I like this.
  26. dsiddons
    dsiddons
    from Indiana
    I've got a list now and a tape measure. Thanks for all the options. I have a stock a seat but don't like it either. The back is kinda a funky shape. I want to roll some pleats over the top to the back and looking for a more rounded back I guess.
