Projects 36-taildragger.....Made in Sweden
Discussion in 'Traditional Customs' started by Kenneth31coupe, Mar 17, 2013.
  1. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    Finaly the p***enger door is done.Got it installed today.
    Got the wheels back on and sat it down on the floor. Gonna start bracing the body again for the chop.
    The roof has been filled some time in the past and is pretty nicely done and the insert chanel is still intact under the roof.First I was gonna cut out the filling panel and reinstall the insert but the more I´ve been thinking about it I think I will go for a filled roof again.I believe that in the 40´s and 50´s they would have done that to get a more modern and luxury look.
  2. ElBrujo
    ElBrujo
    Wow!! That's amazing work you do.
  3. 32coop
    32coop
    from Australia
    Looks fantastic. Can't wait for the chop.
  4. kippers 34
    kippers 34
    She is looking extreamly good Kenneth!
  5. brian55lvr
    brian55lvr
    from ma
  6. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    Thanks a lot.
    Thanks. Stay tuned.
    Thank you Kipp.
    Thanks
  7. nunattax
    nunattax
  8. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    Thanks I think:)
  9. Wensum Valley Rods
    Wensum Valley Rods
    from England
    Those doors have turned out really well Kenneth. The whole coupe is looking really straight and solid now.
    Guess it's nearly time for the real fun to begin..............The custom work.
    Paul.
  10. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    Any day now Paul. The cut lines for the chop is scribed.Some small details left then I will start cutting.:D
  11. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    Ok here we go.Cut the roof off today.First cut was on the doors.
    Then I cut the roof. Took out 3 3/4" from the b-post and put the lid back on. First I planed to take 4" but I think I start with this and see how it looks.Gonna split the roof and take out 3" from a-pillars.Then I will roll it outside to get some distance to look from.In my little space in the garage I can´t see ****.
    Didn´t section out the rear window like many others do.I like them small just as the ones on carson tops.
  12. K13
    K13
    Looks good. Are you going to move the rear window up into the top with it being that small to get it more centered top to bottom?
  13. 1 KooL "MoFo"
    1 KooL "MoFo"
    Very nice work so fare keep it going ! Mad Skill's !!!!!!
  14. Sakke
    Sakke
    from Finland
    Great work !! Keep posting pics of your progress !!
  15. kippers 34
    kippers 34
    *****en! Now the fun begins. Go Kenneth Go.
  16. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    That´s an interesting thought I sure will consider. Will see how it looks when it comes outside.When looking at it now maybe I will widen the window slightly.This is the look I´m after.
    Thanks
    Thanks
    Thanks Kipp.
  17. heyitsnate
    heyitsnate
  18. rramjet
    rramjet
    I hated to see you chop this beautiful car but being able to see your craftmanship in doing it makes it a little more bearable. Nice work.
  19. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    Thanks Nate
    A full kustom needs to be chopped;) Thanks for the kind words
    Split the roof today and cut 3 1/8" off of the a-pillars.Put it back and I think I´m pretty close.The darkness comes too early these days so I will have to wait for the weekend to get it outside for a peek in daylight.
  20. K13
    K13
    It may have been the angle of your picture because this on doesn't look as disproportionately low as the pic you posted of your car.
  21. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    I think so too.It doesn´t look that disproportional in reality.
  22. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    Started to line up the back off the roof.When the b-post was lined up the corner off the roof was to small.
    After some pushing and tweaking from inside to make it fit and see where to cut a reliefe I desided to cut it along the door post and move the whole roof backwards.
    Then there was the beltline that was missaligned.
    Cut out a bit off the beltline
    Moved the cutout beltlinepiece forward to line up and tacked it in.
  23. flatheadfever
    flatheadfever
  24. The 39 guy
    The 39 guy
    Kenneth, You are an amazingly talented guy! Thank you so much for the detailed, clear photos and timely updates. I don't know how you find time to do the work and do the posting like you do, but I am learning a lot just by following your progress.
  25. PRIMER STUDIO
    PRIMER STUDIO
    from Butte,MT
    I have always wanted to see a 36 3-window get chopped. Looks fantastic!
  26. Wensum Valley Rods
    Wensum Valley Rods
    from England
    Great work Kenneth, love to see how you are thinking out every move and cut.
    Can almost hear the cogs turning in your head from here :).
    The beltline is looking good and the strength in it will help the roof keep shape loads when you start to weld it up,.
    Paul.
  27. farmer12
    farmer12
    Still following this thread closely. Awesome work!
  28. luke13
    luke13
    amazing work, you guys up the far north sure do make good use of your long winters.
  29. longgoner
    longgoner
    from western ny
    Wow. Perfect amount and methods.
  30. Tnomoldw
    Tnomoldw
    :)But they seem to speed up in the summers ! :cool::D
