Guy is trying to sell me a small block 327? Please help identify.
Discussion in 'The Hokey Ass Message Board' started by Jay Tyrrell, Nov 13, 2013.
  1. Jay Tyrrell
    Jay Tyrrell
    Every small block was in a corvette right! lololol Just wanted to get that out of the way. So these are the numbers that the motor has from the ****py pictures he is sending me.
    Casting Numbers 3858174
    Front Pad Stamp: (I think FOI22YWC)
    It is coming back a 327 2 bolt main but I am just curious what it was in.
    Thanks
    Jay
  2. 40FORDPU
    40FORDPU
    I show it as a '66 Vette block. Couldn't find your front pad stamp.
  3. F&J
    F&J
    when we were kids in the 60s, we'd look up the 2 letter suffix in OUR Motors manual.
    Nobody has manuals anymore, it seems. Those books gave the make and model with the engine code, too
    and then the world went all modern and chevy went with 3 letters at the end of the decade, and our books were too old :(
    expect a comment here:D
  4. F&J
    F&J
    online, not sure if there is more
  5. TagMan
    TagMan
    1964-1967 car & truck, '66 Corvette used the 3858174, according to the book "Chevy Casting Numbers 1955-1993".
    1Nimrod likes this.
  6. Torkwrench
    Torkwrench
    Do you have the date code? This is located at the rear of the block on the side opposite of the casting number. This will narrow the year down. Sometimes the same suffix on the engine stamping was used for different engines, depending on the year built as shown by F&J's post.
  7. Jay Tyrrell
    Jay Tyrrell
    I remember those! i wish it was that easy. I found the casting numbers easy enough but the stamped number in the front that is another story...
    Jay
  8. henry29
    henry29
    <table border="0" width="100%"><tbody><tr><td>1964-67 </td><td>3858174 </td><td>327 </td><td> - </td><td>- </td><td> 2</td><td> car, truck</td></tr></tbody></table>
  9. Jay Tyrrell
    Jay Tyrrell
    That is what the guy is toting it as. I told him to get the numbers off the pad. The only ones I saw were FOI22YWC
    Jay
  10. Jay Tyrrell
    Jay Tyrrell
    That is exactly what I found man.
    Jay
  11. 40FORDPU
    40FORDPU
    I found the casting number 3858174 referenced in the Corvette Black Book, as for a '66 Vette.
  12. F&J
    F&J
    might be corvette truck, ;) 1/4 ton
    That prefix looks way wrong to me. the first letters are the engine plant, and a common one is TO for a new york plant
    anyways, those old books would tell plant prefixes maybe?, especially my 67 and 69 edition, but it's too cold to go to the shop right now:D. I will go later tonight to fill the woodboiler; if nobody has a book by then, i will look.
  13. Jay Tyrrell
    Jay Tyrrell
    I am going to get him to get me the numbers again off the front pad. Like I said ****py pic. I appreciate you looking that up man!
    Thanks
    Jay
  14. henry29
    henry29
    Can you post the ****py pic of the stamped number?
  15. F&J
    F&J
    I can only think of 2 prefixes right now...from the 60s stuff we had. One was F or FO? for Flint plant, and TO for Tonowanda NY plant.
    Maybe someone knows any more prefixes for 1960s sbc
    did vette have it's own prefix? I sure don't recall that:confused:
  16. squirrel
    F and V and T are the prefixes for the 3 Chevy engine plants. The 0 is part of the date, the first nine months have a leading zero (after they started making them all 4 digit date codes in the late 50s)
    YWC is a 3 letters, 1970 and newer, but the block casting number is for a 327 from the 60s, so my guess is the stamping is hard to read and was not read properly. Should be a letter, then 4 numbers, then two letters.
  17. Jay Tyrrell
    Jay Tyrrell
    Here is the pic!
    1Nimrod likes this.
  18. squirrel
    F0122YWC
    interesting...from a similar thread a few years ago,
    YW is the suffix for a 1966 C60 (big) truck 327 engine.
    They also used CE or R to designate "parts counter" replacement engines, perhaps it's a replacement engine?
  19. Jay Tyrrell
    Jay Tyrrell
    And casting number!
    Jay
    1Nimrod likes this.
  20. Jay Tyrrell
    Jay Tyrrell
    **** my eyes must be bad! lololol that O is a C! Good eyes man!
    Jay
  21. jveesart
    jveesart
  22. Jay Tyrrell
    Jay Tyrrell
    Ok so what do you guys think the block worth? I currrently have a 1965 327 in the 55 but I was thinking of getting another block just in case.
  23. Aquaroscoe
    Aquaroscoe
    For the C2 series, the SBC stamp pad should all start with F from the Flint location. all C2 SBC's came from Flint.
    F01 = Flint, jan 22
  24. 327Eric
    327Eric
    100 bucks is all I'd pay for a bare block.
  25. Jay Tyrrell
    Jay Tyrrell
    With crank and pistons? Short block? Has stock bore too.
    Jay
  26. 327Eric
    327Eric
    I'd be hard pressed to pay more than 200 with those parts, 250 if I really want it. A complete core with heads and intake can be had for 250-400. I have the same, 1965 Virgin short block Core, and I paid 200 for it. I have been offered 250 a couple times, but turned it down. All depends on how much you like em, and how hard you want to run it. When you need one, They can't be found.
  27. Jay Tyrrell
    Jay Tyrrell
    I hear ya man!
    Jay
  28. Jay Tyrrell
    Jay Tyrrell
    It is FOI22YWC on the front pad he got back to me. Any ideas? Is this a replacement block?
  29. Black Panther
    Black Panther
    from SoCal
    G***erkid...in 1966 and 1967 Chevy engines there was sometimes a suffix to the ***embly code that had to do with what carburetor was on the motor...I have seen ones that end in an H (Holley carb) so perhaps ending in a C means it had a Carter carb?
    Normally a regular code like yours isnt a counter exchange engine...a CE prefix does or sometimes a C..
  30. a common 327 number.....
