Ford Aerostar springs.how much of a drop?
Discussion in 'The Hokey Ass Message Board' started by mikhett, Aug 26, 2013.
  1. mikhett
    mikhett
    from jackson nj
    how much of a drop will a pair of ford aero star springs give me on a 56 ford fair lane.
  2. Used Up Junk
    Used Up Junk
    from Merced, CA
    We put a set of aerostar springs in my buddie's '58 Edsel and got about 3 inches of drop. I think that is about what most guys are getting out of them too.
  3. chromeazone
    chromeazone
    I used the MOOG CC850 (about $75.00 pair) on my 51 Ford Shoebox, and it was at least 2"-3". No problems. (But I did get whole front suspension rebuilt at same time.)
    Would never heat springs again.
  4. Squablow
    Squablow
    I got about 3" in my '52 Ford. I think that's what you'd get out of a '56 as well.
  5. JeffB2
    JeffB2
    from Phoenix,AZ
    In most cases you will get 2 1/2" after some driving it will settle another 1/2",the other plus is an improvement in ride and cornering.The listings for the matching shocks is in the 52-59 Ford "sticky FAQ."
  6. mikhett
    mikhett
    from jackson nj
    Thanks guys!
  7. Fryguy302
    Fryguy302
    from Michigan
    You will need spacers if you run the grenada spindles and a big block.
    With the Grenada spindles, the Aerostar springs put the car too low. I like it too low, but it wasn't drive-able.
    I'm going to take a bunch of weight out of the front (re-locate battery, and aluminum heads on the big block), and also put a shim in the springs and keep running the Aerostar springs. I want it to be as low as possible and still drive-able.
    Here's a pic of the springs uncompressed next to each other. Big difference.
