Does anyone know the part number of the lower radiator hose when using a water pump riser (w/ 6 cyl pump) in a '32 with a Walker radiator???
...& maybe he will share the part numbers for the impeller & pop-off valve he uses. I need to get mine sorted out too. JH
I ain't Randy but he gave me the information when I was adding the zips on the 327 in my truck. The lower hose is a Gates # 20225 The purge vent is a GM part # 10070107 And the impeller piece is from summit. Hope that helps. HRP
I'm setting up the Zip's riser in the '31 A roadster I'm near finish on building. If you go to Auto Zone and get their heavy duty pump, it'll have the plate already on the impeller and it's got a lifetime guarantee. They''ll more than likely come out first with a cast iron pump that doesn't have the plate on the impeller. Tell them to look further and they'll find the one listed as hvy duty. It has an aluminum body and has been tumbled to a bright, almost polished look. Price was about $85 IIRC. They had to order it, took a couple days to get it. Do a search and you'll find it, that's where I found it. Sorry I don't have the number right here, but the car is at the shop and I'm @ home drinking coffee! Dave
Only about 3 hours late Been out in the shop working while it was COOL this morning. I use the Gates 20225 bottom hose ( it has to be trimed a little ) For the upper hose I use a Gates # 20046 The GM purge valve I like it is #10070107 ZIPS has a small screw in the top for purging the air but it is small and somewhat difficult to use. I like the larger and much easier GM purge valve Now FlowKooler sells a 6 cylinder Chevrolet pump ... with the special impellar ... already ready for the ZIPS ... for $68.95 ... go here http://flowkoolerwaterpumps.com/catalog2/product_info.php?cPath=1_16_81&products_id=86 I like to use a Walker shroud and a big belt driven mechanical fan. Keeps my 32 running cool. The AutoZone aluminum pump number is BWP-386HDA They usually have to order it. Randy
The impeller plate closes up the back and moves MORE coolant. FlowKooler claims ( copied and pasted ... directly from their web site ) FlowKooler pumps patented impeller design has helped stop engines from overheating and reduced engine temperature up to 30 degrees by doubling the flow of coolant through engines... Original pump impeller design After the plate is installed It would be a very simple matter to just make a thin plate to pop rivet to the rear of the impeller. But I just went the easy way ( at the time ) and bought the plate from Summit. I bought 4 or 5 at one time ( a few years back ). They are about 5 or 6 dollars each. I do not know IF Summit still sells them. NOW I would just buy the pump already modified. Either the FlowKooler or the aluminum one from AutZone.
The mention of a Walker shroud was by Randy, aka Deuce Roadster, now deceased, and missed BTW. But yes he also ran a Walker Radiator. He and I talked offline on the hone several times about cooling issues. Nice guy and very knowledgeable.
Can I safely cut off all the cast-in-place brackets that I don't need without ruining the basic riser? Don't need an AC or alternator mount.
Don't think you would hurt anything by cutting off unused brackets, but if you ever want to sell it, that may kill the sale. Hell, everybody knows you gotta have an alternator, so why hide it up under the engine where you have to stand on your head and hunch up like a monkey ****ing a football to get to it?
any one got an answer to f-150k's question about running a hose between the pump and the intake manifold.
Not sure how that'd work. My car is over in my shop and I'm at home, but IIRC, the water pump connection is at a point of suction, and the intake manifold on SBC is a pressure point, both being as pump circulation is considered, not pressure from a pressurrized system. And the point on the head is also a pressure point, so it might work if I'm thinking right on the water flow patterns. Guess you could try it and see how it worked. But I'd use one of those little handheld heat sensing infrared guns to check it for even temps throughout the system.
The ever o thermostat housing is not good local. Balkamp 6051115 murry 84903 The dorman bleeder is still good 902-112
I guess better late than never..this is on my sedan. . HRP Terrible photo but I'm sure you get the gist.
