Manual trans guys what are you running for Bellhousing/Scatter shield ?
Discussion in 'The Hokey Ass Message Board' started by Russco, Nov 14, 2013.
  1. Russco
    Russco
    from Central IL
    I'm finishing up the last few things on my 383 motor build for a 40 Coupe. I'm down to selecting a flywheel, clutch and bellhousing. I will be running a TKO 600 trans. I have a 621 Chevy bell housing I was planning to use but now I am wondering about going with a ****ter shield type. This is 99% street car that will see a few trips down the strip. I don't plan on turning it more than 6000 RPM's. I wasn't wanting to spend another 600.00 if I don't need to. So who is running ****ter shields on their Hot Rods.
    1Nimrod likes this.
  2. classic gary
    classic gary
    Short answer, yes, behind a 6-71/327, in front of Muncie 4speed. None of the sanctioning bodies will let you race a clutch car without one.
    1Nimrod likes this.
  3. squirrel
    I have a slushbox....but if I were in your position, I'd go with a ****tershield.
  4. I would not even consider running a clutch car without a billet flywheel and a ****tershield! I run an ancient Lakewood...
  5. dirtracer06
    dirtracer06
    One of the few things i saved from the circle track car was the lakewood ****tersheild i bought new over 20 years ago...no way i want to lose my legs for any amount of $$$$
  6. saltflats
    saltflats
    from Missouri
    Its Lakewood for me behind a 509 in big block and super T10
  7. 64gal
    64gal
    A used(out of date) blow proof bell isn't very expensive and affords a lot more protection than a stock bell.
  8. Bigchuck
    Bigchuck
    from Austin, TX
    Can't go wrong with a blow proof bellhousing. Be sure to index it correctly.
  9. dirtracer06
    dirtracer06
    Dirtracing swapmets are a good place to find them...racingjunk.com is a good site to find them also...
  10. Rocky
    Rocky
    Classified Editor
    I also use an old Lakewood, and a new aluminum flywheel especially after seeing a 270 GMC blow the flywheel at the hamb drags a couple years ago. Luckily the racer had a homemade protective shield and the only casualty was a truck's mirror when a hunk of flywheel flew into the spectator's cars parked offtrack.
  11. falcongeorge
    falcongeorge
    from BC
    Russco, trying to remember if your 383 was a solid lifter motor? If it is, you'll need one before they'll let you make a p***.
  12. 29AVEE8
    29AVEE8
    How important are your feet, ankles, knees,hands, face, testicles... Just sayin'.
    54BOMB likes this.
  13. black 62
    black 62
    from arkansas
    new flywheel and other components with hydraulic lifters you would be ok , but why risk it ?...
  14. 56sedandelivery
    56sedandelivery
    I have two of the old style, cast steel, R.C. Industries ****tershields. Actually, one of those is made in aluminum, very thick aluminum. Although they are no longer legal for compe***ion, they are more than adequate for the street with a performance engine. Plus, they don't have to be completely removed to service the clutch, they have a bolt on lower access cover. The Ansen's, in the same style, usually cost more than the R.C. Ind. units. The steel one I have has some deep scratches/gouges on the inside, so it obviously did it's job for someone in it's past. I'm adding the later model style block plate to them to protect the engine also. Butch/56sedandelivery.
  15. TR Waters
    TR Waters
    from Vermont
    I would use a QuickTime bellhousing. They will fit where a Lakewood will not. They are owned by Lakewood Industries.
  16. olcurmdgeon
    olcurmdgeon
    For the flathead guys, we took a chevy lakewood and found there was enough meat on bolting flange to redrill for rear pattern on an 8BA block, had a pilot bearing made for flathead flywheel that had chevy input shaft ID and viola, we had both a ****tershield and an adaptor for chevy trans to 8BA flathead all in one, at swap meet prices. We stood a black on its nose, centered the ****tershield on back to crank centerline and marked and drilled flange, all garage stuff, no fancy machine shop. Worked great, used it in our FED and then in the Anglia. used hydraulic clutch as I remember.
  17. 29Av8 i've seen that dash before at a stop light in town here, stock flywheel took out the dash and windshield no one was hurt,283 with a 4 speed
  18. TR Waters
    TR Waters
    from Vermont
    QuickTime makes bellhousings for virtually any engine/transmission combination. including flatheads.
  19. Finn Jensen
    Finn Jensen
    I don't know what brand this is, found it on eBay years ago. It's now in my 37 Ford with 388ci SBC in front of Muncie M22.
    I don't know if it would p*** current NHRA requirements, but I liked the removable inspection cover at the bottom. The opening was large enough to change clutch ***embly later without having to pull the engine.
  20. oldsman41
    oldsman41
    if your going to put it on the strip and value your legs I would get the ****tershield.
  21. gicknordon
    gicknordon
    Im using a quicktime but thats mainly because it was the only bell housing i could find for my engine/ trans combo
  22. hotroddon
    hotroddon
    I have a Lakewood in the Anglia
  23. Jmountainjr
    Jmountainjr
    I'm also using a TKO 600 in my model A. The Lakewood option takes up a bunch of room since it's sized for the big 168 tooth flywheel. I'm running a 153 toorh flywheel, and settled on the Tilton Sonic series bellhousing. It is not SFI certified, but is 1/4" hydroformed steel intended for stick car racing. It has a shallow bottom profile for clearance, and will take one of the Tilton bellhousing mounted hydraulic TOB or conventional fork type linkage.
  24. 327Eric
    327Eric
    I have a stock bellhousing behind the 427 on my 59 Elcamino. It was a cost factor, but it is also a car that will never see strip time, and due to the weak nature of the stock components, doesn't get launched hard. If I had a decent ch***is, I would step up to a ****tershield in a heartbeat.
  25. TR Waters
    TR Waters
    from Vermont
    I believe it is McLeod that makes a ****tershield type bellhousing that is not SFI certified. For those who want piece of mind but are not going to sanctioned events that require the certification. I think these are in the $300 range.
  26. Russco
    Russco
    from Central IL
    Thanks for the replies. I'm fully aware of what happens when one comes apart especially the flywheel. This motor will not see more than 6000 rpms (Hydraulic Roller) and will probably float at 6200 or so anyway.
    I will probably run it hard and make some drag strip p***es. I will likely end up going with some type of ****ter shield. I like the idea of the non Certified ones TR Waters speaks of Ill check into that. And now I will probably buy a good one for my truck which I do run pretty hard at the drags too that has never had one either.
  27. hotroddon
    hotroddon
    If you are talking about a Chevy Motor, the Lakewood model 15000 is SFI certified and sells for $369.00
  28. M224SPEED
    M224SPEED
    from Missouri
    The Pic. of the 55 or 56 Chevy dash looks almost like one that our 55 race car did back in 1969 , we did not have the $$ for a ****tershield ,even though they were not that expensive. I would NEVER run a 3 pedal car W/O one no matter how many R.P.M. it might go to. I like my feet & legs to stay with the rest of me,and after the one blew on the ole 55 it made a lifetime believers out of us.
    Do yourself a favor,and install a ****tershield.........block saver too if you can !!!
  29. Russco
    Russco
    from Central IL
    I also like the sound of this one but, I'm not finding much info or pricing on them.
  30. dirty old man
    dirty old man
    I run a McLeod that is SFI certified, but the only difference in a non certified is that it doesn't have the block plat in front of the flywheel.
