1000 cubic inch ford
Discussion in 'The Hokey Ass Message Board' started by Sawracer, Feb 18, 2007.
  1. Sawracer
    Sawracer
    from socal
    Met a gentleman the other day chasing parts who has a 1000 inch ford motor on a shelf. I noticed a gigantic alloy v something and some extremely trick looking heads and I said what's that? He said it was a short run aircraft ford engine that is a 1000 c.i. gas engine. How *****in is that? He also showed me some rods he made himself for his stutz bearcat hot rod motor. Heck I even got to finger bang a deusenburg dizzy while I was there. It was like a car guy bat cave with car elevator and everything. Great day and I think I may even be allowed to take some pics if you guys are interested.
  2. Frank
    Frank
    Actually that was probably the Ford GAA tank engine. There was a thread recently that got so much attention that it brought the HAMB to its knees. In a nutshell, built in 1942, DOHC, 4 valves per cyl. 1050 some odd ft/lbs torque. Quite advanced for its age. I saw another thread just this week about it.
  3. motomech
    motomech
    yeah that motor got banned from drag racing
  4. tjm73
    tjm73
  5. motomech
    motomech
  6. Sawracer
    Sawracer
    from socal
    He said airplane engine, but the utube cylinder heads look somewhat similar. I'll post a pic for hahas, if he doesn't care. I presume they aren't cheap?
  7. peanut
    peanut
    that is so bad ***!!!!!!!!!!!! i love it!!!!!!!!!! thanks a bunch for posting this!!!
  8. motomech
    motomech
    they were designed for air planes first but were not reliable then they were used for tanks
  9. koachwerks
    koachwerks
  10. McGrath
    McGrath
    I prefer the "Five Bank Chrysler" for oddity, myself. 5 Chrysler six cylinders mounted together and stuck into the Sherman Tank.
  11. Chopped50Ford
    Chopped50Ford
    Alliance Vendor
  12. Did you hear The mathmatical formula for estimating if your Ford engine is adequate for the task?
    Take what Cu. In. other makers of like horsepower engines are building and double that,thus producing the same horsepower and delivering less mileage at the same time ......PLUS your parts will cost 4 times what the others do.
    THEN and only then are you a true Ford guy!
  13. tjm73
    tjm73
    OMG!! What the hell is that thing?
  14. Sanford Graham
    Sanford Graham
    Wow Some serious engines guys...........
  15. RichFox
    RichFox
    I had a couple of those things for a while. 1100 inches i understand. I have always heard they were ment to be a V12 aircraft engine and were pushed into service as a V8 by war needs. 4 bolt mains. Pretty cool motor I thought. Still have the manual and some rods and pistons. They didn't come with three twos or zoomies from the factory.
  16. Pete1
    Pete1
    from Wa.
    Really nice machine work throughout. Crank machined on all surfaces, same for rods and cam.
    I ground quite a few cams for them in the 50's.
  17. Wild Turkey
    Wild Turkey
  18. Jack E/NJ
    Jack E/NJ
    from NJ
    That funny-looking head seems strangely familiar. 8^)
    Jack E/NJ
  19. V8 Bob
    V8 Bob
    That is a test firing of a V12 Merlin in a Swedish hot rod built by Mr 42 (I think) over on the old Ford barn several years ago. :D:cool:
  20. Jack E/NJ
    Jack E/NJ
    from NJ
    That Merlin sounds like it needs a mellower cam for a street-use hot rod over here. The FDA would probably ban it. Has a nice lope to it though. 8^)
    Jack E/NJ
  21. Relic Stew
    Relic Stew
    from Wisconsin
    The tank version is called the Meteor. It doesn't have the supercharger, uses cast pistons instead of forged, a**** other things. Designed to run on low octane gasoline rather than 100/130 avgas.
