T-5 input shaft and pilot bearing
Discussion in 'The Hokey Ass Message Board' started by scrap metal 48, Nov 17, 2013.
  1. scrap metal 48
    scrap metal 48
    Is the part of the input shaft that goes into the pilot bearing different diameter between the T-5 and Saginaw 3 and 4 speeds?? OR are there different SBC pilot bearings for T-5's and Saginaw transmissions??? Thanks in advance...
  2. KENDEUCE
    KENDEUCE
    I see on Jegs website that there are different diameters for Chevy. But I also have never seen different brgs for sbc. Could you have a Ford ******? They have different dias.
  3. scrap metal 48
    scrap metal 48
    I replaced a 3spd Saginaw with an 89 S10 5spd and now have a vibration in 5th gear.. I'm trying to determine if it is pilot bearing(which I did not replace), drive shaft or transmission...
  4. KENDEUCE
    KENDEUCE
    Vibrations can be a ***** to find...........don't underestimate anything.
  5. Snarl
    Snarl
    Chevy T5 is the same as any older 3 or 4 speed.
    Ford is the one that used a couple different diameters.
    Vibrations going down the road are not pilot bushing related. If it's "jumpy" when launching, that could be pilot bushing related.
  6. scrap metal 48
    scrap metal 48
    Thanks Snarl, that helps a lot...
  7. brokenspoke
    brokenspoke
    The T-5 imput shaft is metric.......
  8. Snarl
    Snarl
    And yet it fits a standard Chevy pilot bushing just fine.
  9. scrap metal 48
    scrap metal 48
    Are there different SBC pilot bearing part numbers for T-5 and Saginaw transmissions or are they the same.. That's what I can't seem to get a definite answer on.. I don't want to take everything apart if they are the same bearing...
  10. Snarl
    Snarl
    Well, if you look up a pilot bushing for an '85 Camaro 305V8 and a '70 Camaro 307V8 you would find the same pilot bushing listed.
  11. scrap metal 48
    scrap metal 48
    Thanks again Snarl.. I probably could have checked at my local parts house and wouldn't have needed to start this thread.. I guess I'll look at my driveshaft next for my vibration.. I had no vibration with the old 3 spd and old driveshaft.. When the new driveshaft was made it was a very tight fit to install it and maybe it needs another 1/2" or so removed...
  12. krylon32
    krylon32
    from Nebraska
    In my T5 to Flathead conversion kit I address the pilot problem with a br*** pilot bushing. Sold so many of them my machinist can make them in his sleep.
  13. brokenspoke
    brokenspoke
    The camero has a different imput shaft than s 10 T-5......the od is the same for all the newer engines....however the ID of the bushing is different for s-10 and others
  14. scrap metal 48
    scrap metal 48
    So ^^^ can I buy a pilot bushing for a SBC that fits the S10 input shaft diameter???
  15. Snarl
    Snarl
    Guys, I've been running S10 T5's with the regular V8 bushing for around 15 years now.
    If you go to www.rockauto.com and take a look at 1985 Chevrolet. Look at the Camaro, S10 & Astro van. The bushing ID's are all listed at .592-.594 (depending on manufacturer). The OD does change for some engines, such as the 2.8V6 which is smaller OD.
    I have also taken a mic to the tips of several different types of Chevy used transmissions and found them to all be the same, give or take a hair, as they were all in used condition.
  16. scrap metal 48
    scrap metal 48
    Thanks again Snarl.. I'd hate to take mine apart and replace the pilot bushing with the exact same part...
