  1. 58pontiac
    58pontiac
    from michigan
    Thank You Ruben, I appreciate your time.
    Any chance you could do some chrome reverse in the rear, with something like a Halibrand kidney bean up front?
    Thanks,
    Tom
  2. Ruben Duran
    Ruben Duran
    No prob, man.
    Chrome reverse and chrome Halibrand.....
  3. 58pontiac
    58pontiac
    from michigan
    Awesome! Thanks again.
  4. OahuEli
    OahuEli
    from Hawaii
    Maybe some chrome steels with the rear fenderwell radiused?
    [​IMG][/URL][/IMG][​IMG]
  5. verde742
    verde742
    WOW !!!! Comes alive !!!
  6. HotRodNisse
    HotRodNisse
  7. 58pontiac
    58pontiac
    from michigan
    That's Bad ***! Only other combo might be some cragar SS's. Thanks again guy's.
    -Tom
  8. nitrobrother
    nitrobrother
    I like that! Here's what I did with the tail: '57 Packard Clipper wagon taillights and rear tailgate trim, removed the overly large gas filler and added some chrome trim (or Packard body lines) down the side, and thought the pipes would look better on the outer ends of the bumper.
  9. gatz
    gatz
    very good job on that !
  10. Leon Sandcastle
    Leon Sandcastle
    Like the ideas
  11. OahuEli
    OahuEli
    from Hawaii
    You nailed it! Those taillights are perfect for this car. I knew I was missing something.
  12. Leon Sandcastle
    Leon Sandcastle
    I think tbird style exhaust through the bumper would put it together.
  13. speedwise
    speedwise
    Could one of you computer wizzes please slap a set of Cragar SS wheels on this thing? Thanks
  14. StefanS
    StefanS
    from Maryland
    Nitrobrother...that looks good, thanks so much. What I mean is, if you look at a dead on side shot of the '54 (110, 210 or bel air) the roof follows the drip rail for the entire length of the top but then when you get to the rear corner the top keeps going horizontally and then drops off to the decklid. I want to get rid of some of the horizontal rear portion of the roof so the top follows the rear curve of the driprail but still ends at the decklid in the factory location (I'm not sure if I'm describing this right but I can picture it in my head sort of). I'm sure I'll have to use an older model rear window
  15. SouthUrn
    SouthUrn
    from US
    StefanS, I understand the vision in your head (quite unlike verde742). May I offer a possible solution? In addition to an older, smaller backlite think about using a (longer) coupe decklid. Doing so would move partial tray inward and enable shortening roof above drip rail by a few inches, allowing curve to echo drip rail more closely.
  16. jabberwoki
    jabberwoki
    from puyallup
    Can you make it a hardtop?
  17. Shaun1162
    Shaun1162
    Not sure if this one is possible, but can someone chop off the back of the cab and make this into a roadster pickup?
  18. nitrobrother
    nitrobrother
    Here you go...
  19. Ruben Duran
    Ruben Duran
    How 'bout a custom? ;)
  20. nitrobrother
    nitrobrother
  21. Squablow
    Squablow
    I so desperately want to build this car some day. What would be the ideal car to start with to try to build a Tucker out of?
  22. nitrobrother
    nitrobrother
    That's cool (and kudos to HotRodNisse for the initial concept). There are so many weird angles on that car that the curved bits look misplaced. What about a taildragger version?
  23. nitrobrother
    nitrobrother
    Still not sure I'm grasping what you want, but something like this?
    Before:
    After:
    (If not then I'm done anyway! :D )
  24. Shaun1162
    Shaun1162
    Awsome, thanks!
  25. daddio211
    daddio211
    Talk to Rob Ida. He builds them on a custom ch***is with a fibergl*** body and twin turboed Porsche engine!
    My '27 T Roadster build: http://www.jalopyjournal.com/forum/showthread.php?t= 734383
  26. flynbrian48
    flynbrian48
    I read somewhere that the factory cut up Studebaker sedans as donors for the body shells. Whether that's true, or just automotive urban legend, i don't know. There are some 'gl*** ones out there…
    Brian
    QUOTE=Squablow;9362209]I so desperately want to build this car some day. What would be the ideal car to start with to try to build a Tucker out of?[/QUOTE]
  27. Rot 'n Kustom
    Rot 'n Kustom
    [/QUOTE]
    I don't know about the Tucker factory, but a bullet nose Stude was used for the rollover scene in the movie:
    <a href="http://www.flickr.com/photos/carphotosbyrichard/3277109434/" ***le="1951 Studebaker Movie car Tucker stunt double by carphoto, on Flickr">[​IMG]</a>
  28. StefanS
    StefanS
    from Maryland
    Nitrobrother, you hit it right on the head. That's pretty much exactly what I meant. Any way you can do that same thing to the first bel air?
  29. OahuEli
    OahuEli
    from Hawaii
    Probably not a Yugo..:rolleyes::D
  30. speedwise
    speedwise
    Wonderful job as usual. Thank you very much!!!
