Frame boxing
Discussion in 'The Hokey Ass Message Board' started by mcmopar, Nov 15, 2013.
  1. mcmopar
    mcmopar
    from Strum, wi
    I have looked on here, and I cannot find a good article on boxing a frame. I have the basic idea, I just want to make sure I do it right the first time. I read one once that said put the boxing plate 1/8" inside the frame.
  2. GeezersP15
    GeezersP15
    from N.E. PA
    I've never boxed a frame, but it seems like that recommendation would give you little more material to make a stronger weld....Maybe:confused:
  3. mcmopar
    mcmopar
    from Strum, wi
    That is what it said in the article.
  4. F&J
    F&J
    There are several good reasons for that inset plate; Stronger, because the weld won't be ground away like edge welding can, also it makes the frame look less like a repro rectangular tube frame, and because it requires no grinding, that will make it go quicker...JMO
  5. Rehpotsirhcj
    Rehpotsirhcj
  6. pila38
    pila38
    I put my boxing plates in about 1/2" to 5/8". It provides more strength and a little more protection for the lines that will run along them. I have pictures of it, I think you can see them in my build thread.
  7. mcmopar
    mcmopar
    from Strum, wi
    Thanks for the build threads. If I want to weld nuts on in the frame I should do it before I box it.
  8. pila38
    pila38
    Yes. I used cage nuts.
  9. Don's Hot Rods
    Don's Hot Rods
    from florida
    1/8 is fine, we use 3/16 because it gives a little more thickness for tapping threads for non structural items like line clamps, etc. But that is just a personal thing. We also inset the plate a little to give a place to hide lines and it is easier to weld up.
    Don
  10. hotrod--willys
    hotrod--willys
    These are some pic's of the 1940 Willys frame I'm working on. The entire frame has been boxed in with 1/8 plate. Holes were drilled to keep the Willys frame design look. I s***ch weld the plate every 3", each weld is approx. 2" long. All welds have been finished down for a smoother look. Some might say that is because my welds are not like the once were.:( But this is the way I like the frame to look after the paint is on.:) Next will be to prime and paint black. The car is going to be a non metallic dark gray.
  11. gimpyshotrods
    gimpyshotrods
    In any case, whatever method or plan, take your time. Weld short sections. Allow time for welds to cool, and move around.
  12. mcmopar
    mcmopar
    from Strum, wi
    I took the box off tonight, and I have more questions. Do I weld braces to the frame and cut out the factory braces, so I can have a fully boxed frame? I would like to build a rear K member to reinforce the frame. I drive everything I build, and sometimes it gets put away wet. I will take pictures in the morning.
  13. mcmopar
    mcmopar
    from Strum, wi
    Here are some pics of the braces. Do I box as much as I can, build the braces I want, then remove the old braces and finish boxing. I am pretty sure I am making this harder than it is.
  14. panheadguy
    panheadguy
    from S.E. WI
    Hi,
    What ever you do for boxing...consider mounting the frame to a ridged table. Square it up, make sure it's flat and clamped down so it doesn't warp and twist during welding. As mentioned go slow and keep the heat down. Depending on how you plan to suspend it you may not need to box the whole thing. As for the crossmembers, I would leave them in for positioning during boxing. You probably won't be doing boxing with continuous plates so you can remove the crossmembers and replace or re-make as you go.
  15. panheadguy
    panheadguy
    from S.E. WI
    Nice avatar. You got all the important stuff in one shot; scoot, 4x4, and project.
  16. I like to set the boxing plates sticking out beyond the edge of the frame about one half the thickness of the plate used. This creates a right angle channel that you have to weld which gives good penetration. I also bevel both edges to create more surface area. After finish welding I dress the welds square and it makes for a nice clean finished edge. Of course weld sections at a time as to not distort from excessive heat.
  17. langy
    langy
    Flush or step boxed is fine, bevel the edges well and a good competent welder the job will be good, its quite important to clamp down to a table and weld small sections at a time, its amazing how a bit too much heat will move even the sturdiest frame around.
  18. mcmopar
    mcmopar
    from Strum, wi
    Has anyone boxed a frame without a jig? Can it be done slowly?
  19. pila38
    pila38
    Did mine without a jig. I went slow and it came out fine, square and level. As far as the crossmembers go, if you decide you don't want them later, you can always remove them and cover up the hole with another piece of plate. I ended up doing that also.
  20. Pewsplace
    Pewsplace
    I have boxed several Deuce and 34 frames without a jig but I did place 1" square tubing across each hole and clamped the ch***is to saw horses. It takes a long time (2-3 days) for me to do a complete Deuce ch***is and a day to do a 34 ch***is. As mentioned above, go very slow and test for movement as you go.I have warped a few by welding too fast and too soon. GO SLOW!
    Here are some examples including a nice jig.
  21. mcmopar
    mcmopar
    from Strum, wi
    Got the plates built, just waiting for the parts from snow white.
  22. pila38
    pila38
    They came out really nice. Good work.
  23. lucky-13
    lucky-13
    from Sacramento
    X2 looks really nice
  24. hotrod--willys
    hotrod--willys
    mcmopar Here is some photo's of the frame I did on the 1940 Stude. The entire frame was boxed with 1/8" plate. The frame was mounted on a machinist table to keep it in place. It was welded solid. Hope this is some help.
  25. trollst
    trollst
    I don't own a frame jig or table, have done several ch***is on sawhorses, clamp the frame to GOOD QUALITY sawhorses and take your time.
  26. Haha, coil overs, discs, booster. That's about as trad as it gets isn't it??
  27. mcmopar
    mcmopar
    from Strum, wi
    Has anyone added a X member for strength to a factory frame? If so how do you figure out where to put it? I am not interested in putting a new frame under it, just make it better. It might not even be worth spending the time to do it, but I want to look at the idea. Also for the guys that want to have a ******* contest about "traditional" or not, piss off and start your own thread, this one is about frame boxing.
  28. lucky-13
    lucky-13
    from Sacramento
    I apologize for the post I deleted my original post
  29. Pewsplace
    Pewsplace
    The x- members are easy to build and also available from several sources. The location is up to you. Set up the drivetrain and build the x out of cardboard to see where it fits the best. Look at some here on the HAMB. Take the patterns to a good sheet metal shop and have them bent up.
  30. jazz1
    jazz1
    I boxed a portion of my frame (from front cab mounts forward) as recommended by vendor prior to installing a Mustang 11 IFS. I used 1/8'' mild steel which is plenty.
